This is a sticky topic.
  • Originally posted by prn31 View Post
    So it seems somehow, embarrassingly, that I burned the 4020 firmware to both CDs! Doh! I have now burned the V7 maps to a CD-R. The RNS510 tells me to insert a DVD and comes up with an error when I load my CD-R. So should I burn the V7 to a blank DVD? I'll give that ago and see how I go....
    I had a B series RNS510 — it didn't care whether it had a CD or DVD, so maybe the burn is faulty.
    • Originally posted by Idle View Post
      The V7 map i have is 697MB so will have trouble fitting on a CD Also you could be correct Write with IMG burn as slow as possible
      • Originally posted by Hillbilly View Post
        ^^^this.
        Always check the .iso file size before committing to the burn process.
        • Ok, so I downloaded some iso burner software and tried again with another (my third!) CD-R and then put it into the RNS510.
          Viola, it works! So obviously there was a problem with my burn. Now time to turn my attention to the RVC...
          One further question. When I checked the set-up information it said that my map version HDD was 8035? Does that equate to V7, or something else?
          Biscay Blue MY10.5 Passat R36 Wagon
          Options: Sunroof, RNS510 Sat Nav, Dynaudio, Power Tailgate, ACC, RVC, BT 9w7, Tint and Factory Towbar.
          Atlantic Blue MY19.5 Golf GTI
          Options: Luxury Package and Sound & Style Package.
            Yes. 8035=AU/NZ v7
            • So I just bought a Jetta with the RNS 510, and am trying to work out what the go with my head unit is.
              At the risk of sounding stupid; I've done some research through the forums and looked at all the different part numbers. As best I can tell they all start #t and end with the country code (680).
              Mine is a tad different:
              Delivery Part Number: 1K8035680
              HW Version: H05
              SW Version: 6276
              Map Coverage: Australia + New Zealand
              Map Supplied: Sensis
              Map Version HDD: 7920
              Am I missing something here or doing something wrong?
              Apologies in advance if I've missed a post here.
              EDIT:: I'm aware I took this info from the radio "secret menu", but I couldn't get the head unit to go the the second secret menu. Just in case that's relevant.
              • 7920 is V6 latest is V8 Are you sure about the SW no as 5238 is latest most are running
                However if its a brand new car it could be right and have the latest DAB+ board in it
                Doubtless Kamold will come on and get it right for me
                • I believe a tweak to the firmware CD enabled the second secret menu. You could pry the plastic fascia off and remove the T20 screws and pull the head unit out to reveal all he various ID numbers on the sticker. Or wait for kamold
                  Audi A3
                  • That's a brand new ssd based unit. You can enable secret menu with vcds.
                    Sent from my HTC One_M8 using Tapatalk
                    • If the car is new go back to the dealer and ask them to load the V8 maps into it FREE
                        Absolutely certain. I took photos to make sure when I was checking
                        Thanks for the info
                        I'm not that brave tbh. I am brave enough to wait for Kamold.. Speak of the devil.
                        Shall do. Would this guy support DAB+?
                        Thanks everyone for the replies.
                        • Not if it was factory installed. They are available aftermarket from Europe but are more expensive than regular units
                          Sent from my HTC One M8 using Tapatalk
                          • Originally posted by kamold View Post
                            Fair enough. Thanks for the info man
                            This community makes me a feel a ton better about the Jetta
                            • Just a quick follow up guys.
                              The dealership I bought my car from is telling me that I already have the latest maps and that everything is up to date.
                              They also told me they updated the headunit software, but they've indicated they flashed the version I already had.
                              This obviously flies in the face of what you guys have said. I just wanted to check with you all as I don't really trust my dealership :/
                              Thanks in advance for any help
                              • Originally posted by articuno1_au View Post
                                ...........as I don't really trust my dealership :/
                                this.
                                In respect of dealerships and their knowledge and resources for the RNS, like John Snow in G.o.T. they "know nothing".
                                For firmware, they do not have the resources, nor do they know how to apply them.
