Firmware updates for RNS510 units in Australia/NZ
This is a sticky topic.
  • Originally posted by YellowLemon View Post
    Hi mate - you need to make a FORMAT DISK which will wipe the mp3 HDD and/or MAPS partitions .. no need to redo the firmware. Then you can reinstall the maps and mp3 as required.
    Find the CD ISO here: Volkswagen RNS 510 Firmware Upgrade and Information | my-gti.com
    The use imgburn to burn it as a UDF disc (not iso966)
    Good luck
    Thanks, found it. Thanks for that will try this morning.
    • No good, might have to find an older software version or the same one as posted here but with default partitions. Annoying
      • On page 33 of the RNS510 manual it tells you how to delete tracks from the HDD so if you know the one thats corrupted perhaps you could just delete it
        • Can't access any menus, the thing just hangs, plays half the offending track and resets. So some specfics about the HD wiping link I was given, I can successfully get it to boot to the disk but I get a SWL error once I get to what would normally be the install screen. Could this be linked to issues with the burn process of something else?
          Anyway, finding an older version that I'm confident to use is proving to be a bit of a challenge, lots of dead links.
          • Originally posted by mackaxx View Post
            Try this DepositFiles
            • Cheers, will that have the same partition sizes though, different should force the wipe? I'll give it a go regardless, maybe the HDD format CD will work with this version.
              Thanks Again
                Thanks Again
                You could always load the recovery Cd from first page of this thread and start again That 4120 d/load takes about 50 mins
                • Link didn't work, I might have a hunt for the file elsewhere though whilst I wait on this download
                    The 4120 does work The forum the recovery disk is on is down
                    • Grabbed it and installed, and huzzah, we have a clear hard drive. I'll upgrade back up to the newer version and install my music, minus the offending file. It was a WMA incidentally. Thanks for the handy link, was dreading the 2 hours to Sydney and back music and podcast free.
                      Great timing having this issue whilst the forum hosting the recovery disk was done but alls well
                      • Hi guys im new in the rns world. So i bought a golf mk5 2004.. It has a RNS 510 with hdd 30gb the delivery part number is 1T0035680B (so B revesion i think?) the HW version is H03 and sw version 0900 HW radio is 0004.. Can anyone tell me how to update the software safe without losing codings in my car (dont have vcds) checked the gateway is Q index and the end.. that what i readed on the forums is the firmware 5238 is good.. So if anyone could pls help me to update the firmware and dont to brick the device.. Thanks
                        • Yes you can use 5238.
                          Make sure you use the version for Euro, not Australia as the partition sizes will not leave enough space for your maps.
                          It is linked in the post below:
                          • Originally posted by kamold View Post
                            http://www.vwwatercooled.com/forums/...ml#post1167022
                            can you please provide me a safe and good tutorial how to update the firmware?!
                            • Read the first post of this thread. It has the instructions...
                              Sent from my HTC One_M8 using Tapatalk
                              • Hi Members,
                                New to RNS units but not to VWs.
                                Read through the thread before upgrading to 5238 which completed successfully on a HW-Version H04 (can't tell you what firmware was on it before as the secret menu wouldn't appear, only saw a radio menu when holding setup button down).
                                Updated the maps with v7 DVD successfully.
                                Now am trying to get the Navigation to pickup my location.
                                Have driven around for about 20-30 mins and navigation appears to be seeing satellites but doesn't show the location on the map and thinks every direction I drive in is North! (I read somewhere that Passats use the GPS for compass reading)
                                The secret menu shows the GPS antenna is connected (and maps worked ok with the previous firmware), it shows the speed etc...I can browse around the maps.
                                Is it normally just a matter of time before it locates and the Navigation starts working?
