Firmware updates for RNS510 units in Australia/NZ
This is a sticky topic.
  • #31
    You said you had a A unit, which, when upgraded via FW will read as a version D.
    Whatever the unit believes it is, it is STILL an A unit. I have an A unit and cannot go higher than 3810. Have tried 3970, 4020 using a gazillion different burning methods. Ba-bow. No dice.
    Trust me...3810/V5 maps/Personal Poi's and personal Splash Screen is more bling than you need. 4020 is not giving you any more bang for buck.
    MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
    2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
    • #32
      Originally posted by jamerson View Post
      thank you so much for the answer,
      yes my Map is still loading ( Westen Europe Map ) , GPs is fine 10/12 Sat,
      when i tried to eject the DVD its warned me the map is on the process and i will break the process,
      so i will have to wait untill all is finished,
      How big is the Europe west map DVD?
      It is possible that there is not enough space on the map partition and it is getting stuck. Also how big is your hdd?
      These custom firmware images were created specifically for Australia and New Zealand users whose map data is only 600mb or so.
      If we find that the partition for the map data is too small with 90/5/5 ratio I can make a new custom script to change to 80/15/5 or similar in order to allow enough room for your map data.
      • #33
        Originally posted by FJ Steve View Post
        You said you had a A unit which now reads as a higher/later version (D?).
        FJ Steve speaks the truth. Follow his advice...
        • #34
          awesome, ok, well with that in mind, with the gradual upgrade, is upgrading like twice fine, once to 2664, then to 3810?
          Also, do I need to worry about this for 2664 update:
          Extract files PQTABLE and SKTABLE from image (use magiciso or ultraiso). Files can be found from path: \VUCI\B101\RNSMIDEC\PROG
          Switch the filenames by just renaming SKTABLE to PQTABLE and vice versa
          Overwrite the renamed files back to image and save the image. Burn this image to DVD or CD.
          Load or reload the Firmware to your RNS-510 using the steps below.
          Voilá… buttons are back!
          I am a Skoda owner, but im not 100% whether it is referencing for BT module buttons, or every skoda ownder should do it regardless.
          And Do I need to know about this for any reason on the 3810 update:
          Revision A, B and C revision units
          These units will become SW revision D after the upgrade however when coding the unit using VCDS you will receive the error
          “Coding Rejected, Error 31: Request Out of Range”
          Before saving the new coding manually add a 10th byte (00) at the end before pressing “Do It” as per the example below
          9 byte coding (A/B/C SW revisions):
          020104000400001100
          10 byte coding (D SW revision):
          02010400040000110000
          • #35
            Bazinga...just realised he is from Germany. Yep...the Europe maps are so big, they issue an East and a West edition.
            thank you guys for the help,
            will get back to you about this when the map is fully on the HDD,
            ---------- Post added at 10:35 PM ---------- Previous post was at 10:24 PM ----------
            the European Map is 4GB ISO, my HDD as i beleive is 30GB, according to the below info, and there is 26 GB free still
            Support Status : HDD supported
            Tempstatus : Degraded
            Power Status : ok
            TEmpstatus : --
            HDD read size 30005821440
            Number of partition = 3 Partition
            Volfile system = filesystem_f..
            Volumsite- 26977769928
            Remaine size = 26977751040
            Firmware version = F4rjas03
            Model = Hitachi HEJ425030
            is there is away to figure out the process status? like how many % is it right now?
            • #36
              I would say with a 4G ISO, and only 5% full HDD space reserved for maps in this Aussie modded version of the f/w, that it will not be any good for you (assume you have a 40G HDD, that will only be 2G partition for maps, not enough for Europe more than likely). If your HDD is 30G, that is only 1.5G partition size for maps. I guess Volkswagen came up with the partitioning scheme with Europe in mind, but for Australia, we don't need anywhere near the kind of space reserved for maps (or POIs), hence the 90/5/5 split for the Aussie (modified) firmwares.
              Manual MY12 RB Golf R | Bluefin Stg2 | Milltek turbo-back
              • #37
                is it possible that someone can help to recreate the new Firmware for Europe to have space on the HDD for the map and POI?
                • #38
                  I believe Kamold indicated that he would work on something for you (in a previous post).
                  Here:
                  • #39
                    Here:
                    he will save my life if he will do this,
                    thank you so much guys
                    waiting for Kamold answer!
                    • #40
                      Please stand by.....
                      As the original post mentions, these custom firmware images were designed for Australia and New Zealand users.
                      We have a pretty small road network compared with Western Europe, so the map disk is under 1GB of data. Therefor we are able to use more HDD space for music.
                      JohnC will provide us with some modified files and I will update the guide in the first post.
                      We will use 75% of space for music, 20% for map data and 5% for POI database.
                      • #41
                        thank you so much man,
                        is it going to be new firmware installation or just like repartition the HDD?
                        • #42
                          It will be a full firmware load.
                          It is possible to just do a HDD repartition, but I want to try and make this is easy as possible for as many people as possible, without too many variations. This was initially intended only for Australia/NZ however as the internet is what it is, seems popularity has spread this further.
                          Appears a club in Spain has come across this as well.
                          • #43
                            so i am not the only European guy with this issue,
                            i beleive i saw somewhere a kind of tools to repartition your HDD without loading the new firmware,
                            i do really like this firmware and feature its provides me,
                            speed warning. compas ect...
                            • #44
                              In my club from Spain there are some people than can't install the maps because the partition hasn't enough space.
                              I'm waiting for the European too.
                              Thank's
                              Enviado desde mi LT18i usando Tapatalk
                              • #45
                                Thank's
                                i am happy we still can use the navi with the disk insered
                                Kamold is working on our issues!
