Initial post updated with link for Euro users.
Firmware updates for RNS510 units in Australia/NZ
This is a sticky topic.
The only difference will be the partition ratios which should allow enough room for your maps.Originally posted by jamerson View PostThank you mate,
this firmware is exactly the same as the one i already uploaded to my Unite?
same speed limite, the font, the color , video in motion, secret menu...?
thank you2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Success - Thank You!
Successfully updated my unit (1T0 035 680 C) to Firmware 40xx earlier this week.
Installed V5 maps and personal POI's via SD Card as well.
Whole process was a snap thanks to the clear and concise instructions provided by "kamold".
My only advice - Be patient - It takes some time.
Would have liked to include the personal POI's on the map disk but my limited IT knowledge prevented me from doing this.
I did try on several occasions but alas I failed and created several coasters.
Just like to take this opportunity to thank "kamold" and "JohnC" for their work.
I can assure you that there are many who appreciate it.
Cheers...MY11.5 MKVI Volkswagen Golf GTI | 5 DR | Deep Black Pearl | Manual | Bi-Xenons (Incl LED's) | 18" Detroits | Black Leather Package | RNS510 Sat Nav | MDI | Bluetooth | R Tails | P3 Gauge
what kind of POI databas did you uploaded? .db3 or different one?Originally posted by OzTrekker View PostSuccessfully updated my unit (1T0 035 680 C) to Firmware 40xx earlier this week.
Cheers...
my RNS doesn't recognise my SD Card at all!
i formated the SD FAT32, NTFS nothing makes different please advise, i need the POI
SDCard needs to be FAT32. Are you using POInspect0r to create the .db3 file or are you downloading from someone who has created it?
The file needs to be named PersonalPOI.db3 and needs to be stored in a folder on the SDCard root directory called "\PersonalPOI"2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
the file i have is originel from the Western Map,Originally posted by kamold View PostSDCard needs to be FAT32. Are you using POInspect0r to create the .db3 file or are you downloading from someone who has created it?
but it calls different and its on EDP folder,
should i rename all?
you mean it should call like this "root"\PersonalPOI\PersonalPOI.db3 ?
does anyway PLEASE has the EU POI with speed cams ?Last edited by jamerson; 19-04-2012, 08:03 PM.
Jamerson this is a forum mainly used by VW owners in Australia.
We've helped you out a lot I think so far with creating custom firmware etc but as we don't live in Europe I think you are better off waiting to hear from someone from the vwnavi or gpsunderground forums where you have posted similar requests...
I don't mean to sound inhospitable but the other forums are more likely to be able to assist you with local mapping issues.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
thank you man,Originally posted by kamold View PostJamerson this is a forum mainly used by VW owners in Australia.
i am sorry, i know i am being bit helarisch!
i will wait for someones else answer, apologies for being like pain
No problem, good luck with getting your poi database setup.
Ps thanks for bailing Europe out of its debt problems
Last edited by kamold; 19-04-2012, 08:46 PM.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
you guys helped me, so it alteast what i can doOriginally posted by kamold View PostNo problem, good luck with getting your poi database setup.
i found somewhere its could be the databas name, so i am gonna try to reset it,
and get back with the result to help others
kamold,
I've found a 4020 version which may be suitable for A version units.
Currently downloading it and will attempt to apply it this weekend.
Any chance (if I can get it working on mine) that you can re-organise the partition profile to reflect 90/5/5%?MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
Yeah I saw that they have done the table swap for 4020 as well.
By all means test it but to be honest I don't know if its worth the trouble...
There are no new features at 402x and haven't really noticed any speed increases as advertised. However it would be worth changing the partition scheme so that you can swap between versions without losing your maps and music.
JohnC has the cable at the moment so he'll have to write the Dlscript.txt file for you for integrate into the firmware image. He's a busy man but he is always very obliging with requests.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Hi all i am having a problem saving music from a CD to the HDD on RNS510 satnav. service center said it is right protected. i have tried making a CD through itunes and media player no luck. they play on the unit no problems any tips thanks. its a new tiguan pacific only two weeks old
