Firmware updates for RNS510 units in Australia/NZ
This is a sticky topic.
  • Disk, burner and software. Plus luck.
    Sent from my HTC One X using Tapatalk 2
    • RNS510 Portuguese Voice control? (Help)
      Hello
      Sorry for my question, I have a RNS510 1T0 035 680 C HW50 SW2840 and it works great but it has not voice control in Portuguese. Do you know if the new SW3970 or 4020 or ... has the Portuguese voice control?
      Can anyone who has firmware later than the 2840 test it for me? Please choose Portuguese language and activate the voice control (star) and see what happens, in my unit appears a message that say something like this "Not active".
      Thank you
      Bye from Portugal
      • Hi
        Problem solved. The information is that the new firmware later than 2840 (3xxx, 4xxx) has the Portuguese a Spanish voice control.
        Thank you all
        • Help - Update firmware from 2840 to 4120 (or other)
          Please help, I want to update my firmware from 2840 to a high version (1T0 035 680 C: Production 11/2009 – 05/2011 HW50 / SW2840 Europe). I see a lot of posts but I have not a conclusion, can I upgrade directly with "SWL 4120 for RNS510 (50-25-25 partitions)" or I must upgrade first to 3810 and after to 4120?
          Thank you
          • Think you can go direct, but have you read all the warnings for that version of firmware? You'll need a VCDS cable to recode your RNS510 if you install it. Plus you need to burn to a DVD+R since other discs have failed half way through. Otherwise you might be safer going only as far as version 4020.
            Audi A3
            • Thank you Ryan_R
              Let me see if I understand. I can go directly to 4020 (better than 4120) (it makes new partition in the HDD and format them). I need a VCDS cable to recode the RNS and put 2 more digits (00) before click "do it". Reload the maps. Is it all?
              For this I do to burn a DVD+R (does verbatim DVD-R works too?) for firmware and a DL for maps.
              Can the firmware be the FW_4020_70_20_5.ISO?
              All I want is the portuguese voice control that the 2840 hasn't.
              Thank you
              • 4020 should be a simple upgrade using CD-R.
                4120 is the one that needs VCDS and DVD+R.
                Go under the assumption that you will lose music and maps when you upgrade to either.
                Audi A3
                • Hi all, have version A RNS with 3810 FW. I am interested in getting the radio song text to appear. If this is possible which version should I be looking at?
                  • Don't think there's anything available for you yet. There was a separate version of 4020 for version A but haven't seen one for 4120.
                    Audi A3
                    • I would steer well clear of attempts to update on older units to 4120 or higher as the radio board is not compatible and will likely damage your unit requiring hardware to be replaced.
                      • Originally posted by kamold View Post
                        +1
                        The gurus in Europe have advised that the Radio board from version D (I think) onwards is only suitable for such an upgrade. A & B units stand a very good chance of being bricked (some classic examples on the Euro forums of guys who have gone in boots 'n all just to have the latest Firmware, and haven't paid attention to to the guys in the know - like our good friend kamold - and now have the "white or black screen of death")
                        MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
                        2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
                        • Number of C units (mine included) have upgraded ok. That said I'm not sure if having radio text enabled is reducing reception quality, noticing a tiny bit of static on some stations occasionally.
                          Audi A3
                          • Originally posted by FJ Steve View Post
                            +1
                            i have an A-unit, and successfully upgraded from firmware 272x to 412x with no probs.
                            3T0 035 680 A
                            HW: H41
                            SW: 2724
                            B 26.08.2010
                            • Originally posted by dArK5HaD0w View Post
                              3T0 035 680 A
                              HW: H41
                              SW: 2724
                              B 26.08.2010
                              And you have Radio Text now? If not, what improvements have you noticed?
                                my apologies, i got it wrong - i upgraded to "402x with no probs", not firmware 412x.
                                so pls ignore my earlier post.
