Originally posted by fox
View Post
1 of 2
2 of 2
Firmware updates for RNS510 units in Australia/NZ
This is a sticky topic.
Just updated the firmware to 5238 from 4120 on my D model. That went OK, but no maps. Tried to load new v.8 map disc. Wouldn't load maps, and no info on the screen. Tried rebooting, but no good.
When I zoomed out the map scale to 700km I found that Europe could be seen as a deep purple colour and the oceans were all black. That's why I said i thought I had a black screen. Weird.
I'm trying to find a working link to go back to 4120 with the 95/5/5 partitions. Can't find the disc I burnt a couple of years ago anywhere.
As always, any help much appreciated.
You shouldnt have lost the map Go for a drive and let it reorient itself If that doesnt work load an older map disk and if that loads then load V8
You cant load the same map over itself I found that out last year2021 Kamiq LE 110 , Moon White, BV cameras F & B
Originally posted by Hillbilly View PostYou shouldnt have lost the map Go for a drive and let it reorient itself If that doesnt work load an older map disk and if that loads then load V8
Just need a GPS signal top reorient the system. At worst have seen it take up to an hour. Driving around shouldnt take more than a few mins.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Hillbilly/ Kamold/ FJ Steve, Thanks for the input. I drove around a bit this morning and eh voila! The fully functional mapping appeared on the screen.
I bought the car with v.3 maps ( not long before v.4 came out of course), and have updated every new version. It says something about either my ailing memory as to why I didn't recognise what was going on, or that it's that long between VW map updates I can be forgiven for not remembering the procedures. Or maybe a little of both.
Anyhow, thanks guys. I do truly always appreciate the help.
No. You're 2 main options for videos are to (1) author your own DVD each time, or (2) install a Red/White/Yellow AV cable to RNS adaptor (connects to the back of the unit where a reversing camera normally would) - you'll find them on eBay. Of course then there's option (3) which is to install a new non-OEM head unit.
Originally posted by Ryan_R View PostNo. You're 2 main options for videos are to (1) author your own DVD each time, or (2) install a Red/White/Yellow AV cable to RNS adaptor (connects to the back of the unit where a reversing camera normally would) - you'll find them on eBay. Of course then there's option (3) which is to install a new non-OEM head unit.
Yep, it's just worth pulling out your RNS/Columbus and double-checking that it has the reversing camera plug before buying. There were some RCD510 (non sat-nav) variants that didn't, for example.
All Rns510/Columbus units have 26pin multimedia connectors.
Sent from my HTC One_M8 using Tapatalk2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
So in order to install a RVC I was given a usb with 4020 firmware and V7 maps to burn on to CDs and load onto my RNS510.( I was told I had old firmware that wouldn't support an RVC and V5 maps.
The firmware loaded ok but my maps didn't. I got that clamp state message and reset my clock to 24 hour mode and it did seem to install ok.
But at the end when I tried to hit the map button it told me to insert map dvd, which I did and it came up with the clamp state message again.
I checked the set up and I've got no maps at all.
What have I done wrong? Is there a problem with my V7 map disc?Biscay Blue MY10.5 Passat R36 Wagon
Options: Sunroof, RNS510 Sat Nav, Dynaudio, Power Tailgate, ACC, RVC, BT 9w7, Tint and Factory Towbar.
Atlantic Blue MY19.5 Golf GTI
Options: Luxury Package and Sound & Style Package.
Originally posted by prn31 View PostSo in order to install a RVC I was given a usb with 4020 firmware and V7 maps to burn on to CDs and load onto my RNS510.( I was told I had old firmware that wouldn't support an RVC and V5 maps.
Not following instructions correctly Have your engine off when doing it Just unlock car and turn the RNS on ( as per post 1) Had same trouble till I worked out what was causing it Forgot since last time
After they have installed go for a drive to let them sort the locality outLast edited by Guest001; 19-07-2015, 10:41 AM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
So it seems somehow, embarrassingly, that I burned the 4020 firmware to both CDs! Doh! I have now burned the V7 maps to a CD-R. The RNS510 tells me to insert a DVD and comes up with an error when I load my CD-R. So should I burn the V7 to a blank DVD? I'll give that ago and see how I go....Biscay Blue MY10.5 Passat R36 Wagon
Originally posted by prn31 View PostSo it seems somehow, embarrassingly, that I burned the 4020 firmware to both CDs! Doh! I have now burned the V7 maps to a CD-R. The RNS510 tells me to insert a DVD and comes up with an error when I load my CD-R. So should I burn the V7 to a blank DVD? I'll give that ago and see how I go....2021 Kamiq LE 110 , Moon White, BV cameras F & B
