Firmware updates for RNS510 units in Australia/NZ
This is a sticky topic.
  • Originally posted by Lindsey View Post
    Really need to update the rns510 firmware for my GTI, but i don't have the gps/sat nav disk... anyone have a link to a download?.
    thanks
    Dont ask we dont have illegal software on here
    • Hillbilly,
      Obviously i'm a noob lol, ahh sooo if i don't have the original sat nav disk i cant upgrade rns 510 fw?
      and no point buying 2010 maps disk either.
        Hillbilly,
        Hillbilly is pointing out the technical deficiency of your request. Asking for links to download the maps is taboo.
        However, if you were to ask if someone could assist by re-loading their disc onto your unit after you have done the FW update, may find a different response.
        Ask for assistance that does not involve an illegal process.
        MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
        2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
        • Ok Sorry I didn't know..
          I'll start again lol.
          My problem is that I need to upgrade fw on the rns 510 and i do not have the maps to reload back into the unit, so if anyone could please assist in anyway to advise me where to get either new or old maps to reload into the rns 510 please, it would be extremely appresiated, thanks in advance.
          • Google VW Forums Some are not as strict as ours ( Or maybe havent been rapped over the knuckles yet)
            • Originally posted by FJ Steve View Post
              Ha ha Thats still technically illegal but maybe someone will oblige LOL
              New V9 maps are $199 from GKU You might get a V8 which most of us have for about $55
              • Originally posted by Hillbilly View Post
                Not anymore......$595 and they're out of stock.
                • Originally posted by willsy01 View Post
                  A stealer might have some old stock of V8
                  JKU advertising it for $99
                  • Hi Everyone,
                    Just wondering if anyone definitively knows which firmware I have to downgrade to to avoid the battery drain? I gave 5xxx, 4xxx (with swapped tables) and now 2760 on my H04 A revision RNS and haven't had much luck (killed the battery twice on the 4 and 5 firmware versions). I have yet to test the 2760 firmware as I couldn't afford to risk it with work (have been pulling the fuse out) so was wondering if this should fix it? Is there any way to potentially tell if its not shutting down properly?
                    Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
                    Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
                    Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
                    • Read through the thread Im pretty sure its nothing to do with firmware Its a module in the car needs upgrading. Kamold will know but its been discussed a lot so maybe a search on "Battery drain" will help
                      • update from CANBUS 1.6 to CANBUS 2 is required to avoid battery drain
                        • Canbus gateway upgrade is the most complete solution.
                          However in some cars (eg 2007 Golf where its up behind the upper relay carrier behind the dash) it's a pain to get to.
                          This firmware has some tables swapped so should prevent the RNS staying awake when it should be going to sleep after 30mins:
                          • Old site but still useful
                            my-gti.com |
                            Tig 162 R-Line; Audi TT
                            • Originally posted by kamold View Post
                              http://www.rnsfirmware.com/downloads...CD_4020_M3.iso
                              Thanks Kamold, you have done much more than you get credit for on this topic!
                              unfortunately i have tried this firmware with the tables swapped (guessing its the same as the one off the my-gti website?).
                              Seems like 2760 might be causing battery drain as well. I have 960 in there before and that didnt cause it, so perhaps I will have to go all the way back to that
                              • I would replace the gateway so that you can use current firmware.
                                But that's me.
                                You can get a gateway from online sellers that will have it already correctly coded for you if you don't want to use VCDS or OBDEleven etc to configure it.
