Originally posted by joecool
View Post
Firmware updates for RNS510 units in Australia/NZ
This is a sticky topic.
I believe that the disk interface is PATA, not SATA, so you might need to check the compatibility of your disk. Apart from that, I recall that there is a tutorial/guide on how to do the disk upgrade somewhere on this forum, so you should search for that.Last edited by arcadelt; 15-05-2017, 09:29 PM.Daily: 2010 Tiguan TDI | Candy White | Manual | 4MOTION | New York Wheels | Comfort Pack | Tinted Windows | Discover Media | MkVI MFSW | Mk7 Climatronic | RVC | Fog Lights | ECB Nudge Bar | Hella 160 Driving Lights | Rola RBXL135 Cross Bars | To Do: Colour MFD
Toy: 2008 GTI Pirelli | Sunflower Yellow | 3 Door | DSG | Pirelli Wheels | RNS-510 | 9W7 Bluetooth | RVC | Rear Sensors | Fog Lights | To Do: Mk7 Climatronics, MkVI MFSW, Colour MFD
I haven't actually pulled my current RNS unit apart (same as the above post from @joecool) however I don't believe that the SSD in these units has a SATA interface. I'm pretty sure it is a NAND flash device soldered straight onto the board.
So unless you've got the mad solder skillz and can replace 144pin TFBGA packages you're stuck with the small device they've decided to stick on it...2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Me too (ABC RN); but don't be disheartened. You could always get the MDI kit and an old iPod Classic and then you would have 160GB of storage (or more if you custom upgrade it - I have one with 512GB on board), or the appropriate bluetooth module and then stream from your smartphone to your heart's content. Personally, I use an iPhone and anything that I can play on that can be streamed to the RNS-510.Originally posted by joecool View PostI see. Thanks arcadelt and kamold. I mostly listen to talkback radio anyway....Daily: 2010 Tiguan TDI | Candy White | Manual | 4MOTION | New York Wheels | Comfort Pack | Tinted Windows | Discover Media | MkVI MFSW | Mk7 Climatronic | RVC | Fog Lights | ECB Nudge Bar | Hella 160 Driving Lights | Rola RBXL135 Cross Bars | To Do: Colour MFD
Has anyone found bugs in the 5238 firmware?
- I find that when I start the car the radio sometimes forgets what station I was last tuned into and reverts to whatever the first station it finds in the FM band, in Melbourne it's 89.9Mhz Light Christian Music *groan*.
- GPS takes forever to get an accurate fix on you, usually at least 5 mins before the navigation can start directing you properly, before that the GPS shows my location as been blocks away from where I am.
Mate, this worked and I was able to do one set of recoding, and now it won't change the code at all? It just comes up with "coding accepted" but when I go back to check the coding, the "current coding" refuses to change. Any ideas? ATM it's running as if it's got a sound system installed so low volume which is a bloody painOriginally posted by kamold View PostTry putting in this string and saving, then go back and edit the coding bytes using long coding as appropriate for your car:
04010000010000930011
Sent from my HTC 10 using Tapatalk
Sent from my iPhone using TapatalkCurrent: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
There sounds like there is a bad eeprom in your unit.
Initially it had no coding, now it's not saving new coding.
I would try and enter the coding string a few times in a row to see if it will update, otherwise might need to look at a repair
Sent from my HTC 10 using Tapatalk2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Got it to take the code by reinstalling firmware, coding that generic one you sent me, then recoding again. Fingers crossed its now bloody fixed!Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
Good result
If you are using the cable that came with it you will find it will only charge it NOT play music through it.Originally posted by RSanti View PostHi, do you know where I can have the rns510 updated here in Melbourne? There's a compatibility issue when i plug my Iphone ios 10.3 in MDI. Thanks2021 Kamiq LE 110 , Moon White, BV cameras F & B
Hi everybody.
Newbie here with little vw knowledge, however, my wife has a 2012 yeti with an rns510 that has decided that audio isn't nececary and that neither is English.......
From what I have read, it isn't exactly an uncommon issue and is usually rectified with a software/firmware update, but there are so many hardware versions and software versions for different regions etc, I find it a little daunting.
Anyone prepared to help me decipher exactly what I need to sort it?
Thanks in advance
Install version 5238
