Firmware updates for RNS510 units in Australia/NZ
This is a sticky topic.
  • Originally posted by kamold View Post
    I would replace the gateway so that you can use current firmware.
    But that's me.
    You can get a gateway from online sellers that will have it already correctly coded for you if you don't want to use VCDS or OBDEleven etc to configure it.
    Thanks mate, I may go down that route at some point, although my gti is 07, so does that mean its a PITA to get to the CANBUS?
    And trying to figure out which CAN BUS i can get away with - would a 1K0 907 530 S be sufficient?
    Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
    Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
    Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
    • You can just get the newest 7N0 gateways they are probably cheapest.
      The location is a bit of a pain but once you know where it is probably only takes 15 minutes.
      Last time I did one I just took the bottom cover off the footwell, then removed the upper relay carrier to push it out of the way and you can then see the gateway up towards the firewall. It unclips and you can disconnect the cable.
      Some people come in from the engine bay by removing the rain tray but I think this would take longer.
        Thanks Kamold.
        So even with 1300 firmware, the RNS510 seems to be refusing to shut down. I have the multimeter sitting in line in the fuse plug and after a night locked and off, it is still drawing 1.88amps.
        Is there something I am missing? Perhaps coding of the old CANBUS H revision?
        Anyone got any ideas?
        • First thing to do is upgrade the gateway, then you can run current firmware on your RNS.
          If you can find someone with access to ODIS-E (engineering) they can upgrade your gateway to software version 0178 which will resolve this.
          Otherwise you just need to physically replace the gateway with a new one that already has new software loaded on it.
            Gateway upgraded! $20 from the wrecker - told them it was a relay haha. Seems to have immediately solved battery drain!
            • Originally posted by mb1907953 View Post
              Good result
              It is kind of a network relay...it's not a TOTAL fabrication...
              • Hi Again Kamold,
                Going to call again on your expertise - I am trying to code the bloody thing and I keep getting Error 31: Request out of range. I have tried to change the coding from 9 bytes to 10 bytes, and then back, but it just wont accept either.
                Any other ideas?
                • Trying to code the gateway?
                  What is the pn and SW version on it?
                  What exactly are you trying to change?
                  Sent from my HTC 10 using Tapatalk
                    Sorry - trying to code the RNS-510! Im trying to just code in the active speakers and change the display style to a different colour code (highline).
                    It's currently coded as all zeros (00000000000000000000) and wont accept any code I put in!
                    EDIT: Updated to 5238.
                    HW04 unit
                    1T0035680L is the part number coming up, although it was originally an A before update.
                    • Are you using a non-zero workshop code?
                        Yep I've tried that as well. 12345 123 12345
                        • Try putting in this string and saving, then go back and edit the coding bytes using long coding as appropriate for your car:
                          04010000010000930011
                            You are a legend! Thanks so much
                              I do what I can...
                              • Dear all
                                Requesting any assistance. I have searched far and wide but to no avail.
                                I have recently got my hands on an RNS 510 (1T0 035 686F) HW H30 and SW 6270. I have since upgraded the firmware to 6276.
                                I have a spare 512GB SSD lying around so am thinking of installing that, replacing it with my current 40GB SSD.
                                The question is - is there any SW 6276 with custom partitions and if so, can someone please point me in the right direction for how to go about obtaining it (or instructions on how to go about creating my own ISO)?
                                From what I can see, all of the firmware that has custom partitions seem to be 5XXX or earlier. I can't seem to find any for 6276. Or does this not exist and I need to live with a 256GB partition for maps?
                                Am located in Australia.
                                Thank you.
                                .:R32 - because it's all about cubic inches.
