Originally posted by prn31
View Post
Firmware updates for RNS510 units in Australia/NZ
This is a sticky topic.
Originally posted by Idle View PostI had a B series RNS510 — it didn't care whether it had a CD or DVD, so maybe the burn is faulty.Last edited by Guest001; 19-07-2015, 10:42 AM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
Originally posted by Hillbilly View PostThe V7 map i have is 697MB so will have trouble fitting on a CD
Always check the .iso file size before committing to the burn process.MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
Ok, so I downloaded some iso burner software and tried again with another (my third!) CD-R and then put it into the RNS510.
Viola, it works! So obviously there was a problem with my burn. Now time to turn my attention to the RVC...
One further question. When I checked the set-up information it said that my map version HDD was 8035? Does that equate to V7, or something else?Last edited by prn31; 19-07-2015, 02:47 PM.Biscay Blue MY10.5 Passat R36 Wagon
Options: Sunroof, RNS510 Sat Nav, Dynaudio, Power Tailgate, ACC, RVC, BT 9w7, Tint and Factory Towbar.
Atlantic Blue MY19.5 Golf GTI
Options: Luxury Package and Sound & Style Package.
Originally posted by prn31 View PostWhen I checked the set-up information it said that my map version HDD was 8035? Does that equate to V7, or something else?2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
So I just bought a Jetta with the RNS 510, and am trying to work out what the go with my head unit is.
At the risk of sounding stupid; I've done some research through the forums and looked at all the different part numbers. As best I can tell they all start #t and end with the country code (680).
Mine is a tad different:
Delivery Part Number: 1K8035680
HW Version: H05
SW Version: 6276
Map Coverage: Australia + New Zealand
Map Supplied: Sensis
Map Version HDD: 7920
Am I missing something here or doing something wrong?
Apologies in advance if I've missed a post here.
EDIT:: I'm aware I took this info from the radio "secret menu", but I couldn't get the head unit to go the the second secret menu. Just in case that's relevant.Last edited by articuno1_au; 21-07-2015, 08:56 PM.
7920 is V6 latest is V8 Are you sure about the SW no as 5238 is latest most are running
However if its a brand new car it could be right and have the latest DAB+ board in it
Doubtless Kamold will come on and get it right for meLast edited by Guest001; 21-07-2015, 09:14 PM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
I believe a tweak to the firmware CD enabled the second secret menu. You could pry the plastic fascia off and remove the T20 screws and pull the head unit out to reveal all he various ID numbers on the sticker. Or wait for kamold
That's a brand new ssd based unit. You can enable secret menu with vcds.
Sent from my HTC One_M8 using Tapatalk2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Originally posted by Hillbilly View Post7920 is V6 latest is V8 Are you sure about the SW no as 5238 is latest most are running
Thanks for the info
Originally posted by Ryan_R View PostI believe a tweak to the firmware CD enabled the second secret menu. You could pry the plastic fascia off and remove the T20 screws and pull the head unit out to reveal all he various ID numbers on the sticker. Or wait for kamold
Originally posted by kamold View PostThat's a brand new ssd based unit. You can enable secret menu with vcds.
Thanks everyone for the replies.
Not if it was factory installed. They are available aftermarket from Europe but are more expensive than regular units
Sent from my HTC One M8 using Tapatalk2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Originally posted by kamold View PostNot if it was factory installed. They are available aftermarket from Europe but are more expensive than regular units
This community makes me a feel a ton better about the Jetta
Just a quick follow up guys.
The dealership I bought my car from is telling me that I already have the latest maps and that everything is up to date.
They also told me they updated the headunit software, but they've indicated they flashed the version I already had.
This obviously flies in the face of what you guys have said. I just wanted to check with you all as I don't really trust my dealership :/
Thanks in advance for any help
Originally posted by articuno1_au View Post...........as I don't really trust my dealership :/
In respect of dealerships and their knowledge and resources for the RNS, like John Snow in G.o.T. they "know nothing".
For firmware, they do not have the resources, nor do they know how to apply them.MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
