Firmware updates for RNS510 units in Australia/NZ
This is a sticky topic.
  • Originally posted by Nos View Post
    Hi All,
    Need some help.
    Tried updating firmware on my RNS510 to v4120 but it failed about 51% of way through. Now have no radio etc. Looking for help on getting another copy/or loading of the 4120 software so I can finish the update.
    Have rebooted but requires the installation to complete before I can get back to normal use.
    Regards,
    Shayne
    Go to original post and download the version that fixes your problem and load that and start again Here it is
    DepositFiles
    What version is your 510 as early versions wont load 4120 as stated in the OP WILL BRICK IT
    • Thanks HB.
      Not sure on exact version, however it is from a 2010 passat so assumed it would be ok. Tried the secret menu but never got passed the radio menu.
      Hopefully I haven't bricked it!
      • Ok heart palpitations have been averted. Downloaded and loaded the fix and all working. Thanks HB!
        New problem is that everything is in German. Even when I go to the system menu and choose English it remains in German.
        • Load the map....then select "English" as language.
          MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
          2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
          • Thanks FJ, tried that but it didn't give me an option to select language during or after it had loaded.
            • I can now interrogate the unit by holding the setup button and have discovered my h/w version is 0006. So I may try to upgrade to 52xx firmware and see if I have more luck. Although the minimum burn speed my laptop will do is 10x which I believe may cause issues...hmmmm dilemma's.
              Nevertheless thanks to all the tireless efforts of those that post the information and provide advice. Muchly appreciated!
                -I thought the H/W version relevant to the latest version firmware you can run ends in a letter... but I think radio HW 0006 is usually in the later LED units ... C+ so should be OK
                Same here, minimum 10x write speed, common in the newer CD burners/Cd media. I wouldn't worry about it, I never had a problem with it using IMGburn.
                - 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
                - 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
                • Thanks YL, I am in the process of loading it onto dvd-rw (due to size) now. Fingers crossed it goes smoother than the 4120 upgrade.
                  • cdburnerxp allows burn speed down to x1. use "Track-at-once" burning method.
                    • Originally posted by FJ Steve View Post
                      The software lets you select that, however the burner itself sets the minimum speed. You will request 1x and receive the lowest available, usually 16x these days...
                      • Originally posted by kamold View Post
                        cheers.
                        • 5238 loaded and all went smoothly, thanks all for the tips.
                          • MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
                            • Is this firmware appropriate (ok for Australians)? version 6276
                              Volkswagen RNS 510 Firmware Upgrade to version 6276 | my-gti.com
                              2008 Skoda Octavia Elegance TDI 4x4 wagon
                              Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
                              • Originally posted by wfdTamar View Post
                                Unless you have a very new unit with DAB+ I wouldnt use it as you could brick the unit
                                The 5238 on here is probably the latest you should use What version is your unit
                                4120 is Ok and there is no reason to go higher as there are no obvious improvements in 5238
