Firmware updates for RNS510 units in Australia/NZ
This is a sticky topic.
  • It probably will Look back through the thread to see what Mac users have done to get it to work.
    • Hi Guys, I have just upgraded my B Version RNS510 to firmware 5238 (modifed by josi) and it works beautifully. However after running the modified partition version of 3810 I was a little miffed when it reset my partition sizes back to default. Is there any likelyhood of an AU-3 Partition version poping up here anytime soon, or is there a way to make my own modified version (prefer not to)?
      Stuart..
      • You can get it from the rnsfirmware server, if you can't find it I can pm you. It's not linked, you should just be able to work it out from the location of the others. Can browse the directory.
        • Tried but got lost, can you pm me the link pls
          • Just like to pass on my thanks to Kamold for his help today. Firmware 5238 now loaded on my Version A Touareg. Everything works and nothing broken.
            Kind regards
            Stuart.
            • Hi,
              I need some assistance with my unit, I have an RNS510 - 1TO 035 680 B with H04, I'm just in the process of putting new HDD in and want to know what is the correct firmware and where to get it. I was hoping to have RDS as I have it now with my RCD510...is this possible.
              Thanks Simon
              • Originally posted by Sim T5 View Post
                Hi,
                Thanks Simon
                From the first post in this thread the links are there for each version Read it carefully
                • I did download 38xx for the "B" version but this firmware does not have RDS which as far as I'm aware is possible on these units, also this version is a European version which means the DVD gives a region error. I was hoping there was another version around that would fix these issues....
                  • Wait for Kamold to answer He will know. I think RDS is only available with 4xxxx firmware but I could be wrong
                    • RDS is available from 4120 onwards. DVD region can be set with vcds.
                      • will 4120 work with my unit which is a B HW04?
                        • It's the hw radio version which you need to check.
                          • I have already pulled the unit apart, is it possible to get this without the unit being on? or do I need to check in the menu?
                            Thanks Simon
                            • No, you need to get it from the menu
                              • thanks for all the help Kamold, I have put the unit back together with the old drive and made the HDD removable without stripping the unit by folding the two tabs up....seems to be quite secure just with the top screw...when I get the SSD drive later this week I can easily fit it. I have just reloaded the old drive with 3970, 90-5-5 partition. This current drive keeps failing which is why I'm going to a SSD...the HW Radio is 0003
