VCDS (VAG-COM) codes and programmable options for Golf Mk7
  • Originally posted by komoornik View Post
    Can someone help me with 3rd brake light tweaks?
    I did some coding (mostly enabling 3rd brake light when boot is open and also for coming/leaving home).
    I tried to enable it for hazard lights but it now is active while using turn signals too.
    Why would you want the third brake light on when its pointing to the sky
      Komoornik: bummer!! If you used my tweak instructions - then I've received many responses confirming that they work OK.
      There are lots of ways that the tweak could go wrong - perhaps the best way to fix the problem is to post-up the FULL Leuchte-set values on your car at present (by which I mean the complete 19 x adaptation channels for Leuchte22BR MA57). You can either copy-and-paste the channels and their values into a post, or include pictures (probably need 3 x pics)
      Don
      So any tail-gating birds don't crash into the rear of the car!!!
      • Here are the screenshots.
        BTW is there an adaption channel for cornering lights from the main lamps? I have LED TOP installed.
          try changing Lichtfunkion E22 to "not active"
          not sure what you mean by "cornering lights from the main lamps"?
          Don
          • Ok now the 3rd brake light is off. So how to enable the blinking with hazard lights only? I want to keep it on when boot is opened or for coming/leaving home.
            I mean the cornering lights which are turned on when moving a steering wheel (not the fog lights).
              Hi Friend, I have used this modification of XaGiCo to activate 3 light (stop) on my Golf with VCDS.
              I'll put screenshots of the changes if you might find it useful.
              http://italiatrasporti.mastertopforum.com/index.php
              • ^^^^ The logic for this tweak is real odd IMHO - why on God's green earth would you want to switch-on the high mounted brake light when the hatch is open?
                As I understand, when someone opens the hatch, your tweak causes the 3rd brake light to illuminate. This might be useful in stopping a collision by the occasional owl that might be flying close to the vehicle at night ( , just joking) - but how does it benefit either the driver, or the cars at the rear?
                Don
                Don
                • Originally posted by DV52 View Post
                  Don
                  Don
                  I agree its totally weird unless you are parking at the end of the local runway.
                  The usual one is to have normal taillights on when taildoor is open but that leads to accidentally leaving it open and running the battery flat.
                  However whatever floats his boat. Hope his driving habits arent as weird.
                  If it does as he says comes on when turn signals are working it is potentially dangerous
                  • Anyone in sydney who can help me code my abs module on my mk7 golf? I tried plugging a different cluster with same vin but i mistakenly turned the ignition on and it wiped off abs module coding.
                    • Your best bet would be to use dealer tool ODIS online which can restore your coding to factory settings.
                      Sent from my SM-G960F using Tapatalk
                      • Originally posted by Arsalant1 View Post
                        Or if ODIS isn't an option - try looking at a previous auto-scan (VCDS saves these in the sub-directory C:\Ross-Tech\VCDS\Scans)
                        Or if you have previously created an adaptation map of the hex03 module, look in C:\Ross-Tech\VCDS\Logs.
                        Or if you have previously changed long coding in the hex03 module look at the CodingLog.CSV file in C:\Ross-Tech\VCDS\Debug.
                        If you use OBD11 and you previously saved a Back-Up, or you changed long code Byte/Bit in the hex03 module - Look in the History facility
                        Don
                        PS: after restoring the long code string, you will likely need to execute a few Basic setting procedures - as determined by the DTC error messages
                        • I find Odis way more simple and it’s the factory software.
                          • Originally posted by tyr382 View Post
                            But how many of us has access to it. I jokingly asked the tech who was working on my car about a copy of it and he said yeah sure but as soon as you leave here it wont work as it would only work through their connection
                            • VCDS (VAG-COM) codes and programmable options for Golf Mk7
                              **** if I had my computer with me I can just email you a copy and guid ya through installation.
                              First you need VAS tool
                              I think there is a new version VAS6154 but iv never used it.
                              Iv had no issues with the 5054A unit but I think if your going to be using on 2018 and onwards, you will need the newer version.
                              Car Diagnostic Tool VAS 5054A ODIS V4.3.3 /V4.4.10 / V3.0.3 Bluetooth OKI 01 | eBay
                              It comes with a copy but I recommend downloading the most updated.
                              It’s not that complicated to install but I recommend buying a old laptop that uses win7
                              Best thing about ODIS it’s free and you can plug into as many cars as you want.
                              It’s very good for coding and if your using the factory service Manuel, the guided functions are very straight forward.
                              • Theres no way of changing anything like temperature or air recirculation on the climate control through coding is there? As in the user operational controls.
                                Reason being is I had a crazy thought of my android phone detecting when within a certain radius of a tunnel for it to automate the air recirculation on. I've got no problems with the android phone detecting the location and simulating a screen action on the phone (say through the obdeleven app) but I'm not sure any controls can be changed through the odb port can it?
                                I've got my obdeleven and waiting on delivery of my car so it got me thinking in the mean time.
