Franky: Hallo.
If you look at my tweak HERE, you will find a set of instructions for adding the 3rd Brake light to the hazard warning function.
In theory, a similar set of changes should work for including the hazard warning function into the "angel-eyes" (U LED lights) on your Golf R. BUT - I suspect that it's not possible for the following 2 x reasons:
Don
- The LED lights on angel-eye fittings operate differently to the other exterior lamps in that they use 2 x separate Leuchte-sets: one for the lighting functions and a second Leuchte-set for the power-supply to the fittings
- The Leuchte-set for the lighting functions is normally fully subscribed - meaning that there isn't sufficient spare adaptation channels in the Leuchte-set to implement the hazard warning function
Don
