VCDS (VAG-COM) codes and programmable options for Golf Mk7
  • Originally posted by dArK5HaD0w View Post
    interesting......
    might try this on my Suberb, although it won't b much good given the engine start-stop button in the on the steering wheel column itself.
    nonetheless, give it a crack i shall
    success - its subtle, but a nice touch.
    • Originally posted by kamold View Post
      Try setting this adaptation to enabled in 5F infotainment:
      IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B
      ok to me he’s got a low line camera in his car, you gave him options for high line which is kept in the module of the camera (you can change the speed in that module), low line is just basic 12V camera open, 0V camera closed, so although a high line you can use the low line option, the high line you can’t, I can be totally wrong tho
      • Originally posted by marsias View Post
        So far i have figure out the Names, i cant find the names of yellow arrows pointed lamps.(s.Pictures)
        Any help from somebody?
        [ATTACH=CONFIG]47299[/ATTACH][ATTACH=CONFIG]47300[/ATTACH]
        2 and 4 are the brake lights on my uk car which is 20/21 BR LA71/RC8
        3 is empty and when I looked there was no wire down the right side or LED’s in the cluster (ok it was a few years back so my fog could be on the right not left)
        • Closing windows & sun roof with 1 click on key remote
          Hi... someone have this coding for Golf MK7.5 2018..!?
          Thanks.
          YouTube
          • ^^^ Assuming that you use VCDS (not difficult to translate to OBD11 speak), try this:
            1. Go to the hex09 module (BCM)
            2. Enter the magic number 31347 as the security code
            3. Go to Adaptation
            4. Navigate to the channels below and change as appropriate:
            Key-fob operation
            ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen > active
            ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen > active
            Sun-roof operation
            ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen > active
            ENG141632-ENG116646-Sunroof-SAD Komfort schliessen > active
            Kessy operation
            IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen > active
            IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen > active
            Enable comfort open/close facility in MENU in the MFD (so you can turn the feature on or off):
            ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar > adjustable
            Don
            • I have recently purchased a OBDEleven and one of the tweaks I made was the Battery state of charge. I have noticed that whenever I check it , it always shows that the SOC as 0% . Does that mean that my battery is nearly dead or that the 0% reading is inaccurate?
              Sent from my Pixel 2 XL using Tapatalk
              • Are you holding the button down on the key fob? I'm not sure you can just click it.
                2012 MKVI Golf Comfortline 118 TSI
                • Originally posted by gh172 View Post
                  I have recently purchased a OBDEleven and one of the treaks I made was the Battery state of charge. I have noticed that whenever I check it , it always shows that the SOC as 0% . Does that mean that my battery is nearly dead or that the 0% reading is inaccurate?
                  Unless you battery has a module attached to it you cant get that to work.
                  What vehicle is it and look to see where the earth point is on the vehicle If its just a bolt on the firewall as in a Tiguan forget it Have tried several times and hardware is just not there
                  • Originally posted by DV52 View Post
                    3. Go to Adaptation
                    Key-fob operation
                    Sun-roof operation
                    Kessy operation
                    Don
                    Would this also work in a TIguan
                    Have slighty different things on 09 like but none of identical to above
                    Kessy comfort oeffen Not active
                    Kessy comfort shliessen Active
                    Kessy Protokollvariant Entry Exit Not active
                    Kessy Ruephase Entry Exit Not Active
                      ^ ^^^ this is a pic of the Battery monitor module (J367) that is connected to the negative terminal that Hillbilly refers-to (I think). J367 is basically a coil of wire with a few electronic components embedded in a resin housing - it's roll is to measure every ampere of electrical current that flows out-of and into the battery. Without a J367 module SOC can't be calculated. J367 will be installed if your car has start-stop.
                      Don
                      ignore thw yellow gunk - it's an anti-frosting agent that the dealer sprayed onto the negative terminal
                      • Originally posted by Hillbilly View Post
                        Not sure - but try it. The settings can always be reverted back if it doesn't work. And, it might be worth factory reset on the MENU screen (definitely, don't use the factory reset in OBD11/VCDS) after the settings are changed
                        Don
                          Don
                          Yeah realise that. I thought your German may be better than mine LOL
                          There is nothing about key start in there
                            Don
                            Here is the pics of my batteries Neg terminal No little black boxes and the voltage display wont show even after several trys
                            • My mistake I see what you mean now.
                              • Can someone help me with 3rd brake light tweaks?
                                I did some coding (mostly enabling 3rd brake light when boot is open and also for coming/leaving home).
                                I tried to enable it for hazard lights but it now is active while using turn signals too.
