VCDS (VAG-COM) codes and programmable options for Golf Mk7
  • Originally posted by maca View Post
    I feel like an absolute noob with this. I managed to activate the alarm chirp on lock and the DRL control in the vehicle settings, but I can’t seem to deactivate the DRL wink when the turn signals activate.
    maca: Being able to deactivate the DRL wink facility really depends on the module arrangement in your car. In recent model mk7s that have new left and right side LCMs (Light Control Modules) @ address hex29 & hex39, it's not possible to alter much at all on the DRLs.
    Don
    • Hey guys - anybody know if it's possible to change (or more specifically - set) a delay before auto hold kicks in? In the Arteon, pretty much the split second I come to a stop, auto hold engages.
      What I would like to do is have it so say... it only comes on if I've been at a dead stop for 2secs+
      My car: MY18 Arteon
      My car #2: MY22 Volvo XC40 Pure Electric
      Her car: MY22 Skoda Octavia Limited Edition Wagon
      • Auto Hold depends on a brake force, use the pedal gently.
        And it still works much better then in Audi A4 B8 - it tends to jerk because there it activates too quickly.
        • Originally posted by DreamensioN View Post
          Yes, I'd like to change this as well!
          While at it, is it possible to change the Auto Start Stop Engine in the same way?
          On a separate note, it would be amazing if the Driving Mode had a memory. For example, when in Comfort the dash/cluster showed the map with the range and efficiency but when in Sport the dash showed Gear and Speed. Probably too much to ask.
          Arteon & T-Roc
            Dream..: You could try something like this:
            Select ABS Brake module @ address hex03
            Select the adaptation channel Dynamic starting assist
            Select one of the following settings "Early", "Normal" (default) or "Late"
            Don
            • Originally posted by DV52 View Post
              Don
              Thanks for this Don.
              I did try this today but it made no difference to the auto hold. Not that I could tell anyway. To be honest, I'm not even sure if I detected any difference with anything, so I put it back to the default Normal setting.
              My car: MY18 Arteon
              • You can't deactivate start/stop with obd11
                You can get a kufatech module for about 70 bucks that will do it tho
                Have done it on my alltrack works great
                2017 Golf Alltrack 135tdi All options
                • Originally posted by Kachingg View Post
                  If you had OBD11 Pro couldn't you just manually use the long coding to set the start/stop voltage threshold?
                  MY13 Golf GTI DSG (SOLD)| Candy White | 18" Detroits | Bi-Xenon Headlights | Street Guardian SG9665C
                  MY18 Golf R DSG | Indium Grey | 19" Spielbergs | DAP | Sunroof | Viofo A119v2 (front) | BlueSkySea B1W (rear)
                  Micro-CAN VCDS
                  • Do you clean out your VAG before a service? Making it look untouched.
                    What I mean to say, do you reset your code changes before a service at a dealer?
                    Arteon & T-Roc
                    • Originally posted by HiddenTaco View Post
                      I'd love this, it does this for the Infotainment system, but not the active info dash. I guess once more cars get the feature standard we might see it.
                      I'd love to me able to add quick toggles to the DAP button. I usually toggle Adaptive Lane assist on and off, but I rarely completely disable it. I haven't been able to find any lists to modify, but my gf has banned me from OBD11.
                      Good question.
                      I'm thinking I'll undo the cosmetic changes like Fog with DRL and TP and it's right there saying No TP
                      2018 Golf GTI DSG (DAP LUX INFO R-TAILS)
                        I wasn't planning on doing it for the first service.
                        When I had my Golf R, I used to reflash it to the stock mapping before taking it for a service, then would flash back the aftermarket ROM after, then I got lazy and didn't bother changing it at all. Made no difference to the couple of warranty claims I made.
                        My car: MY18 Arteon
                        • Hi guys,I’ve tried searching and couldn’t find anything. I’ve got a mk7.5 110tsi highline Rline wagon. Totally new to this stuff Is it possible with to turn on both DRLs like the gti or golf r?
                          • Hey Guys,
                            Im probably one of the few people that like stop/start but I've found the 'expanded restart function' where the engine will restart if the car in front creeps forward even the slightest distance to be VERY annoying in traffic where people will inch forward even if the car in front of them is stationary.
                            I haven't seen this mentioned on these forums but this can be turned off under ACC module > adaptions > 'expanded restart function' (potentially called 'advanced restart function') > deactivate.
                            2018 Golf 7.5 110TSi Comfortline | Drivers Assistance Package | Retrofitted: Traffic Jam Assist | Emergency Assist II | Light Assist | OEM Vienna Leather Sports Seats with full Highline Interior | Power Folding Mirrors
                            • It’s on the obdeleven forum
                              • Originally posted by Rich86 View Post
                                i think it’s a hardware thing with some lights, but I could be wrong
