VCDS (VAG-COM) codes and programmable options for Golf Mk7
  • Originally posted by DV52 View Post
    As Rainesh correctly advises the facility is enabled/disabled by either:
    For mk7 Golf
    In BCM (@ address hex09)> Coding
    For mk7.5
    In BCM (@ address hex09) > Security Access -enter magic number, 31347 > Adaptation> ENG10579-ENG10924-ZV allgemein-ZV_ohne_Safe_Funktion change to "not installed"
    BUT (and there is always a "but"), the Wiring Diagram for those mk7s that are fitted with "deadlocks" (SAFELOCK) appear to have an additional motor in the door lock unit.
    See pic below:
    So - it's unfortunately more than just a coding change
    Don
    Sorry for the late reply Don.
    Thank you for your answers.
    I own a Passat and I tried to find those settings in the BCM but Failed.
    Neither yours or Rainesh's showing up in my Passat.
    Neal
    • Friends, I have a GTI 2015 Mexican and I am from Brazil, my car when it is stopped the instantaneous consumption of it does not mark the consumption, I have seen that in some cars it is marking the instant consumption per hour. Does anyone know how to empower? type of consumption of 0.8 liters / hour
      • Meu amigo, sou do Brasil e tenho um Golf GTI 2015 mexicano de 220 cv que são os mesmos que vão para o Canadá e os Estados Unidos, tentei de todas as maneiras fazer a configuração através do VCDS 12.12.3 a senha é aceita 20103 Eu posso acessar os canais, mas o erro mensagem de erro na entrada, por favor, digite um byte hexadecimal, por exemplo: FF aparece e eu não posso de forma alguma fazer as alterações. Você tem alguma outra dica? É a versão do cabo?
        • HELP!!! My friend, I am from Brazil and I have a Golf GTI 2015 Mexican 220 hp that are the same ones that go to Canada and the United States, I tried in all ways to make the configuration through VCDS 12.12.3 the password is accepted 20103 I can access the channels , but the error message error in the input, please enter a hexadecimal byte, for example: FF appears and I can not in any way make the changes. Do you have any other tips? Is it the cable version?
            • Originally posted by adrianoemp View Post
              hmm.............. "VCDS 12.12.3" ? Sounds like you might be using software that is well out-of-date, or it sounds suspiciously like you might be using a fake cable. If you don't have a fake cable - update the software to the latest version and if you can't (or won't) update the software, stop participating in IP theft!!
              Don
              • Any chance I could have a copy as well please?
                I've managed to fix all but just can't get the indicators to sweep. :'(
                Also my reverse lights are giving me an error too. :'(
                • I am not sure this issue has been closed or not for STG17 security code which need to modify instruments illumination for after MY16 model.
                  But friend of mine who has MY16 Golf7 found out the security code for STG17 with "47115". If not please tr.
                  • ^^^ Zeal-san: Hi
                    Just tried your friend's security code (47115) on STG17 on my MY18 Audi A3 (MQB platform like mk7 Golf). Alas no joy!!
                    Don
                      ^^^ Zeal-san: Hi
                      Don
                      Oh. I am sorry this security code did not fit your car.... I am not sure this core is effective for MY16 and after but my friend said the core was works on his car.
                      • Hey guys,
                        I’ve played around with my headlight adaptions on OBD11 (and stupidly didn’t make a back up) to code the CH/LH function to use the LED DRLs on my Golf, i then after a while changed the brightness down to 40% of the DRLS in the CH/LH function but when doing this my DRLs stopped working in the headlight off and auto modes (with low beam off). I tried to un-do my changes and now have DRLs back, but they’re running at full brightness in all headlight switch positions and in the CH/LH function. Does anyone know correct coding to have the DRLs dim when the low beam is activated and how to code the DRLs to function at reduced brightness for coming/leaving home?
                        2018 Golf 7.5 110TSi Comfortline | Drivers Assistance Package | Retrofitted: Traffic Jam Assist | Emergency Assist II | Light Assist | OEM Vienna Leather Sports Seats with full Highline Interior | Power Folding Mirrors
                        • OBD11 tracks the changes made to your car in the history. you should be able to just look up the previous values when the changes were made.
                          2018 MY18 Indium Grey VW Golf 110TSI Comfortline, DAP & Infotainment, Folding Mirrors!
                          2023 MY23 Nevada White Cupra Formentor VZx
                          2015 Carnival Yellow Honda S660
                          • I've coded my fog-lights to act the same as my "U" DRLs (lighting package on 2015 Canadian SEL / Highline GSW TDI).
                            So - my fog lights are always on when I'm driving. I think I also coded them to switch OFF if I pull the headlight switch knob outward (the normal "turn on" action).
                            I can live without that, though - I don't think I've used it once in the 2+ years I've had it set up like this.
                            What I'd like to do is code that "pull out" action to turn on rear fog light (which I don't have installed yet - I have the bulb in, but it's just another bulb/light in my rear signal/brake light cluster now.
                            So - once I run the wire from the rear light(s), where does it terminate up front?; and how would (or could?) I code the switch to turn on that rear fog?
                            • Hi everyone,
                              I'm hoping someone (maybe Don if I'm lucky!) will be able to help me with my lights trouble.
                              I've spent a long time browsing through this thread (all 161 pages!) but despite what I can piece together, nothing seems to work.
                              The main issue is the DRLs on my lights are too bright when I have my low beams on. The wrinkle is I have a pair of replica xenons as a retrofit to my originally halogen-equipped car. This is now my second set (sadly I was involved with the ill fated Winpower group buy).
                              As such the new LED U is now mapped to the DRL / parking light function of the H15 bulb in the original halogen cluster.
                              On the previous winpower cluster I had coded the DRL to stay on as a dimmed function when low beam was active, but it didn't seem to translate to the new ones.
                              I know that the DRL is mapped to its own channel because I've managed to restore the DRL wink when indicating, and when you unlock the car the headlights will activate without the DRL/LEDs lighting up. I just can't seem to separate the two!
                              So far I've worked on lichtfunktion G4 and G5 channels corresponding to LB4 and RB32. Here's what I've got set at the moment:
                              If anyone has any suggestions I'd be very grateful!
                              Mk7 GTI | Pure White | 6MT
                              • Does anybody how to change the function of the PTT button on the steering wheel to mute?
