VCDS (VAG-COM) codes and programmable options for Golf Mk7
  • Handbrake enabled DRLs
    It's all in the name! Well...it is for me when it comes to the Daytime Running Lights (DRLs). And the operative word for this neat little safety feature must surely be the term "Running". So here's my question:- why have the DRLs switched on when the car isn't "Running" (i.e. the car isn't actually moving)? Well it appears that the good Burghers in Germany have also considered this question and they have included a facility in the mk7 that allows the Handbrake to speak to the DRLs. What a clever lot they are in Germany!!
    Turn-off DRLs when Handbrake is engaged
    The instructions below describe how to implement a VCDS tweak that automatically turns-off the DRLs when the handbrake is engaged and then switches the DRLs back-on again when the Handbrake is disengaged. Grateful acknowledgement to the Stemei.de site for the original material.
    Before proceeding, please consider any implications from this tweak on the Australian Design Rules and its application to vehicles fitted with DRLs.
    1. Select 09 - Cent Elect. module control
    2. Select Security Access-16
    3. Enter the magic access code. Click Do it! tab
    4. Select Adaptation - 10.
    5. From the pull-down channel, select (5)-Daytime running lights- Tagfshrlicht-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten (it's about 10% down the channel list)
    6. In the New Value box, select active
    7. Click Do it! tab. Click Add to log to save a copy of the change and click Go Back tab
    8. Exit from software
    9. Test the facility by engaging and disengaging the handbrake (notice how the status of the handbrake modulates the operation of the DRLs)
    • Originally posted by DV52 View Post
      [ATTACH=CONFIG]11346[/ATTACH]
      [ATTACH=CONFIG]11347[/ATTACH]
      [ATTACH=CONFIG]11348[/ATTACH]
      [ATTACH=CONFIG]11349[/ATTACH]
      [ATTACH=CONFIG]11350[/ATTACH]
      My sister's Mazda 3 SP25 does this ... was so confused when she was sitting in the driveway and they weren't on! Lol. I like the feature, though.
      MkVII | GTI | Tornado Red | DSG |Bi-Xenon | Panoramic Roof | Vienna Leather | Driver Assist
      • I had a quick search but couldn't find it here. Has anyone looked into optioning the blind spot monitoring? I think it may be called "side assist" or "side view" surly the highline has all items required to make it work, I would imagine the little led on the side mirrors could be used as the warning indicator.
        • Originally posted by Andy2176 View Post
          Andy: not sure that I have understood your question, but the mk7 Golf does have an option called "lane assist" . The advertising material from VW talks about lane-assist in terms of BSM. Is this what you are after? If so, the option requires that a forward view camera is installed (it's part of the rear-view mirror assembly, camera sits under the mirror-looking forward). This is not standard equipment in a Highline.
          • Hi all,
            A while back I posted a problem trying to upgrade my normal MK7 Multifunction steering wheel to one that has tiptronic paddles. it's for a Golf 90TSI DSG comfort line.
            I've tried Ross tech but they haven't been very helpful. I am hoping i have better luck here.
            Summary:
            I recently purchased a new VW OEM MFSW that has tiptronic paddles to replace my standard MSFW.
            My mechanic installed the new MFSW and it seemed to work ok - i can shift gears with the MFSW paddles, and the other buttons seem to work ok.
            However, there are 3 errors
            1) EPC light on
            2) Auto Stop/Start malfunction
            3) Cruise control malfunction
            Below are the scan results, any help will be much appreciated!
            Thanks.
            Code:
            Thursday,17,July,2014,16:26:57:23272
            VCDS -- Windows Based VAG/VAS Emulator
            VCDS Version: 12.12.2.0
            Data version: 20140212
            Dealer/Shop Name: Beyond Limit Autos
            VIN:   License Plate:
            Chassis Type: AU (5Q0)
            Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
            VIN:
            01-Engine -- Status: Malfunction 0010
            02-Auto Trans -- Status: OK 0000
            03-ABS Brakes -- Status: OK 0000
            08-Auto HVAC -- Status: Malfunction 0010
            09-Cent. Elect. -- Status: Malfunction 0010
            10-Park/Steer Assist -- Status: OK 0000
            15-Airbags -- Status: OK 0000
            16-Steering wheel -- Status: OK 0000
            17-Instruments -- Status: OK 0000
            19-CAN Gateway -- Status: OK 0000
            42-Door Elect, Driver -- Status: OK 0000
            44-Steering Assist -- Status: OK 0000
            52-Door Elect, Pass. -- Status: OK 0000
            5F-Information Electr. -- Status: OK 0000
            Address 01: Engine (J623-CXSA)       Labels: 04E-907-309-V1.clb
               Part No SW: 04E 906 016 DF    HW: 04E 907 309 A
               Component: 1.4l R4 TSI   H08 5673
               Revision: WAH08---
               Coding: 01250032242405082000
               Shop #: WSC 01357 011 00200
               ASAM Dataset: EV_ECM14TFS01104E906016DF 002002
               ROD: EV_ECM14TFS01104E906016DF_VW37.rod
               VCID: 69D2115F88230A562C9-803C
            1 Fault Found:
            17149 - Check Coding of ECUs on Powertrain Data Bus
                      P1647 00 [175] - -
                      MIL ON - Confirmed - Tested Since Memory Clear
                         Freeze Frame:
                                Fault Status: 00000001
                                Fault Priority: 2
                                Fault Frequency: 14
                                Mileage: 2130 km
                                Date: 2014.07.14
                                Time: 12:16:54
            Readiness: 0000 0001
            Address 02: Auto Trans (J743)       Labels: 0CW-927-769.clb
               Part No SW: 0CW 300 046 A    HW: 0AM 927 769 K
               Component: GSG DQ200-MQB H43 5113
               Revision: 00043014    Serial number: CU501311195247
               Coding: 0014
               ASAM Dataset: EV_TCMDQ200021 001001
               ROD: EV_TCMDQ200021_AU37.rod
               VCID: 3874841B830963DE637-806D
            No fault code found.
            Address 08: Auto HVAC (J255)       Labels: 5G0-907-044.clb
               Part No SW: 5G0 907 044 T    HW: 5G0 907 044 T
               Component: Climatronic   H02 0805
               Revision: 00001K06
               Coding: 00120004200100001005000012101800
               ASAM Dataset: EV_ACClimaBHBVW37X 003018
               ROD: EV_ACClimaBHBVW37X_SE37.rod
               Fresh Air Blower Front:
               Refrigerant Pressure And Temperature Sender:
               Air quality sensor:
            1 Fault Found:
            590081 - Control Circuit for A/C Compressor
                      B10A9 11 [008] - Short to Ground
                      Intermittent - Confirmed - Tested Since Memory Clear
                         Freeze Frame:
                                Fault Priority: 2
                                Fault Frequency: 1
                                Reset counter: 220
                                Mileage: 2024 km
                                Date: 2014.07.11
                                Time: 15:27:49
            Address 09: Cent. Elect. (J519)       Labels: None
               Part No SW: 5Q0 937 084 AB    HW: 5Q0 937 084 AB
               Component: BCM MQBAB B   H16 0124
               Serial number: 00011334600061
               Coding: 03001842C24102F34BE44000000403081000000000000000000000000000
               ASAM Dataset: EV_BCMCONTI 012001
               ROD: EV_BCMBOSCH_SE37.rod
               VCID: 78F4441BC389A3DEA37-802D
               Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A
               Component: WWS    131207  042 0551
               Serial number:         131210032723
               Coding: 0E4DDD
               Subsystem 2 - Part No SW: 5Q0 955 547     HW: 5Q0 955 547   Labels: 5Q0-955-547.CLB
               Component: RLFS  024 0042
               Serial number: Y13M12D17H11M42S21S9
               Coding: 00A8DD
            1 Fault Found:
            395273 - Control Circuit for Signal Horn
                      B1344 14 [008] - Open or Short to Ground
                         Freeze Frame:
                                Fault Priority: 2
                                Fault Frequency: 1
                                Reset counter: 229
                                Mileage: 2129 km
                                Date: 2014.07.14
                                Time: 11:52:59
            Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
               Part No SW: 5Q0 919 294 F    HW: 5Q0 919 294 A
               Component: PARKHILFE 8K  H03 0142
               Revision: --------    Serial number: 39331335202967
               Coding: 0031151011
               ASAM Dataset: EV_EPHVA18AU3700000 002024
               ROD: EV_EPHVA18AU3700000_VW37.rod
               VCID: 3E789203A12D5DEEA9B-806B
            Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
               Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
               Component: Lenks.Modul   075 0135
               Revision: FF027027    Serial number: 20131207500154
               Coding: 0410
               ASAM Dataset: EV_SMLSVALEOMQB 001015
               ROD: N/A
               VCID: 3F86EF07A62754E6A2D-806A
            No ASAM data for: "EV_SMLSVALEOMQB" (VW37)
            Address 17: Instruments (J285)       Labels: 5G0-920-XXX-17.clb
               Part No SW: 5G0 920 861     HW: 5G0 920 861
               Component: KOMBI         252 2210
               Coding: 27A419082380000800082A00040000
               ASAM Dataset: EV_DashBoardVDDMQBAB 008031
               ROD: EV_DashBoardVDDMQBAB_AU37.rod
               VCID: E6C89A63193DA52E81B-80B3
            Address 19: CAN Gateway (J533)       Labels: None
               Part No SW: 5Q0 907 530 P    HW: 5Q0 907 530 E
               Component: GW MQB Mid    124 1164
               Revision: --------    Serial number: 0001355699
               Coding: 030100342B085700EF0002481C0F00010001000000000000000000000000
               ASAM Dataset: EV_GatewLear 010015
               ROD: EV_GatewLear_AU37.rod
               Alternator:
               Multifunction unit control module:
               Subsystem 2 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K
               Component: E221__MFL-DC1  H14 0035
               Serial number: 27130001231250063315
               Coding: 2DFFFF
               Battery Monitoring Control Module:
               Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
               Component: J367-BDMHella  H03 8043
               Serial number: 2415092103
            Address 42: Door Elect, Driver (J386)       Labels: None
               Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
               Component: TSG FS        020 0025
               Serial number: 03121302090098
               Coding: 003003208001040000000000
               ASAM Dataset: EV_DCUDriveSideEWMINKLO 006003
               ROD: EV_DCUDriveSideEWMAXKLO.rod
               Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
               Component: FOND_FHSG_DRV  005 0005
               Serial number: 00000000000001343624
               Coding: 1D0000
            Address 44: Steering Assist (J500)       Labels: 5Q0-909-144.clb
               Part No SW: 5Q0 909 144 P    HW: 5Q0 909 144 P
               Component: EPS_MQB_ZFLS  122 1043
               Coding: 0103
               ASAM Dataset: EV_SteerAssisMQB 010031
               ROD: EV_SteerAssisMQB.rod
               VCID: 4182E9FFD0D32216D49-8014
            Address 5F: Information Electr. (J794)       Labels: None
               Part No SW: 5G0 035 824 A    HW: 5G0 035 824 A
               Component: MU-S--ER      040 0421
               Serial number: V1E01412131694
               Coding: 02730000FF00000011510001000900001F0100960100010001
               ASAM Dataset: EV_MUStd4CPASE 002039
               ROD: EV_MUStd4CPASE_SE37.rod
               VCID: 234E43772A8F1006A65-8076
               Media Player Position 1:
               Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
               Component: ABT_Std_Radio  H51 0022
               Serial number: VWZ8Z9NJ702UNM
            End   ---------------------------------------------------------------------
            • I posted this in the ECU section but didn't get any help, hopefully I can here;
              I'm looking for someone in the Newcastle/Sydney area with a VCDS cable. I have a GTI PP and want to activate the Traffic alert system.
              Any help appreciated. Happy to compensate people for their time.
              • Originally posted by turtle View Post
                When did you get yours? Surprised it isn't on by default! Mine works (first batch of cars in VIC).
                Mk 7 GTI PP
                • Originally posted by n0d3 View Post
                  Well to be honest, it might actually be activated and I just don't know. I don't live in a capital city (Newcastle) and I believe that traffic alerts only work in capital cities, so I've never had a chance to try it, I'm just assuming it doens't going off what other people on here have said and what the dealer told me.
                  It has been deactivated in the setting menu, however its easy to go in and tick the boxes (enable RDS, enable Traffic Alerts).
                    turtle: are you really sure that you don't have TMC activated? What year was your car built? Have you tried enabling "TP" and "RDS" on the radio menu and then waiting a little while to see if the list appears when you press the "TRAFFIC" button (you should also get triangles on the navigation screen)? And yes, you have to be in one of the Australian Capital cities for it to work.
                      DV52,
                      Because I don't live in a capital city, and haven't driven in one with the car yet, maybe it does work and I just don't know it yet. I know how to enable 'TP' and 'RDS'. I'll try it next time I travel to Sydney. My car is a MY14
                      Thanks for the input guys. Appreciate the help
                        .....And yes, you have to be in one of the Australian Capital cities for it to work.
                        ....or The Gold Coast — Australia's 6th biggest city.
                        • Originally posted by slashj View Post
                          Hi all,
                          Summary:
                          1) EPC light on
                          Thanks.
                          Code:
                          VIN:   License Plate:
                          VIN:
                             Revision: WAH08---
                          1 Fault Found:
                                    P1647 00 [175] - -
                                       Freeze Frame:
                                              Fault Priority: 2
                                              Fault Frequency: 14
                                              Mileage: 2130 km
                                              Date: 2014.07.14
                                              Time: 12:16:54
                             Coding: 0014
                             Revision: 00001K06
                             Air quality sensor:
                          1 Fault Found:
                                       Freeze Frame:
                                              Fault Priority: 2
                                              Fault Frequency: 1
                                              Reset counter: 220
                                              Mileage: 2024 km
                                              Date: 2014.07.11
                                              Time: 15:27:49
                             Coding: 0E4DDD
                             Coding: 00A8DD
                          1 Fault Found:
                                       Freeze Frame:
                                              Fault Priority: 2
                                              Fault Frequency: 1
                                              Reset counter: 229
                                              Mileage: 2129 km
                                              Date: 2014.07.14
                                              Time: 11:52:59
                             Coding: 0031151011
                             Coding: 0410
                             ROD: N/A
                             Alternator:
                             Coding: 2DFFFF
                             Coding: 1D0000
                             Coding: 0103
                          I'm just having a quick look from my phone but it looks like the kilometers that the fault happened are logged with the fault. What km was the car at when you got the new part fitted?
                          Have you tried clearing and see if they come back?
                          • Originally posted by flight View Post
                            Flight: point well made! I keep forgetting about Gold Coast - not sure why.
                            • Does anyone know if there's a coding to allow the windows and roof to continue closing after the key is removed and a door is opened? It's a drag to have to wait till everything is closed before leaving.
                              Greg
                              MY14 Golf Wagon Highline 1.4L TSI 103, Limestone Grey Metallic, Roof, Leather, DAC.
                              • Wouldn't just holding the lock button achieve the same result?
