VCDS (VAG-COM) codes and programmable options for Golf Mk7
  • Code:
    Address 01: Engine (J623-CZEA)       Labels: 04E-907-309-V1.clb
       Part No SW: 04E 906 027 HF    HW: 04E 907 309 BJ
       Component: R4 1.4l TFS   H22 2326
       Revision: R6H22---
       Coding: 0119003223441D082000
       Shop #: WSC 01357 011 00200
       ASAM Dataset: EV_ECM14TFS01104E906027HF 001004
       ROD: EV_ECM14TFS01104E906027HF.rod
       VCID: 6FC33DBAB624AD46B4-803A
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
       Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
       Component: ESC           H42 0623
       Revision: 00000000    Serial number: 61735000000178
       Coding: 01FA8AA1242429750779060641CC2980512494E0608294F314205078C002
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
       ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
       VCID: 79D703E2F860F3F61A-802C
    Address 08: Auto HVAC (J255)       Labels: 5G0-907-044.clb
       Part No SW: 5G0 907 044 BC    HW: 5G0 907 044 BC
       Component: Climatronic   H03 1001
       Revision: 00001K08
       Coding: 00120004100100011005004000101002
       ASAM Dataset: EV_ACClimaBHBVW37X 004131
       ROD: EV_ACClimaBHBVW37X_SK37.rod
       VCID: 69F753A288C04376EA-803C
    Address 09: Cent. Elect. (J519)       Labels: None
       Part No SW: 5Q0 937 084 AQ    HW: 5Q0 937 084 AL
       Component: BCM MQBAB M   H24 0173
       Serial number: 01061517400714
       Coding: 03000842C24102FB0BA44080B10403281000000000000000000000000000
       ASAM Dataset: EV_BCMMQB 015001
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: 0733751ABE9495061C-8052
       Slave 1:
       Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A  Labels: 5QX-955-119-V1.CLB
       Component: WWS    150613  042 0551
       Serial number:         150621004624
       Coding: 0E4DDD
       Slave 2:
       Subsystem 2 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: 5Q0-955-547.CLB
       Component: RLHS  037 0059
       Serial number: S5Y15M07D01H11M02S40
       Coding: 96A8DD
       Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
       Component: Sensor, DWA  006 0326
       Serial number: 000000000ZY151530JPD
       Subsystem 4 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
       Component: Sirene, DWA  004 0311
       Serial number: 00000000000062798780
    Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
       Part No SW: 5Q0 919 294 K    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0054
       Revision: --------    Serial number: 39331518005881
       Coding: 0071051001
       ASAM Dataset: EV_EPHVA18AU3700000 002026
       ROD: EV_EPHVA18AU3700000_SK48.rod
       VCID: 43ABA10ACA2C792600-8016
    Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
       Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
       Component: ACC Bosch MQB H05 0400
       Serial number: 27051503210263
       Coding: 00000300FE0739
       ASAM Dataset: EV_ACCMRRBoschVW372 001016
       ROD: EV_ACCMRRBoschVW372_AU37.rod
       VCID: 3A55DCEEBDE638EE53-806E
    Address 15: Airbags (J234)       Labels: 5Q0-959-655.clb
       Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
       Component: AirbagVW20    015 0388
       Serial number: 003MLR0W7H77
       Coding: 98CCC000000000005C0000CF00C800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
       ROD: EV_AirbaVW20SMEVW37X_AU37.rod
       VCID: 7F23EDFAE644DDC624-802A
       Seat belt tensioner; left:
       Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
       Component: BeltPretRevFL  H36 0350
       Serial number: 34169677B29061571106
       Coding: 333135
       Seat belt tensioner; right:
       Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
       Component: BeltPretRevFR  H36 0350
       Serial number: 34169676B30061510105
       Coding: 333135
       Crash sensor for side airbag; driver side:
       Subsystem 3 - Part No SW: -----------    HW: 480 002 606 15
       Component: SideSensor_Df  001 0887
       Serial number: 35767000000DDA40C41%
       Coding: 2D2D2D
       Crash sensor for side airbag; front passenger side:
       Subsystem 4 - Part No SW: -----------    HW: 480 002 506 15
       Component: SideSensor_Pf  001 0887
       Serial number: 3586700000020749841L
       Coding: 2D2D2D
       Crash sensor for side airbag; rear; driver side:
       Subsystem 5 - Part No SW: -----------    HW: 480 402 306 15
       Component: SideSensor_Dr  001 6149
       Serial number: 35165029B1C52F3490CJ
       Coding: 2D2D2D
       Crash sensor for side airbag; rear; passenger side:
       Subsystem 6 - Part No SW: -----------    HW: 480 402 206 15
       Component: SideSensor_Pr  001 6149
       Serial number: 3526502A31B5A884914B
       Coding: 2D2D2D
       Crash sensor for front airbag; driver side:
       Subsystem 7 - Part No SW: -----------    HW: 480 402 306 15
       Component: FrontSensor_D  001 6149
       Serial number: 3556502C91C52F35C26O
       Coding: 2D2D2D
    Address 16: Steering wheel (J527)       Labels: 5Q0-953-549.clb
       Part No SW: 5Q0 953 507 GK    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0110
       Revision: --------    Serial number: 26061504400352
       Coding: 0C00
       ASAM Dataset: EV_SMLSKLOMQB 017001
       ROD: EV_SMLSKLOMQB_SE37.rod
       VCID: 052F7F12849887166E-8050
    Address 17: Instruments (J285)       Labels: 5G0-920-XXX-17.clb
       Part No SW: 5G1 920 940 A    HW: 5G1 920 940 A
       Component: KOMBI         202 6420
       Coding: 27A519002780260001886A011400000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009046
       ROD: EV_DashBoardVDDMQBAB_AU37.rod
       VCID: 266D189E595EAC0E07-8072
    Address 19: CAN Gateway (J533)       Labels: 5Q0-907-530-V1.clb
       Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1223
       Revision: --------    Serial number: 0003661951
       Coding: 030100043F085700FB00025C080F00010001050000000000000000000000
       ASAM Dataset: EV_GatewLear 013020
       ROD: EV_GatewLear.rod
       VCID: 75CF0FD2D47897967E-8020
       Alternator:
       Multifunction unit control module:
       Subsystem 2 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K
       Component: E221__MFL-DC1  H16 0040
       Serial number: 29150001361390025267
       Coding: 2CFFFF
       Battery Monitoring Control Module:
       Subsystem 3 - Part No SW: 5Q0 915 181 G    HW: 5Q0 915 181 G
       Component: J367-BDMHella  H04 8050
       Serial number: 3568387103
    Address 42: Door Elect, Driver (J386)       Labels: 5QX-959-X93-42.clb
       Part No SW: 5Q0 959 593 E    HW: 5Q0 959 593 B
       Component: TSG FS        020 0041
       Serial number: 240615BFN16549
       Coding: 003B0220D001048000001000
       ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
       ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
       Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812
       Component: FOND_FHSG_DRV  005 0005
       Serial number: 00000000000006623359
       Coding: 0D0000
    Address 44: Steering Assist (J500)       Labels: 5Q0-909-144.clb
       Part No SW: 5Q0 909 144 R    HW: 5Q0 909 144 R
       Component: EPS_MQB_ZFLS  125 1061
       Coding: 8103
       ASAM Dataset: EV_SteerAssisMQB 012140
       ROD: EV_SteerAssisMQB.rod
    Address 52: Door Elect, Pass. (J387)       Labels: 5QX-959-X92-52.clb
       Part No SW: 5Q0 959 592 E    HW: 5Q0 959 592 B
       Component: TSG BFS       020 0041
       Serial number: 170615BFG06812
       Coding: 003B0020DE01048000801000
       ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
       ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
       VCID: 42A5A40ED536702E0B-8016
       Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811
       Component: FOND_FHSG_PSG  005 0005
       Serial number: 00000000000006536680
       Coding: 150000
    Address 5F: Information Electr. (J794)       Labels: None
       Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
       Component: MU-S-ND-ER    820 0611
       Serial number:
       Coding: 02730001FF00000051111101008808001F0100C601200100CF
       ASAM Dataset: EV_MUStd4CDELP 001001
       ROD: EV_MUStd4CDELP_VW26.rod
       VCID: 3041FEC66B9AF2BEED-8064
       Media Player Position 1:
       Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
       Component: ABT_Std-2_Nav  H43 4060
       Serial number: VWZ6Z9R1810374
       Engine Control Module 2:
       Subsystem 2 - Part No SW: 3G0 919 866 H    HW: -----------
       Component: ECE 2015/16  --- 0430
       Serial number: --------------------
    End-------------------------(Elapsed Time: 03:26)--------------------------
    While I am at it here is the link to the controller map for 5F information electronics (too big for post!) any chance someone with app connect enabled could do the same so we can compare!
    • Not sure if this is the right place but randomly the auto open/close on the drivers side window does not function, where you press the button down and the window winds the whole way down?
      I made some VCDS tweaks, like auto rain closing etc, just wondering if there is a way to reset everything to defaults to check nothing is messing with the window auto close/open?
      • Originally posted by jonoz View Post
        Jonoz, I have the same issue, but up to this point, have attributed it to the way the driver side button is tucked away in an awkward corner, and I just can't get a proper deep press in to trigger the auto open/close function.
        What year model is yours? Mine is MY15.
        Golf MK7 103TSI Highline Wagon | Limestone Grey | DAP2
        Golf MK7 110TDI Highline Hatchback | Tungsten Silver | DAP
        • Originally posted by agentthumb View Post
          Yeah MY15, I definitely feel it doing the deep press but it just dosent do anything both open and close.
          • Interesting. Have you got a scan of your driver side electric? Would be good to compare ours against a MY14 or 13 car just to see if the hardware and software changed.
            Here's mine:
            Code:
               Part No SW: 5Q4 959 593 C    HW: 5Q4 959 593 B
               Component: TSG FS        009 0015
               Serial number: 0000140235596
               Coding: 003A03208001028000000000
               Shop #: WSC 00028 028 00067
               ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
               VCID: 45AFA0CAC4D9D21626-8011
               Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
               Component: Fond FHSG DRV  007 0002
               Serial number: 00000000000000974756
               Coding: 0D0000
              1. Originally posted by jonoz View Post
                Jonoz: Hi.
                Intermittent faults are a bitch to find and fix, but you might try the following:
                1. Check if convenience opening and closing is set correctly
                1. Press the CAR button on the RH side of the Discover media Unit
                2. Press the set-up panel on the bottom RH side of the screen
                3. Press the Opening and Closing panel
                4. Make sure that the settings for Convenience opening option is set to All windows
                5. Exit the screen
              2. Check the codinglog.txt file on your laptop. This will enable you to validate the VCDS tweak changes that you have already (please don't be offended-I'm not suggesting that they were incorrectly made). If you are not aware of how to do this, I wrote a short primer on the process which you can find HERE
              3. Reset
              As for your question about how to reset everything, you can reset the MENU functions in the car using the following process:
              3. Select Factory Setting panel (it's the very last entry on the list)
              4. On the Factory Setting screen, select Reset all Settings
              5. Press the Reset panel
              However, If your question was about how to reset the tweak changes that you previously made, you can use the information in the Codinglog.txt file to roll-back any modified coding, or adaptation channels.
              Cheers and good luck
              Don
              PS: As I write in my paper, the codinglog.txt file can be a bit confusing if you have made lots of changes. If you post-up a copy where it can be downloaded, I'm sure that someone here will parse the data for you so that it is more readable
              • Originally posted by DV52 View Post
                1. Jonoz: Hi.
                  4. Place a tick in the Automatic closing in rain panel as shown in the picture below.
                  5. Make sure that the settings for Convenience opening option is set to All windows
                  6. Exit the screen
                3. Reset
                Don
                PS: the codinglog.txt file can be a bit confusing if you have made lots of changes. If you post-up a copy where it can be downloaded, I'm sure that someone here will parse the data for you so that it is more readable
                Ah thats it! The reset settings option, might do that and see how I go.
                Pretty sure I dont have the laptop I made the coding changes on anymore unfortunately [emoji26]
                  This is easy to fix and has nothing to do with VCDS. Simply hold the button down and wait till the window rolls down completely. Not roll the window up all the way in one go. Now one touch opening and closing should work fine.
                  Sucnip
                  • Originally posted by sucnip View Post
                    Sucnip
                    Ill give it a shot! Funny thing is the settings don't seem to do anything as if I set Conven. Opening to Off all the other windows still auto open.
                    • Originally posted by Bizmo View Post
                      Bizmo: Sorry to read that your troubles continue.
                      But not sure that comparing auto-scan reports will add much value in solving your problem. Here is the auto scan report for address Hex17 from an aussie MY16 TSI Highline (thanks chendo)
                      Part No SW: 5G1 920 740 A HW: 5G1 920 740 A
                      Component: KOMBI 207 7640
                      Coding: 27A419182F98000800886A095400000000000000
                      ASAM Dataset: EV_DashBoardJCIMQBAB 009005
                      ROD: EV_DashBoardJCIMQBAB_SK37.rod
                      VCID: 244C2BA02F2A581E11-8070
                      For reference, your same control module report was:
                      The instrument control module in my car is a 5G0 series and yours is the 5G1 series.
                      I know that the security code works on 5G0 modules. And, a few pages back in this thread, agentthumb implemented the tweak and he didn't report a security code error. Agentthumb's control module details for address Hex17 are ;SW:5G1-920-740 HW:5G1-920-740. This suggests that the security code does work on series 5G1 modules
                      cheers
                      Don
                      PS: Thanks also for the Hex5F information. It was good to be able to compare your adaptation map for the new generation infotainment unit with it's Australian counterpart. VW's new MIBII certainly looks like a very impressive beast! It seems to be functionally rich where apps are concerned and very "hot-spot/WAN" friendly
                      • Hi All,
                        I bought the Ross Tech cable and have enabled a few of the tweaks listed on this site. I would like to enable the Traffic Information, however both of the posts linked in the tweak reference thread refer to changing the default value of 0 to 1024. But my default value isn't 0, it is a 5 digit number, something like 16652. So I am hesitant to change it to 1024 as it doesn't match what other have seen, I wonder if this is a MY16 change as my car has the newer infotainment system.
                        When I am on the Nav screen there is a TP at the top, but when I press the traffic button there are no reports and TMC has a line through it. I assume this means traffic isn't enabled.
                        Am I safe to change the 16652 to 1024 and see what happens?
                        2010 MY10 Golf R (Sold) - 5 Door, DSG, Rising Blue, Leather, ACC, Satnav, Dynadio, Sunroof, MDI, Electric Seat.
                        2015 MY16 Golf GTI - 5 Door, DSG, Carbon Grey, Leather, Sunroof, DAP.
                        • VCDS (VAG-COM) codes and programmable options for Golf Mk7
                          Originally posted by HPSOV View Post
                          Hi All,
                          Yes. My MY15 had 16652 as well. Worst case you can just change it back.
                            cheers
                            Don
                            Hmm thanks anyway, will keep trying!
                            I was supplying the 5F coding, for a completly different tweak, sorry didn't make it very clear! I was wondering if it was possible to enable app connect via VCDS. I understand that the 5F module is difficult for VCDS to read for some reason and that's why it hasn't got the label files.
                            EDIT: On further examination in the mib2 menu by pressing and holding menu it would appear that the app connect is a software update like the voice control
                            • Electric Parking Brake (EPB)- Open/close procedure for Pad Replacement
                              Just a heads-up that Ross-Tech have published a process for closing/opening the callipers on EPB versions of the mk7. Handy if you are contemplating the removal/replacement of the rear pads.
                              The link to the Ross-tech wiki-page is HERE
                              Don
                              PS: I was asked to try out the procedure on my RoW vehicle before publication and I can vouch that it works perfectly on our Aussie cars!
                              • I'm trying to activate the TMS function in my daughters MY15 Golf Comfortline. I get the drop down menu for it in control module 5F and after clicking Adaption. When I select it the stored value window has "ERROR function not available" in it and I can't type 1024 as the new value.
                                Any ideas?
                                GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
