VCDS (VAG-COM) codes and programmable options for Golf Mk7
  • Originally posted by agentthumb View Post
    Don, I think what Brian is trying to achieve is to have the DRLs switch off automatically when the low beam lights are on. The DRLs act as position lamps when the rotary dial is in that position, dimming DRL to I think 20-30, this is the same for when the low beams are turned on (at least this is what I observed on both the MY14 and MY15 model Golfs)
    Brian, you can do this by programming Leuchte4TF LLB4-Lasstyp 4 (LEFT) and Leuchte5TFL R832-Lastyp 5 (RIGHT) Leuchte adaptation groups (which are your DRL lamps). What you will need to do is identify a free channel-subset (i believe set A & B are used by default for the DRL function, C & D are used for position light, E & F are for parking light) so your best bet is probably channel-subset G & H.
    I'm at work and can't check on my car, so make sure the channel-subset is free before continuing.
    What you will need to do is for programmable function G of each of your DRLs, set the value to:
    Leuchte4TFL LB4-Lasstyp 4 (Left DRL)
    Set function G 4 to: Abblendlicht links (left dipped beam)
    Leave function H as: not active
    Set GH Dimmwert to: 0
    Set Dimming Direction GH to: Minimise
    Leuchte5TFL RB32-Lastyp 5 (Right DRL)
    Set function G to: Abblendlicht rechts (right dipped beam)
    This will turn off your DRL lamps when the low beams are switched on.
    Refer to Don's guide of Leuchte programming if you are not sure what I'm on about: https://www.dropbox.com/s/74b00lkimj...n_5_2.pdf?dl=0
    Let me know if you want me to explain further.
    Agentthumb: Well done! Now that I read Brian's post again, I see that you are correct in your interpretation.
    OK, the reason why I didn't get Brian's question correct was that on my Incandescent headlight mk7, the DRLs do turn-off when the low beams turn-on. But, on reviewing my latest BCM adaptation spreadsheet, I can see that some models do have the DRLs on when the low beam light is switched-on.
    Whilst I reckon your suggestion is well worth a try, the other way to achieve the same outcome is to find:
    1. Abblendlicht links setting in 4 TFL LB4 (left DRL) Leuchte channel set, and
    2. Abblendlicht rechts setting in 5 TFL RB32 (Right DRL) Leuchte channel set
    and change these two adaptation channels to not active
    Don
      Don, quick questions
      1. What are the adaptation channel-sets 10 & 11 (remote lights shutter Front left / right) for; or what are these shutters?
      2. Under permissible Alpha channel settings, what are ID 61 and 62 (Flashing left / right active)? Are they referring to the indicators?
      3. Also under the permissible Alpha channel settings, is ID64 (Active flashing function...) referring to the mechanism that triggers the emergency brake signal?
      Agentthumb: Hi again
      Channel-sets 10 & 11 (remote lights shutter Front left /right) are used to operate the "shutter" in certain types of Xenon fittings. These fittings usually have a single Discharge envelope (lamp) that is used for both Low beam and high beam. When used in High beam mode, a "shutter" is electrically operated and placed in a position to give the correct cut-off characteristics. Leuchte channels 10 and 11 provide the initiating signal for the shutter electrics
      ID 61 - Blinken links aktiv (beide Phasen) and ID 62 - Blinken rechts aktiv (beide Phasen) are the commands that create the "Wink". DRL wink is when the DRL goes-off on the side that the blinker operates. DRL wink is meant to accentuate the blinker. So ID 61 & ID 62 when used in a Leuchte channel sub-set is normally associated with a Dimmwert value of "0" and a dimming direction value of "minimise" (causing the DRL to turn-off when the turn signal is operating)
      I've not played with ID 64, so I'm not sure how this works - Happy to receive feedback if you find-out any information on this setting
      Don
      • Originally posted by DV52 View Post
        Don
        Thanks for clearing that up Don. I'll let you know if I find anything.
        Golf MK7 103TSI Highline Wagon | Limestone Grey | DAP2
        Golf MK7 110TDI Highline Hatchback | Tungsten Silver | DAP
        • Hi Don & agentthumb,
          Thanks very much for the hints!!
          I'll give it a try this weekend and let you guys know the result.
          The reason I'm asking this setup is I'm also purchased one of the OEM HID headlight from China, but after few around of replacement and money wasted on shipping, the outcome was getting the dimmer DRL on the LEFT when Low beam are on, DRL on the RIGHT are ok.
          And when low beams are off only DRLs are running, the brightness on both DRL are ok....... So, that's where my question came from~~
          Brian Tien
          • Originally posted by chihbriantien View Post
            Brian Tien
            Let me put take an image which should be much clear!! The LEFT DRL(Red circle) is usually run dimmer when Low Beam is on, and sometimes even worst like flashing or even not glow, but when I turn off the Low Beam or running under day light with DRL only, there's no much difference in brightness!!
            Brian Tien
              Brian Tien
              Brian, what you actually need to do then if make sure when you look at the two adaptation channels for your DRLs that the dim value for both left and right are the same (for when low beams are on). It would be functions C&D or E&F.
              If the values are already the same, then the lights you have bought aren't interpreting them correctly. You will just have to pick a value to match both sides by trial and error.
              • Hi agentthumb,
                I have already checked the dim value for both are the same, but I've never try to change the value.
                I have another question before testing to change the value, please have look below:
                The DRL have two part 1 & 2, part 1 is the while dot LED which has the dimmer issue, part 2 is the U sharp LED which works no issue.
                So, is that possible that I can only adjust the dim value for part 1?
                I have already replace two sets of this OEM headlight, the first set the part 1 on the LEFT don't even glow! And every time I make a replacement of the light sets I have to paid one way shipping fee, which is quite a lot.... Just to hope I can make a workaround instead of continue paying the shipping....
                Anyway, many thanks for your help!!
                Brian Tien
                  Hi agentthumb,
                  Brian Tien
                  Hey Brian, unfortunately I will have to defer this question to Don. I don't have HID on mine, so not sure if they can be programmed separately.
                    Hi agentthumb,
                    Brian Tien
                    Brian, Hi again!
                    OK, that's real weird behaviour indeed. I'm not sure about you fault but I suspect that there is an issue with the wiring/light assembly. As I have outlined in my Leuchte programming paper, the mk7 controls up to 35 exterior lamps. There are (as far as I know) only two direct channels that control the physical DRL lamp positions; the left DRL is allocated to Leuchte4TFL LB4 and the right DRL is allocated to Leuchte5TFL RB32. So, the "U" shaped lights in your picture (these are called "angel-eyes") should be driven by the same Leuchte channel-set as the inner DRLs - dots.
                    Two questions might clarify things (maybe)
                    First, I assume that the each HID assembly that arrived from China had the typical 14 pin connector, whereas the connector on your car would have been a 10 pin connector (I assume that you had Halogen lamps factory fitted). Did you make-up a loom to match the two and if so, have you re-checked that the cross-over wiring is correct?
                    Second: Did you make any changes to any Leuchte channels to accommodate the new LED lamps (i.e. to channel (1))?
                    Lastly, have you created a Adaptation map for the BCM on your car?
                    Don
                    • Has anyone managed to get auto rain close working on a MY15? Tried it twice yesterday, no joy. Worked fine on the MY13.
                        Instrument Cluster Illumination
                        Hey Don, quick question, does this work with the rotary switch in the Auto position as well?
                        Never had the need for this until I had my car tinted. The default values seemed to work fine with the amount of natural light in the cabin without tinting, but as soon as I had my car tinted, I started having trouble reading the dash when the sun is shining from the side or back of the car. Thinking of using this tweak to alter the curve to have the cluster illuminated earlier.
                          Agentthumb: Hi. Short answer to your question is -YES.
                          The control mechanism is the photo-transistor that is embedded into the instrument cluster. I suspect that it's the response from this transistor that has made your cluster illumination drop with the window tinting.
                          So, with my tweak, the cluster illumination is entirely dependent on the prevailing light level in the cabin- regardless of the rotary light switch position. This said, having the rotary switch on Auto will affect what happens to the cluster illumination at low light levels (in a good way - I think). With the rotary switch on Auto position, when dusk levels force the headlights to switch-on, the cluster illumination will increase to the normal "night" values whereas with the light switch in the off position, the cluster illumination will fall until you manually turn-on the headlights. Hope this makes sense!
                          Not sure how tinted windows will impact my tweak (I would welcome feedback-please), but if you find that my curve does not sufficiently light-up the cluster illumination, I suggest that you decrease the settings for X5 to X2 by a set amount (your choose the amount). I suggest that you DON'T change the setting for X1 because this setting provides a reminder signal to the driver to turn-on the headlights at dusk. Hope this makes sense too!
                          Don
                            Not sure how tinted windows will impact my tweak (I would welcome feedback-please), but if you find that my curve does not sufficiently light-up the cluster illumination, I suggest that you increase the settings for X5 to X2 by a set amount (your choose the amount). I suggest that you DON'T increase the setting for X1 because this setting provides a reminder signal to the driver to turn-on the headlights at dusk. Hope this makes sense too!
                            Don
                            Thanks Don. I'll give it a go, observe and report back.
                            • Don, been driving all day today after the tweak. Not once did I think the dash was too dark.
                              This tweak has worked like a charm. Thanks
                                Agentthumb: Thanks for the feedback and well done - great to hear that the tweak was useful!
                                On a different, but related matter - has the window tinting affected the operation of the anti-dazzle rear vision mirror in your car?
                                From my reading of VW's material, my understanding is that the rear vision mirror uses two sensors to set its dimming level. There is a light sensor pointing to the rear (positioned near the LED) and a separate sensor pointing forward toward the windshield (it's recessed into the black plastic housing). The dimming level of the mirror is determined by the difference in illumination between these two sensors. If the car's rear window is tinted and the windshield is not tinted (or, the windshield is not tinted as much), logic says that the dynamic of the anti-dazzle mirror should/will alter (I think). Does this happen on mk7 cars with tinted windows??
                                Don
                                PS: on my car, I have taped-over the front light sensor on my anti-dazzle mirror. This means that every time that I switch on the mirror function, the level dims to maximum. Very low tech-but works great for me!
