Is anyone running v8 maps? (are they the latest)
This is a sticky topic.
I am. They are the latest.Daily: 2010 Tiguan TDI | Candy White | Manual | 4MOTION | New York Wheels | Comfort Pack | Tinted Windows | Discover Media | MkVI MFSW | Mk7 Climatronic | RVC | Fog Lights | ECB Nudge Bar | Hella 160 Driving Lights | Rola RBXL135 Cross Bars | To Do: Colour MFD
Toy: 2008 GTI Pirelli | Sunflower Yellow | 3 Door | DSG | Pirelli Wheels | RNS-510 | 9W7 Bluetooth | RVC | Rear Sensors | Fog Lights | To Do: Mk7 Climatronics, MkVI MFSW, Colour MFD
I 've got a Rev A unit and have ungraded to 3810 a while ago.When on the map the arrow indicating the position of the car is about 10 metres behind where the car actually is. Is there a way to correct this?sigpic GTI | MY08 | Blue Graphite | DSG | Leather | Bi-Xenon | RNS510 |
That's pretty normal. It is not predictive, it is only reporting your calculated position.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Drive slower and let it catch up. LOLOriginally posted by mark4323 View PostI 've got a Rev A unit and have ungraded to 3810 a while ago.When on the map the arrow indicating the position of the car is about 10 metres behind where the car actually is. Is there a way to correct this?
Last edited by Guest001; 16-04-2015, 08:05 AM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
Hi! I use a CD to erase maps from the maps partition labelled 2720_mpf ... all it seems to do is call a script in the firmware update interface hdTermFormat("/hdb2",2)) ... which I presume means format partition 2 on hdb2 ... just checking if this is still valid for the newer OEM SSD versions of the RNS 510??
I read the SSD versions have a different partitioning scheme and don't want to brick the thing by erasing the wrong partition
(This is to install older version of maps...)
EDIT: Link to source of this file from my-gti: Volkswagen RNS 510 Firmware Upgrade and Information | my-gti.comLast edited by YellowLemon; 23-04-2015, 09:46 AM.- 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
- 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
Maps are still on partition 2 on newer 3 partition systems. Why do you want to just erase the partition?2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Thanks for the advice! On my PC in the map disc I edit the original POI.DB3 file using free POIinspector to add custom POI and then burn this custom map disk ... but the RNS510 won't load maps that aren't a newer version ... so I erase the maps first, then load the maps again (this time with the custom POI.DB3 file)- 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
If you get an older version it will revert to that but wont load the same version you have. EG if you have V6 load V5 and then you can go up to V6,7or 8Originally posted by YellowLemon View PostThanks for the advice! On my PC in the map disc I edit the original POI.DB3 file using free POIinspector to add custom POI and then burn this custom map disk ... but the RNS510 won't load maps that aren't a newer version ... so I erase the maps first, then load the maps again (this time with the custom POI.DB3 file)2021 Kamiq LE 110 , Moon White, BV cameras F & B
All you need to do is increment the map version number by one in Poinspect0r eg 8035 to 8036. Then the rns sees it as a new version and will overwrite the existing maps.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Hi I did the firmware update on a H61 H LED version - first time I installed the maps straight after the firmware: this resulted in the system crashing anytime the maps were accessed. The trick was: install firmware, wait for GPS to get a location first (10-20 miuntes - you can check on the GPS status screen you get when pressing the maps button twice), only then insert maps CD for download. Cheers!- 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
Hi All,
Need some help.
Tried updating firmware on my RNS510 to v4120 but it failed about 51% of way through. Now have no radio etc. Looking for help on getting another copy/or loading of the 4120 software so I can finish the update.
Have rebooted but requires the installation to complete before I can get back to normal use.
Regards,
Shayne
