Is anyone running v8 maps? (are they the latest)
This is a sticky topic.
I am. They are the latest.Daily: 2010 Tiguan TDI | Candy White | Manual | 4MOTION | New York Wheels | Comfort Pack | Tinted Windows | Discover Media | MkVI MFSW | Mk7 Climatronic | RVC | Fog Lights | ECB Nudge Bar | Hella 160 Driving Lights | Rola RBXL135 Cross Bars | To Do: Colour MFD
Toy: 2008 GTI Pirelli | Sunflower Yellow | 3 Door | DSG | Pirelli Wheels | RNS-510 | 9W7 Bluetooth | RVC | Rear Sensors | Fog Lights | To Do: Mk7 Climatronics, MkVI MFSW, Colour MFD
I 've got a Rev A unit and have ungraded to 3810 a while ago.When on the map the arrow indicating the position of the car is about 10 metres behind where the car actually is. Is there a way to correct this?sigpic GTI | MY08 | Blue Graphite | DSG | Leather | Bi-Xenon | RNS510 |
That's pretty normal. It is not predictive, it is only reporting your calculated position.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Originally posted by mark4323 View PostI 've got a Rev A unit and have ungraded to 3810 a while ago.When on the map the arrow indicating the position of the car is about 10 metres behind where the car actually is. Is there a way to correct this?Last edited by Guest001; 16-04-2015, 08:05 AM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
Hi! I use a CD to erase maps from the maps partition labelled 2720_mpf ... all it seems to do is call a script in the firmware update interface hdTermFormat("/hdb2",2)) ... which I presume means format partition 2 on hdb2 ... just checking if this is still valid for the newer OEM SSD versions of the RNS 510??
I read the SSD versions have a different partitioning scheme and don't want to brick the thing by erasing the wrong partition
(This is to install older version of maps...)
EDIT: Link to source of this file from my-gti: Volkswagen RNS 510 Firmware Upgrade and Information | my-gti.comLast edited by YellowLemon; 23-04-2015, 09:46 AM.- 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
- 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
Maps are still on partition 2 on newer 3 partition systems. Why do you want to just erase the partition?2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Thanks for the advice! On my PC in the map disc I edit the original POI.DB3 file using free POIinspector to add custom POI and then burn this custom map disk ... but the RNS510 won't load maps that aren't a newer version ... so I erase the maps first, then load the maps again (this time with the custom POI.DB3 file)- 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
Originally posted by YellowLemon View PostThanks for the advice! On my PC in the map disc I edit the original POI.DB3 file using free POIinspector to add custom POI and then burn this custom map disk ... but the RNS510 won't load maps that aren't a newer version ... so I erase the maps first, then load the maps again (this time with the custom POI.DB3 file)2021 Kamiq LE 110 , Moon White, BV cameras F & B
All you need to do is increment the map version number by one in Poinspect0r eg 8035 to 8036. Then the rns sees it as a new version and will overwrite the existing maps.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Hi I did the firmware update on a H61 H LED version - first time I installed the maps straight after the firmware: this resulted in the system crashing anytime the maps were accessed. The trick was: install firmware, wait for GPS to get a location first (10-20 miuntes - you can check on the GPS status screen you get when pressing the maps button twice), only then insert maps CD for download. Cheers!- 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
Hi All,
Need some help.
Tried updating firmware on my RNS510 to v4120 but it failed about 51% of way through. Now have no radio etc. Looking for help on getting another copy/or loading of the 4120 software so I can finish the update.
Have rebooted but requires the installation to complete before I can get back to normal use.
Regards,
Shayne
