Can't recall mate. But I think it may have been able to calculate it. I know the Garmin bling bling in my wife's Polo can do it.
This is a sticky topic.
You sir have just earned some rep
Here you go
Firmware 4020 with modified partitions (for Australian/NZ Version A units)
FW_4020_A.ISO - download now for free. File sharing. Software file sharing. Free file hosting. File upload. FileFactory.comMY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
Thanks Steve2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Do I need to activate downgrade in the secret menu to load this firmware given that I am already on 4020?
Originally posted by kamold View PostSorry I meant to reply to your post thezoneR32's...
The last portion of the firmware load, VUCI which is reporting the failure may indicate that the tables it is trying to copy are not compatible.
You mentioned that you have a B revision unit I think so the 402x image that you are using needs some of those tables swapped around in order for you to use it. We have not made this widely available due to possible issues however FJSteve is running it on his A unit without issue as far as I am aware.
You have two options here: downgrade to the 381x image from the beginning of this thread which has the tables swapped for compatibility with your unit, or ask FJSteve to make the 402x image with table swaps available for others to try.
Cheers guys great thread!Volvo S60 RD T6
Yep need to do a downgrade.
If this doesn't fix your issue then there may be an issue with the unit.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Just a note: I upgraded a '11 and '12 build Rocco with the files here, burnt to CD (Benq) at the slowest possible speed, without problems.
The RNS in both detected the CD without the need to press the buttons to restart the unit. Both took 57mins for the firmware, plus the Nav disc.
I have read through the whole thread and I have a question from a real novice on this sort of thing -
In the first post it says for upgrading to -
Firmware 40xx -Links (thanks to JohnC) Part 1 Part 2 Part 3 Part 4 Part 5
1. Do I have to download all 5 parts and combine it into 1 cd? Or,
2. Can I just use the link provided
and burn one cd from this link please?
Apologies if this has been answered before or I just don't have the knowhow to work out what I should do.MkVI GTD fitted with Bluetooth & MDI, CSG, DSG, Xenons, RNS510 with Dynaudio, ACC, Weathershields, Mudflaps, Sunroof, LED Tails, LED Indicators, LED Foglights, Interior LEDs, Tinted, RVC and Towbar - Gosford.
You need to work out which version unit you have first.
A, B, C, D or higher?
The five part link (and yes download them all and combine with say winrar program) can be used for anything other than A unit.
Second link is just for an A unit.MY11 Tiguan 147TSI (SOLD)
All I can say is - You guys are brilliant. After I worked out how to extract and combine the 5 parts, I burnt the CD using IMGBurn and then made the choice to "have a go". It worked perfectly. I followed the instructions fully and I now have 33Gb of free space instead of 19 odd Gb. I have now upgraded to FW4020 from FW3920, have V5 maps and a ton of POIs. Bloody brilliant. Thanks heaps Kamold, JohnC, Aussietig and I'm sure I've missed someone. Well done.MkVI GTD fitted with Bluetooth & MDI, CSG, DSG, Xenons, RNS510 with Dynaudio, ACC, Weathershields, Mudflaps, Sunroof, LED Tails, LED Indicators, LED Foglights, Interior LEDs, Tinted, RVC and Towbar - Gosford.
Originally posted by GTD Dubber View PostAll I can say is - You guys are brilliant. After I worked out how to extract and combine the 5 parts, I burnt the CD using IMGBurn and then made the choice to "have a go". It worked perfectly. I followed the instructions fully and I now have 33Gb of free space instead of 19 odd Gb. I have now upgraded to FW4020 from FW3920, have V5 maps and a ton of POIs. Bloody brilliant. Thanks heaps Kamold, JohnC, Aussietig and I'm sure I've missed someone. Well done.
Hey Brim,
When you say I got VIM ... does this mean I can play a movie dvd while driving?MkVI GTD fitted with Bluetooth & MDI, CSG, DSG, Xenons, RNS510 with Dynaudio, ACC, Weathershields, Mudflaps, Sunroof, LED Tails, LED Indicators, LED Foglights, Interior LEDs, Tinted, RVC and Towbar - Gosford.
(yes)MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
