Firmware updates for RNS510 units in Australia/NZ
This is a sticky topic.
  • Can't recall mate. But I think it may have been able to calculate it. I know the Garmin bling bling in my wife's Polo can do it.
    MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
    2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
    • Perfectly normal ... whenever I put in a WA address, my unit returns "Catch a plane you tight@$$!".
      MY11 Tiguan 147TSI (SOLD)
      • You sir have just earned some rep
        Audi A3
        • Here you go
          Firmware 4020 with modified partitions (for Australian/NZ Version A units)
          FW_4020_A.ISO - download now for free. File sharing. Software file sharing. Free file hosting. File upload. FileFactory.com
          • Thanks Steve
            • Originally posted by FJ Steve View Post
              Here you go
              Awesome Steve thanks for that!
              Do I need to activate downgrade in the secret menu to load this firmware given that I am already on 4020?
              Originally posted by kamold View Post
              Sorry I meant to reply to your post thezoneR32's...
              The last portion of the firmware load, VUCI which is reporting the failure may indicate that the tables it is trying to copy are not compatible.
              You mentioned that you have a B revision unit I think so the 402x image that you are using needs some of those tables swapped around in order for you to use it. We have not made this widely available due to possible issues however FJSteve is running it on his A unit without issue as far as I am aware.
              You have two options here: downgrade to the 381x image from the beginning of this thread which has the tables swapped for compatibility with your unit, or ask FJSteve to make the 402x image with table swaps available for others to try.
              kamold, I already downgraded to the 381x image from the beginning of this thread which also gave me the swl error screen that I posted. I will try this new 4020 and see how I go.
              Cheers guys great thread!
              Volvo S60 RD T6
              • Yep need to do a downgrade.
                If this doesn't fix your issue then there may be an issue with the unit.
                • Just a note: I upgraded a '11 and '12 build Rocco with the files here, burnt to CD (Benq) at the slowest possible speed, without problems.
                  The RNS in both detected the CD without the need to press the buttons to restart the unit. Both took 57mins for the firmware, plus the Nav disc.
                  • I have read through the whole thread and I have a question from a real novice on this sort of thing -
                    In the first post it says for upgrading to -
                    Firmware 40xx -Links (thanks to JohnC) Part 1 Part 2 Part 3 Part 4 Part 5
                    1. Do I have to download all 5 parts and combine it into 1 cd? Or,
                    2. Can I just use the link provided
                    and burn one cd from this link please?
                    Apologies if this has been answered before or I just don't have the knowhow to work out what I should do.
                    MkVI GTD fitted with Bluetooth & MDI, CSG, DSG, Xenons, RNS510 with Dynaudio, ACC, Weathershields, Mudflaps, Sunroof, LED Tails, LED Indicators, LED Foglights, Interior LEDs, Tinted, RVC and Towbar - Gosford.
                    • You need to work out which version unit you have first.
                      A, B, C, D or higher?
                      The five part link (and yes download them all and combine with say winrar program) can be used for anything other than A unit.
                      Second link is just for an A unit.
                      • Outstanding, thanks Aussietig.
                        • All I can say is - You guys are brilliant. After I worked out how to extract and combine the 5 parts, I burnt the CD using IMGBurn and then made the choice to "have a go". It worked perfectly. I followed the instructions fully and I now have 33Gb of free space instead of 19 odd Gb. I have now upgraded to FW4020 from FW3920, have V5 maps and a ton of POIs. Bloody brilliant. Thanks heaps Kamold, JohnC, Aussietig and I'm sure I've missed someone. Well done.
                          • Originally posted by GTD Dubber View Post
                            Your accolades are justified, and you've got VIM!
                            • Hey Brim,
                              When you say I got VIM ... does this mean I can play a movie dvd while driving?
                                Hey Brim,
                                ka-ching...there's the money-shot
                                (yes)
