Tigger73's 162TSI Sportline
  • Great update. She’s certainly coming along.
    2018 Allspace 162TSI R Line
    • Originally posted by iDiesel View Post
      Thanks!
      I've put together the mod list. It's seemed to have grown a bit more than what I thought...
      BASE CAR
      2017 Tiguan 162TSI Sportline, Crystal Black, Sunroof
      MODIFICATIONS
      HRE FF15 20x9 ET35
      Eibach Pro-Kit Lowering Springs
      TTE475 Hybrid IS38 Turbo
      RD Technik Stage 3 ECU Tune (base map)
      RD Technik Stage 3 DSG Software (to be installed)
      RD Technik 3" DP (Mk7 R spec)
      R600 Intake
      Racingline Silicon Intake Pipe
      Wagner MQB Intercooler
      Leyo Turbo Muffler Delete
      Leyo High Flow Turbo Inlet Pipe
      VIS HPFP (to be installed)
      034 Motorsport Billet Aluminium MQB Dogbone Mount Insert
      Full Size Spare
      Nova EVO Ceramic Coat
      Forever Black bumpers
      - Tigger73's 125TSI Build
      • Hi Tigger72
        I you looking some serious very light high performance tyre on wet and dry .Will make your tig to start as rabbit , than I can recommended you try new Conti premium contact 6 .They are lighter at least 1kg per tyre than any other brand tyre in this cat, and have almost all better performance in all aspect than Conti sport5 https://blobs.continental-tires.com/...act-6-data.pdf .some vide review Goodyear Eagle F1 Asymmetric 5 VS Continental PremiumContact 6 Test - Tyre Reviews
        Price here in AU can be find also really cheap for this performances offered.
        • Thanks Cameleon. I will be looking at tyres soon(ish). I do a fair few km in my cars so good wear is also a consideration. Ideally I'd like to get 35-40,000km out of a set. I know that's not always possible, however I'd be prepared to sacrifice a little in terms of performance if I can get another 10,000km out of a set the tyres. Ideal world I'd have a long life performance tyre which is good in wet and dry but that combination is often hard to achieve.
          • I know previous usig Conti , from ContiSport5 was wearing very fast almost finish at 20k! but this one at least on 4wd tig I had 25k and still at least left 15k for front and maybe 20k for rear left to use .But I don't put this car hard and I am not racig, but I never notice wheel spin with this tyre regardless how wet is or fast cornering or road condition. However this is not tyres for everyone if you don't like soft fill tyre. It is so light and so soft easy to move around with one finger on steering . When first time you come to this tyre you will be thinking like is balloon not tyre And need some get used , as is very very light and sensitive tyre on steering input. Again because is just incredible light ( 21kg only on 18 inch sportline Audi wheel in 235/55R18 for compare on some wheel Bridgestone H/P sport tyre with even lower profile /235/50/R18 was 24.3kg so saved almost 3.5kg per wheel!
            In beginning I didn't like at all this tyre was bit scare at high speed , till I didt find correct pressure for this tyre , but after get some used on lightness and adapted on precise sensitive control steering input is just amazing ultra light grip tyre ,very comfortable and noise is also minimal.
            • OK got a call from the tuner today and he has a new file to go on before the HPFP gets installed. This is a 26psi file but with reduced fuelling to work with the stock fuel pump.
              So I'm heading into the workshop tomorrow morning to get the file loaded and some initial logs done. Things seem to be moving along now that everyone is over Easter/Anzac holidays.
              • Ooft, see if you can put the car into dyno mode and get a dyno run with haldex engaged and not engaged.
                Curious to see the power difference.
                Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
                Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
                www.nhbautomotive.com.au
                • It'll get road tuned first and then onto the dyno later (in the next week or 2).
                  • New tune file loaded on this morning and we logged the boost vs rpm just to check the turbo response.
                    Really happy with how the TTE475 spools up (which is one of the main reasons I chose to go with this turbo):
Name:	Actual Boost vs RPM - TTE475.jpg
                    Now to get the fuel pump installed and turn it up! Currently running 20psi and will aim for around 26psi once it's dyno tuned.
                    • Awesome, can't wait for the final dyno!
                      Current:
                      2017 Mk2 Tiguan 162TSI, R-line, White
                      2020 Mk7.5 Golf R Wagon, White
                      • RD are not custom tuning the car on the dyno? Just sending you tunes to upload?
                        Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
                        • Originally posted by INASNT View Post
                          They’re getting it close with some road tuning and finishing it on the dyno. No use paying for dyno time to run some base maps.
                          • Just hit 20,000km the other day.
                            • Man you pack on the ks!
                              Our car is just at 11k
                              • Im at 23,000km.
