Originally posted by tigger73
View Post
Tigger73's 162TSI Sportline
DP will likely be RD Technik Mk7 R or equivalent. Exhaust will probably come later - it's actually not necessary for tuning as cat-back section is only for noise (DSG farts and over-run crackles).Originally posted by Psych101 View PostWhat are the plans for a dp and exhaust? (I assume this is necessary given the turbo and other mods)
I am looking to source a stock Mk7 R exhaust and looking to modify this to suit. There's a couple around but looking to pick one up at the right price when it comes along. I'm in no real hurry on this as I've got plenty of other things to spend $ on and getting the cosmetic stuff will happen later.
This car needs a bit more noise more than anything else I feel. I can't even hear any dsg farts stock.Originally posted by tigger73 View PostDP will likely be RD Technik Mk7 R or equivalent. Exhaust will probably come later - it's actually not necessary for tuning as cat-back section is only for noise (DSG farts and over-run crackles).
Agreed. I’ll see how the sound goes with DP, turbo and intake installed and go from there.Originally posted by Psych101 View PostThis car needs a bit more noise more than anything else I feel. I can't even hear any dsg farts stock.
Would love to see a step by step write up of how you eventually install the mk7 R exhaust on your Tiguan! That’s def a project on the cards for me too.Originally posted by tigger73 View PostDP will likely be RD Technik Mk7 R or equivalent. Exhaust will probably come later - it's actually not necessary for tuning as cat-back section is only for noise (DSG farts and over-run crackles).
I’ll just be taking the stock Mk7 exhaust to an exhaust shop and getting them to modify it to fit.Originally posted by GreyGoose_X View PostWould love to see a step by step write up of how you eventually install the mk7 R exhaust on your Tiguan! That’s def a project on the cards for me too.
I’ll look to get some photos and a description of what changes had to be made to get it to fit.
Ran some timed 0-100’s this morning.
Was quite surprised with the results:
So that’s 0.4sec off the stock 0-100 time just from an intake!
Morning, that’s a massive performance increase with just an intake upgrade!Originally posted by tigger73 View PostRan some timed 0-100’s this morning.
We’re all the conditions and settings the same as your original run without the intake?VW Tiguan 162 TSI Highline w/ R-Line & DAP. Mods: OEM IS38 turbo, APR IS38 98 RON ECU tune, TVS Stage 2 + with custom TCU tune, APR Downpipe and resonator delete, APR turbo inlet, VWR turbo muffler delete, APR pendulum mount, APR dog bone insert, APR Open Pod Filter (MQB), RAMAIR intake tube, APR Red Ignition Coils, NGK R7437-9 Spark Plugs, DBA T3 slotted rotors front and T2 slotted rotors rear, ATE ceramic pads front and rear Vbox: 0-100 4.1s
Had you verified stock times are 6.5 with that same gps device beforehand though? If so, good result without a tuneOriginally posted by tigger73 View PostRan some timed 0-100’s this morning.
I can’t remember exactly what temps the stock run was done at but it certainly wasn’t a hot day. This morning was about 22 deg C so would have been max 10 deg C between the 2 - probably less.Originally posted by Melbourne_Tiggy View PostMorning, that’s a massive performance increase with just an intake upgrade!
Were all the conditions and settings the same as your original run without the intake?
Yes. Stock run was using same device and ran both directions on same road to check/verify.Originally posted by Psych101 View PostHad you verified stock times are 6.5 with that same gps device beforehand though? If so, good result without a tune
I was surprised at the difference. Most times intake just makes noise and no measurable performance gains but this is massive. I was kind of expecting 0.1s max but 0.4s is a significant gain.
I suspect the snow grate delete on the stock intake would give a little more at top end too.
Plus intake upgrade keeps warranty intact [emoji6]
From my testing I think you may get a modest increase. If you also installed a high flow panel filter you’d probably be able to get a measurable difference.Originally posted by OZROD View PostAnd for those who just want to remove the snow grate, I just did it. Took less than 5 minutes, lifted straight out, and didn't even get my hands dirty. I have no way of knowing if that made any difference, but I figured it couldn't hurt
I think the filter element plays a decent part as well as the more direct flow path with the Racingline intake.
Confirming a moderate increase. Snow grate removal was tested and there was a 3% increase in CFM:Originally posted by tigger73 View PostFrom my testing I think you may get a modest increase. If you also installed a high flow panel filter you’d probably be able to get a measurable difference.
Mk7 GTI Stock Airbox Snow Guard Modification
With a panel filter (AFE in this example) and snow grate removal, there was 5% better flow:
Mk7 GTI panel filter and snow guard modification
Turbo Inlet Pipe (TIP) shows some distinct gains over stock (note APR intake did not provide significant flow increase compared to the panel filter and snow grate removal):
TIP comparison - APR vs panel
APR intake and APR inlet pipe
Turbo Inlet pipe shoot out, Burger Motor Sport and MST with elbow take the lead:
Inlet pipe testing
The elbow gives a boost also....Last edited by Melbourne_Tiggy; 20-01-2019, 12:33 PM.VW Tiguan 162 TSI Highline w/ R-Line & DAP. Mods: OEM IS38 turbo, APR IS38 98 RON ECU tune, TVS Stage 2 + with custom TCU tune, APR Downpipe and resonator delete, APR turbo inlet, VWR turbo muffler delete, APR pendulum mount, APR dog bone insert, APR Open Pod Filter (MQB), RAMAIR intake tube, APR Red Ignition Coils, NGK R7437-9 Spark Plugs, DBA T3 slotted rotors front and T2 slotted rotors rear, ATE ceramic pads front and rear Vbox: 0-100 4.1s
All these also increase intake noise alot.. DV+ also gives nice turbo noises when coming off the throttle.Originally posted by Melbourne_Tiggy View PostConfirming a moderate increase. Snow grate removal was tested and there was a 3% increase in CFM:
Inlet pipe testing
If you really want a loud intake, disconnect the airbox and just have the turbo inletpipe, did this to see how it sounded when installing my intake parts...Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
