Originally posted by tigger73
View Post
Tigger73's 162TSI Sportline
Woohoo, congrats!Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
www.nhbautomotive.com.au
Thanks! Now I have a job for tomorrow morning....Originally posted by Dose Pipe Sutututu View PostWoohoo, congrats!
Intake install complete!
Wasn’t particularly difficult. Watched a couple of install videos first and went pretty smoothly.
Only around the block to get a before/after videoOriginally posted by Psych101 View PostNice! Driven with it yet?
Not long. All-up was less than an hour and that included getting tools out and packing away.Originally posted by Grugly View PostHow long did it take you to install?
2 screws and the clip on the pipe to undo and then about 8 screws and the clip to put the R600 in. One of the simpler mods as there's no major disassembly required.
Do u need to modify anything out the front of the car for the air intake?Originally posted by tigger73 View PostOnly around the block to get a before/after video
No modifications - just straight bolt off and bolt on. The R600 intake effectively has the "snow grate" modification already completed as it takes air from the complete front of the car compared to the stock intake which has half blanked off.Originally posted by Psych101 View PostDo u need to modify anything out the front of the car for the air intake?
very sexy, I like how it doesn't look "cheap" like those REVO kits.Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
It doesn't look cheap because it wasn'tOriginally posted by Dose Pipe Sutututu View Postvery sexy, I like how it doesn't look "cheap" like those REVO kits.
RRP on these is $795 + shipping. I bought it in the Xmas sales when they had 10% off (and another 5% discount on Ebay).
It's still pricey but it looks almost stock. If you didn't know what you were looking at you probably wouldn't know any different.
Sounds very OEM, I think under WOT you should be able to feel and hear little bit of difference. With a tune, DP and turbo swap the R600 will increase induction volume and sound.....Originally posted by tigger73 View Post
Well done on your first performance mod.VW Tiguan 162 TSI Highline w/ R-Line & DAP. Mods: OEM IS38 turbo, APR IS38 98 RON ECU tune, TVS Stage 2 + with custom TCU tune, APR Downpipe and resonator delete, APR turbo inlet, VWR turbo muffler delete, APR pendulum mount, APR dog bone insert, APR Open Pod Filter (MQB), RAMAIR intake tube, APR Red Ignition Coils, NGK R7437-9 Spark Plugs, DBA T3 slotted rotors front and T2 slotted rotors rear, ATE ceramic pads front and rear Vbox: 0-100 4.1s
Yeah haven't really had the opportunity to go WOT yet to test it. Sound will definitely change with all the other mods but I like that it isn't obnoxious.Originally posted by Melbourne_Tiggy View PostSounds very OEM, I think under WOT you should be able to feel and hear little bit of difference. With a tune, DP and turbo swap the R600 will increase induction volume and sound.....
I'll have to see if the 0-100 has changed. I know usually intakes make bugger all difference
I will have to get around to updating the post on the first page but car is pretty much stock with an intake and some blacked out trims. Don't want to disappoint you from reading through 300+ posts.Originally posted by Psych101 View PostIs there a summary of everything you have done on this build? Looked at the start but maybe its further in?
On order are TTE475 hybrid turbo (due to be completed manufacture shortly). I'll also be placing an order for an intercooler shortly (likely Wagner) and will also be getting a DP, turbo inlet elbow and turbo muffler delete. After that it'll be on the dyno for tuning. So the discussion is more about the preparation and all the exciting bits are yet to come...
