When to edit the spelling mistake in my post and the edit deleted the post, fark....
Tigger73's 162TSI Sportline
Originally posted by INASNT View PostWhen to edit the spelling mistake in my post and the edit deleted the post, fark....Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
www.nhbautomotive.com.au
That's why you have moderators
Originally posted by Dose Pipe Sutututu View PostI saw the post haha.. But yeah this forum needs a refresh man! I hate tapatalk, it's junk so I only use it to attach images.
How’s the base tune?VW Tiguan 162 TSI Highline w/ R-Line & DAP. Mods: OEM IS38 turbo, APR IS38 98 RON ECU tune, TVS Stage 2 + with custom TCU tune, APR Downpipe and resonator delete, APR turbo inlet, VWR turbo muffler delete, APR pendulum mount, APR dog bone insert, APR Open Pod Filter (MQB), RAMAIR intake tube, APR Red Ignition Coils, NGK R7437-9 Spark Plugs, DBA T3 slotted rotors front and T2 slotted rotors rear, ATE ceramic pads front and rear Vbox: 0-100 4.1s
Originally posted by Melbourne_Tiggy View PostHow’s the base tune?
There's a base file in it but I've been told no WOT and no running to redline so it'll be mild levels of boost/midrange running only.
Better put a brick or a piece of timber under the accelerator pedal so you don't get excited haha.Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
Originally posted by tigger73 View PostThings didn't quite happen late this afternoon and then my wife needed to go to the shops and get her nails done before Easter so long story short I'm picking up the car in the morning. Well I did have her car all week so I guess that's understandable.
I guess no launch control until the HPFP and tune is in
Have a good Easter!VW Tiguan 162 TSI Highline w/ R-Line & DAP. Mods: OEM IS38 turbo, APR IS38 98 RON ECU tune, TVS Stage 2 + with custom TCU tune, APR Downpipe and resonator delete, APR turbo inlet, VWR turbo muffler delete, APR pendulum mount, APR dog bone insert, APR Open Pod Filter (MQB), RAMAIR intake tube, APR Red Ignition Coils, NGK R7437-9 Spark Plugs, DBA T3 slotted rotors front and T2 slotted rotors rear, ATE ceramic pads front and rear Vbox: 0-100 4.1s
Originally posted by Melbourne_Tiggy View PostYour wife sounds very tolerant, mine would have gone bananas if she didn’t have transport for the week.
Have a good Easter!
And no LC or 0-100 runs for at least another week.
Sent from my iPhone using TapatalkLast edited by tigger73; 19-04-2019, 07:36 AM.
Right picked up the car this morning and it's certainly a different beast.
Its nicely driveable in lower rpm area under 2,500rpm which is where the turbo starts to spool and really starts getting going around 2,800rpm. From there the tacho moves rather rapidly towards 6,000rpm. File is currently on 23psi base map and not going to do much more than daily duties for the next week or so.
Apart from a rattle which is (I think) heatshield it's all pretty good. Cruises along fine, nice little bit of turbo whistle at low rpms under load. But it's quiet at 90km/hr on the expressway.
Probably could do with a bit more exhaust note as there's definitely more growl coming from the engine / downpipe and not much (nothing at all) out the back. Once I get the rattle fixed and the HPFP in and tuned I'll post up a full review along with dyno charts.
Originally posted by twyat1 View PostWhat DP are you running. Generally speaking most aftermarket DP have been the source of rattles as or needs to be modified to fit. After my hangers were adjusted again the rattle went away.
Sent from my SM-G975F using Tapatalk
I know a couple of others have also experienced small rattles after install so I'm not too worried.
Originally posted by tigger73 View PostRD Technik Mk7 R DP fits better on the Tig than on the Golf! Actually needed to shorten the catback section f the stock exhaust by 30mm to get proper fitment - probably because of the reducer. Also spoke to the workshop and they said most likely a small exhaust leak but will get it back there in the week after Easter/Anzac for round 2.
I know a couple of others have also experienced small rattles after install so I'm not too worried.VW Tiguan 162 TSI Highline w/ R-Line & DAP. Mods: OEM IS38 turbo, APR IS38 98 RON ECU tune, TVS Stage 2 + with custom TCU tune, APR Downpipe and resonator delete, APR turbo inlet, VWR turbo muffler delete, APR pendulum mount, APR dog bone insert, APR Open Pod Filter (MQB), RAMAIR intake tube, APR Red Ignition Coils, NGK R7437-9 Spark Plugs, DBA T3 slotted rotors front and T2 slotted rotors rear, ATE ceramic pads front and rear Vbox: 0-100 4.1s
Maybe cut off the slip joiner and get a set of self-locating v-bands, 1x step down reducer & an exhaust bellow.
I know it's not "Euro" spec, but those slip joiners on Euro cars are a nightmare and I hate them. I've been under the Tiguan a few times and itching to mod it, but the wife said to finish off the R33 before I touch her car hahaDaily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
OK just spent a bit of time updating the first page (first few posts) with progress to date. I'll post up a full build list in the first post shortly also.
