  • Push the go pedal less aggressively
    Also unplug soundaktor.
    • First is not likely
      Second has nothing to do with induction noise
      Thanks though
      • Originally posted by Candyman View Post
        How to minimize induction noise under acceleration ?
        earplugs
        • Tried earplugs but soundaktor rattles them out
          • turn up the radio.. quit you complaining... more induction noise means more powar
            • Power is good
              Induction noise is bad
              So, live with it then.
              Guess I was hoping an intake mod might turn it down a notch
              • hmm I like induction noise.. maybe cold air intake will fix it.. allow it to breath better.. ask the folk that have done this
                • Will do
                  • Don't CAI mods make the induction noise louder? Mr Hawk posted comparison videos for his 118 TSI cab.
                    Audi A3
                    • Depends on the intake design
                      • Currently running a VWR Intake on a 2008 Audi S3[mechanically the same as Golf R]
                        Can't say that I've noticed any increase in induction noise over stock.
                        Len
                        • Originally posted by Ryan_R View Post
                          As far as my experience goes - yes.
                          Forge Twintake = louder
                          AWE intake = louder
                          VWR intake = louder
                          APR Carbonio = little bit louder
                          Those are the intakes I have heard. I'm sure the other brands are much the same.
                          The APR Carbonio is the quietest, but it's still a bit louder than stock. If you don't like the sound of your R's induction noise, then your going to HATE the C63 if you end up getting one. They are loud and obnoxious ALL the time (idling / slow cruising / full throttle etc). I had a C63 estate for a day last year - personally I loved the sound.
                          Len
                          If you drive with your windows up 100% of the time you may not notice and difference in noise Len. I also have the VW Racing intake and I can assure you it's much louder than stock. Next time you take your car out, put your window down and give the car some throttle.
                          • C63 will be a weekender only
                            My R is my daily
                            An investigating the new option from Viezu but also chatting with a tuner on modifying the stock intake
                            • Maybe covering the intake inlet with muffling material (i.e. stockings etc) will reduce the intake sound.
                              Any form of modified intake will only make it louder as Lucas stated since most people want it louder.
                                My R is my daily
                                Fair enough. The C63 was a ripper. I only had it for a 24hr period though. You should start saving for tyres now - the rear ones wont last long at all. It wants to spin the tyres and go sideways ALL the time. And its only got narrow 255 section tyres. The one i drove only had 18,000km on it and the previous owner said it was its 3rd set of rear tyres. Yes 3rd set in 18,000km!!
                                I dare say whatever Viezu are working on intake-wise will be louder than stock as well. You could try removing the plastic hose that goes from the engine cover to the grill, and getting a custom made pipe made up from the engine cover down to the space behind / below the passenger headlight?? Add a 2nd air filter (pod style) at the end of that pipe and it might help to quieten the intake noise down?? It wont look pretty (and personally i wouldnt do it) but if you want to quieten it down, that might be a solution.
