2720 -> 4120 with ease. Worked first go. Like a treat
Thanks guys. Getting my hands on the latest Maps dvd tomorrow to load on. Going to go through and load up music tonight.
This is a sticky topic.
Make sure you get Aussietigs POI database loaded on there too for speed cameras etc2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Hi guys,
Does anyone have firmware 6270 or the newer 6272??? I have a R model (C14) and it is very buggy and want to do a clean install. For some reason, I cannot find any links to getting it. What's the go, why is this not available anywhere?
Any help would be much appreciated
Because you need to wait for a factory install CD to be made available. If it's buggy go back to where you bought it from.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Hi Guys, I was thinking about updating maps and firmware but after reading warning on 1st page about HW radio version 0003 am now a bit stumped!
What would be the best firmware to use for the following specs (or should I risk it and try 4120)???
Part number: 1T0035680C
HW-Version: H04
SW-Version: 2760
HW Radio: 0003
Active map: Aust+NZ
Active map: Sensis
Map version HDD: 7360
Many thanks
4020. Any higher could damage your radio tuner board permanently.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Thankyou SirOriginally posted by kamold View Post4020. Any higher could damage your radio tuner board permanently.
Just downloading now from the link of the first page
Is there any limitation on the map version I can use or will the latest version of maps combined with Aussietigs POI database be OK?
Thanks again Kamold!Last edited by tigger73; 06-12-2014, 07:34 PM.
No limit with maps or POIs, just firmware.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Well... running in the FW4020 update now..... the first 2 disks ejected with errors but the 3rd has stayed in. No instructions popped up on the screen and the screen is really, really, really dim.
The CD seems to be spinning and whirring and you can just make out a VW logo in the top left of the screen. It's been going 20 minutes now so will go downstairs to check it out in about half an hour.
Is the dim screen (almost not even on) normal or am I just lucky???
Originally posted by singlefished View PostWell... running in the FW4020 update now..... the first 2 disks ejected with errors but the 3rd has stayed in. No instructions popped up on the screen and the screen is really, really, really dim.
Doesnt sound right and its usually done on a DVD. There is a menu it goes through at normal brightness If you go back through the thread they are pictured doing it in its various stages
You should write it as slow as possible using Imageburn to be successful It usually takes an hour but shows on the screen what it is doing2021 Kamiq LE 110 , Moon White, BV cameras F & B
Success!!! Of sorts... Couldn't get a 4020 disc working and thought I'd bricked the thing as the radio was kaput even though it booted up properly.
Put the old RCD310 in and thought I'd have to have the RNS510 updated externally maybe next weekend.
Decided after dinner to try one last time with different images so downloaded 2760 and 3810.
Back down to the garage, removed the 310 and connected up the 510....2760 disc didn't work so tried 3810 - Bingo! It started loading properly!!!
A very nervy hour later it's all installed and running sweet!
Don't think I'll bother going to 4020.... had enough excitement already
Will get POI's installed next weekend.
I'm getting a cd/DVD error. Please check cd/dvd
I've burnt it to 3 DVDs and one cd
From a Mac if that makes a differenceMine:2012 MY12.5 Amarok |Natural Grey |RCD510|Premium Bluetooth
Hers:2012 MY12.5 Passat TDI|White|RNS510|MDI|Premium Bluetooth|Park Assist 2 | Sports pack | Tints
