Originally posted by gavs
View Post
Polo GTI High Oil Usage - Discussion Thread
This is a sticky topic.
2011 VW Polo 77TSI | Manual | Savannah Yellow | Comfort Pack | Sports Pack |
Installed: Whiteline Rear Sway Bar, H&R Springs, Resonator Delete
Originally posted by gavs View PostSo, to all of you worried about your oil consumption, just be wary in thinking that it's burning through more oil than it is because that dipstick only reads the equivalent of 1 litre of oil.
If it really only had a litre of oil remaining, the engine would've already seized by then.
Originally posted by Trepid4tion View PostHow do we do that on the 6R's, is it the same as others with the neg off the battery for a period of time? Been curious about that for a little bit but havent investigated much into it.
Dieselvert, I just find it daft that VW are making people panic due the level dropping on their dipstick, so when it drops by half the dipstick level over, say, 2000kms, then people panic and think "oh crap, my car has a capacity of 4 litres and half of it is gone in 2000kms!". The sump has a mighty big sensor on it which lets you know when the oil level realistically gets low, so why not have a true-er reading on the dipstick, it just seems logical to me and if indeed it is that critical to re-fill after losing 1L of oil, then it seems like VW engine engineers are putting owners at quite a level of risk.....
Just my opinion of coursesigpic
If you lose 1L of oil, then you DO need to top it up. So the dipstick and sensor are doing their job etc. I'm not sure how the dipstick being at the bottom and people having to add in 1L was then interpreted as the car being empty and having used 4L....
George06 Jetta 2.0TFSI Killed by a Lexus!
14 EOS 2.0 TSI has arrived!
Originally posted by Corey_R View PostIf you lose 1L of oil, then you DO need to top it up. So the dipstick and sensor are doing their job etc. I'm not sure how the dipstick being at the bottom and people having to add in 1L was then interpreted as the car being empty and having used 4L....carandimage The place where Off-Topic is On-Topic
Originally posted by gavs View PostDieselvert, I just find it daft that VW are making people panic due the level dropping on their dipstick, so when it drops by half the dipstick level over, say, 2000kms, then people panic and think "oh crap, my car has a capacity of 4 litres and half of it is gone in 2000kms!". The sump has a mighty big sensor on it which lets you know when the oil level realistically gets low, so why not have a true-er reading on the dipstick, it just seems logical to me and if indeed it is that critical to re-fill after losing 1L of oil, then it seems like VW engine engineers are putting owners at quite a level of risk.....
The MIN level on the dipstick refers to the minimum amount of lubricant the engine can function properly on. Going below this level means you risk serious engine damage.
There is no point of the dipstick to represent absolute volumes (i.e. max. = 5 L, min = 0 L), as the engine would almost certainty be permanently damaged just at the halfway mark. If you continued on and let it drop even further, it won't be long before the engine will seize up. Thus, it would serve no useful function (apart from generating business for engine rebuilders).
Originally posted by Diesel_vert View PostThe MIN level on the dipstick refers to the minimum amount of lubricant the engine can function properly on. Going below this level means you risk serious engine damage.Exactly. Most of the oil drains back to the sump when the engine stops so the oil level you measure is far higher than the level when the engine is running. And to allow for surge when cornering, accelerating or braking, the amount of oil must be greater than the amount needed to fill the oil galleries else oil pressure will drop in these circumstances with the obvious outcome to the most heavily loaded surfaces.
If the oil level fell below the mininum on the dipstick, I'd be worried that the engine may have suffered some damage already.Last edited by kaanage; 07-10-2011, 06:46 PM.Resident grumpy old fart
I would like to add that the drop in oil does NOT seem to be a linear process... at least in my car.
I've been lulled into a false sense of security for the first 1500kms after a top up, where the dipstick level stays at or near full. Then, the level seems to drop quite rapidly in the next 500km.
I think I've posted here twice about how my oil consumption issues seem to have resolved, only to correct myself soon after.
My 2 cents.2011 Polo GTI | Black | 5 doors | Comfort pack | Audio pack | 9w7 Bluetooth | Xenons - a Return to VW!
Previous ride: 2008 Mazda2 - ZOOM-ZOOM indeed!
1st Ride: 1988 Red VW Fox Sedan!
Originally posted by saabby View PostAfter 3,500km, I decided I better check the level. To my surprise, only 0.5 litres. Maybe I'm lucky or the high revs when new has something to do with it.2011 Polo GTI | Black | 5 doors | Comfort pack | Audio pack | 9w7 Bluetooth | Xenons - a Return to VW!
I agrees with the non-linear oil sipping habit of our GTi.
From 0-7500km the oil light only comes up around 7400km mark. After the service the oil problem got worse, down to 1L per 1000km, some times even less. I have been going back to the dealership for top up almost 7 times now up to 15k km.
Did the oil consumption test and VW agrees to change the piston rings. I hope this would fix the big appetite of the GTi.
Oil light came on last night at 3100kms. Dipstick was dry. It took 1L of oil to get it back to nominal.
What a joke! LS1's copped a hammering for going through waaay less oil than this back in the late 90's.
If the consumption continues like this, it will be interesting to see VW's response.
Originally posted by BENN0 View PostOil light came on last night at 3100kms. Dipstick was dry. It took 1L of oil to get it back to nominal.
If the consumption continues like this, it will be interesting to see VW's response.sigpic
