There is no clip & no heating was required on mine, it's flexible unlike the main plastic line from the engine which is bigger in diameter. I stand by my comments & I have a heat gun, so if necessary would have used it. The middle return simply pulls off, mine pulled off the rubber plug which I then pulled off the manifold. I simply pushed the middle pipe on with the rubber plug inserted (as delivered from VW) when re-installing, takes a small amount of effort - verify it's fully seated by inspection with a flash light.
It's an easy 10 minute job......
