I recently went into dealership on recommendation by VWA to get a new fix got to the dealership all they ran was some tests may have been that thing you are referring to. They still havent sent me my paperworks for that job when I get it i can tell you what it is. Either way I filed a report to fair trading and shall see where this takes me
Polo GTI High Oil Usage - Discussion Thread
This is a sticky topic.
That should be all they need to negotiate with vwa the repair and what is required. My dealer had mine for a day to complete the oil test and do the back and forth. Maybe they just want to take 3 days to do that back and forth. Not really cool for you to be without your car for so long and they aren't even fixing it.Originally posted by POW View PostDrop my car for oil consumption test result after 1000km. Confirmed by dealer 1.3L per 1000km. They top up now and booked next mth for 3-4 days to carry out diss ticket to VGA. Can someone tell me what it mean? The service guy said they need the car for data collection or something to send to VGA and if they approve,then will be repair. Is this usual process , is my first time and just want to know more.
As I keep recommending, don't be afraid to get in touch with vw assist, they really want to make sure we are looked after.
I have contacted VGA and have a case manager following the whole case.i know is bad to without my car for days but lucky dealer will give me a loan car when i drop my car to them.hope all fine after all.2013 POLO GTI Black
2005 MKV 2.0 FSI Black
Can someone explain to me how will a revised oil squirters fix the problem. I thought majority of these oil consumption problem are piston seal related? If your seals are stuffed, what difference would a new oil squirter make (assuming it's squinting less or redirecting the oil else where).Originally posted by Lucas_R View PostSo apparently VW/Skoda are installing new/revised oil squirters onto the 1.4 twincharge engines to try and reduce oil consmption issues. My bro who works for Skoda told me this a few weeks ago (after me asking him how many Fabia vRS's have come back with oil/DSG issues).
I haven't seen any mention of these oil squirters on here - anyone had this done yet? These engines squirt oil onto the bottom (or underneath) the pistons to cool them - i assume these are what have been revised.
I guess the worst scenario that could happen, is oil consumption is "reduced" to an "VW acceptable level", but would still require the owner to top up multiple times between services. I wonder if it's a cost saving fix, instead of a full rebuild or a new motor?
The theory is that the squirters are pumping too much oil under the pistons, this is finding its way up past the rings and getting burnt.
From what ive been told: Until about a month ago the fix was a short engine replacement. Then they went to a new TPI that was, 'check the piston part numbers, replace if not the MY13's, else clean the rings and refit with smaller oil squirters'. A vast amount of work as with all the 'strip, check, contact VGA for approval, order parts, wait for parts, fit parts, hope you dont break anything, potentially order more parts etc' it seems the turnaround is about 3 -4weeks if the parts are in the country. From what I can tell there is now a new TPI that only seems to be just to fit new squirters.Bury S9 XL cradle for Touch Adaptor for sale: http://tinyurl.com/hgmjc4j
Sold my Shadow Blue MY12.5 3 door Polo GTI for a WRX Hyperblue...
SPOC - 1st Four.... www.DeskDivers.com & www.PloProf.com & www.2smoked.com & www.JonWallis.com
Originally posted by ATYPIC View PostHow can you be so sure of this?
The damage appears to be done early on so it won't matter what procedure is used from that point on.
Hi, I have read quite a few pages of this thread, its so long :faceplate:could some please help me short cut this issue as I am thinking to get a polo gti very soon.
The oil consumption issue is a random pot luck issue? or it has been directly linked to not been run in correctly from new purchase?
Would the 2014 models still have this potential issue?
Thank you
Random pot luck IMOOriginally posted by Maclab View PostHi, I have read quite a few pages of this thread, its so long :faceplate:could some please help me short cut this issue as I am thinking to get a polo gti very soon.
Thank youcarandimage The place where Off-Topic is On-Topic
Yeah it seems to be potluck.Originally posted by Maclab View PostHi, I have read quite a few pages of this thread, its so long :faceplate:could some please help me short cut this issue as I am thinking to get a polo gti very soon.
Thank you
I went in knowing that but it just got frustrating along with other little things, I wouldn't risk it. I just got rid of mine after a year even though I had it all repaired, I just didn't trust the car anymore.
As others have said, it's 100% pot luck. No matter the engine combo, run in method, oil brand used, how you hold your tongue while doing a wee on a Thursday morning, it's all just pot luck. Rumour is that it's more attributed to the engine plant that the engine comes from but I think that's just another dealership excuse to try an keep customers happy and quiet.sigpic
At the end of the day it's caused by something, I wonder what that is. Poor quality control/loose tolerances on the pistons? I've heard the speculation that it's an issue because of the drive to reduce fuel consumption by lowering engine friction which would be annoying if true because I'm sure people care less about economy than they do about reliability...MY13.5 Polo GTI - Flash red
That's somewhat true, less inherent friction, the less resistance, the easier things move, the less bang required to make them move. However, you're right in that the poor manufacturing tolerances are to blame for reliability, plain and simple.sigpic
