Tigger73's 125TSI Tiguan Build Thread
  • Cool - no worries. Ive got the angle cut dual wall jobbies from Magnaflow on mine which i really like. These ones look quite similar so i wondered if they were also a Magnaflow part.
    They should look nice once they are on.
    B9 Audi SQ5
    • Originally posted by Lucas_R View Post
      I don't beleive there was any branding on the tips - will have another look.
      Yes looking forward to getting them on as it should finish off the exhaust nicely.
      - Tigger73's 125TSI Build
      • Originally posted by tigger73 View Post
        Hahaha I know there's almost always more to do
        Does the BT conversion on the APR Tig make the car a pain to drive in city traffic?
        I'm just concerned (apart from the cost of course) that whacking a big turbo on is going to kill the responsiveness and end up with a laggy car that has OMG levels of boost and nothing below 3,500/4,000 RPM. I have heard that some of the Golf R's are like that.
        Yes and difference between a manual 160kW car and 310kW DSG is going to be massive. I think you're almost better off having a DSG to do the gear changes with that much power/torque on tap.
        Do you know what the 0-100 times are with the car - low 4's? I know they're still working on the shifting so it'll only get quicker.
        I think I'd only look at going down the path of BT / brake upgrade if I was putting my car on the track whih I don't intend to do. So at this stage I'll give the $20,000 conversion a miss.
        next time you are in Brisbane - take it for a spin - perfectly behaved & drivable by your Grandma - that's why it takes months & months to get the software right on all stage 3 kits
        • Originally posted by Guy_H View Post
          Tempted just to get some cheap flights and come up for the day.
          • OK plasti-dip part 2 this morning...
            Had a couple of edges on the first attempt which have pulled away when taking off the tape. I'm looking to fix up and found that Eucalyptus oil melts plasti-dip so I've cleaned up the edges. Will attempt to "fix" rather than rip off and redo the whole section.
            I've heard that citrus based cleaners have a similar effect.
            • Taped up ready to go. Stay away rain!!!!
              • Exhaust tips getting fitted tomorrow.... as well as something else but you'll all just have to wait until it goes back on the dyno in about a weeks time to find out
                  Haha..
                  Intercooler ?
                  2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
                  • Originally posted by Ramee View Post
                    Haha..
                    Intercooler ?
                    Can't say - it's top secret.
                    Though I have an intercooler on the way and will be fitting it over Xmas along with some mods to the lower grill to allow more air flow.
                    • Keen to see how the plastidip and the super secret squirel mod goes.
                      I have now grown accustomed to the quietness of stock noise.
                        The effect of the Plasti-dip is a lot easier to see if you have two cars next to each other. It's chalk and cheese then.
                        I like this mod because it is subtle - looks a lot better but not really noticeable at the same time. My wife wonders why I bother...
                        Only possible downside is the rubber finish. Obviously the best would be to have colour coded paint, but for $50 for 2 cans of plasti-dip and a few hours on the weekend it's not bad.
                        Yes regarding secret squirrels, there's a few things going on in the back ground and I'll post up here when it's all done and dusted.
                        • New tips installed.
                          Happy with the result
                          • ^ They look good (nicely aligned etc) and the shine matches the muffler. Did they add 5kw as advertised
                            B9 Audi SQ5
                              Will have together it back on the dyno and check
                              • I find that a lot of the time, a visual improvement is more satisfying (to me) than a power/engine modification. The new tips definitely look nicer.
                                B9 Audi SQ5
