Mk2 Tiguan VCDS Tweaks
This is a sticky topic.
  • Originally posted by Wazza 162 View Post
    Learning a bit more with each step but still not showing in the light settings.
    Byte 5 isn't shown but I presume it's the light assist box, there are 2 more unlisted boxes under that one do I leave them alone?
    Close to giving up but I must be close to activating HBA.
    THANKS for your patience.
    Get your definitons correct or you will end up well in the s**t if you mix them up
    Its BYTE 21 BIT 5 and in mine it goes down to BIT 4 and then it says Light Assist (AFS) Dynamic light assist so tick the second box in that
    • Originally posted by Hillbilly View Post
      Mine is the same except High beam assist instead of Dynamic light assist with three boxes, I tick the first box
      MY18 Tiguan R Line Black-162 Highline TSI
      Drivers Assistance Package - Sunroof - Tow Bar
      Ordered July 17 Arrived December 17 Delivery Jan 18
        Why that one Worked it out as when i click on it it gives the option of HBA
        I know If have DLA enabled and so it will bring that up when I tick the box I did
          I'm so close, now have it in my settings and activates on auto lights, stalk pushed forward but comes up Fault light assist in dash centre
            I got that same error when I first did it - turns out I'd been counting the bytes from 1, instead of from 0.
            i.e. byte 0 starting at the top, not byte 1.
            Any chance you made the same mistake I did?
            • Originally posted by PDMJO View Post
              Maybe only going on hillbillys instructions so I would have thought he would say the byte by number e.g. byte 0 or byte 1 etc
                Its as plain as the nose on your face as under the big digits which is the first BIT in the BYTE you are on is the BYTE number you are on.
                Top row 00
                under that it says BYTE 21 or whatever you have scrolled to
                Hexadecimal always starts at 00 AFAIK
                You are both getting definitions mixed up which can only lead to confusion
                The bottom number is a BYTE which has a certain number of BITS which are the numbers in the top row..
                Try to get it right or instructions will be incorrect
                While it doesnt quite follow the protocol of 8 bits to a byte it is basically the same thing
                Bits and Bytes
                Why didnt you just use the APP It works.
                If you havent got enough credits Open the program every 24 hours and you get a free credit and if you open 5 ads you end up with 6 credits a day. Ive got 630 ATM for virtually doing nothing.
                  Top row 00
                  Bits and Bytes
                  Yes l did mix myself up with the message from PDMJO, bit 1 means bit1 etc. Byte numbers bring up the difference pages of bits.
                  I hope that is right.
                  I have redone again and all appears to be working except the fault light assist in dash centre comes on when pushing stalk forward
                  I did originally use the app but had to reverse it as I had no high beam even pulling back the stalk for highbeam flash didn't work.
                  Where are the ads?
                    Where are the ads?
                    Come on dont you do any research yourself Open the Wallet in the program and play around till you find out how
                    • Hi all, i have an MY20 Tiguan Allspace Highline, S&V, R-Line.
                      I purchased a Ross-Tech cable and have been making a few changes.
                      So far i have managed to do the following;
                      Adaptation changes;
                      IDE06419-Driving profile switchover
                      ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen
                      IDE04159-Deactivation of start-stop function - didn't work
                      IDE12467-Tubes illustration
                      IDE05111-Fee-based traffic information (TMC) - yet to confirm if this worked
                      IDE04158-Activation of start-stop function - this didn't work
                      IDE06588-Ignition active message: actuator
                      Long coding changes;
                      Overtaking right prevention active
                      Sat Nav initial disclaimer
                      display volume to be replenished
                      display acceleration
                      The one thing that i desperately want to change, is the stop/start function.
                      Does anyone with a new platform vehicle have a solution for this?
                      I looked for the temperature method, but couldn't find anything.
                      latest coding form the car below.
                      Tried to put in coding but website tells me it is too long.
                      • OK, what am i doing wrong with trying to post my code.
                        I go advanced, select the #, then paste the code between the [] [].
                        My code is a full log, 42000 odd characters, is that the issue?
                        I just did exactly the same thing on the RT Forum, and it accepted my code. Maybe it’s a post count thing.
                        • Ah, I received the new OBDEleven last week, and finally got around to using it last night, made some minor tweaks to get started,
                          * Enabled TMC traffic, this was working the next morning on my way to the station.
                          * Disabled startup nag, ah, peace at last.
                          * Disabled undertake on left prevention, I look forward to never worrying about this again.
                          Already my life is better.
                          I'm running on an MY19.5 R-line SWB
                          I plan on enabling Dynamic Light Assist next, and see if I like the Reduced throttle delay
                          maybe dynamic roadsign display, though i'm not sure how this is meant to work?
                          • Originally posted by AshB View Post
                            Read through the thread its all there and it doesnt work quite as good as it could due to our mapping limitations
                              That is what I thought. Oo this is the speed sign that appears on the maps, sometimes. I haven't really used the built in maps much, given my area is all new developments, the maps aren't updated often enough to be of much use, so I rely on car play.
                                It's works, the speed limits also come up in the display. It's works using the camera not maps.
                                Sent from my SM-G977B using Tapatalk
