Mk2 Tiguan VCDS Tweaks
This is a sticky topic.
  • Originally posted by twyat1 View Post
    It's works, the speed limits also come up in the display. It's works using the camera not maps.
    Sent from my SM-G977B using Tapatalk
    Does it really Tell me then why historic speed signs that are NO LONGER THERE come up at random places and do it repeatedly..
    Where does that info come from????
    • Originally posted by AshB View Post
      That is what I thought. Oo this is the speed sign that appears on the maps, sometimes. I haven't really used the built in maps much, given my area is all new developments, the maps aren't updated often enough to be of much use, so I rely on car play.
      If you look in this thread you will get the latest map which came out on Nov22nd
      Link is in reply 4
      Latest map for DIscover Pro out
        Ah, I received the new OBDEleven last week, and finally got around to using it last night, made some minor tweaks to get started,
        * Enabled TMC traffic, this was working the next morning on my way to the station.
        * Disabled startup nag, ah, peace at last.
        * Disabled undertake on left prevention, I look forward to never worrying about this again.
        Already my life is better.
        I'm running on an MY19.5 R-line SWB
        I plan on enabling Dynamic Light Assist next, and see if I like the Reduced throttle delay
        maybe dynamic roadsign display, though i'm not sure how this is meant to work?
        My Highline is to be delivered Friday and I would like to do the same things, but that's all.
        Does anyone in the Ballarat, Victoria region have a OBDEleven or VCDS who would be prepared to help me do these mods?
        • Hi,
          I've been trying to activate the Sunroof Opening/Closing With Remote Control using this coding:
          Sunroof Opening With Remote Control
          Sunroof opens when holding down the unlock button on the key fob. Also closes when holding lock button.
          Select Control unit 09 (Central Electrics)
          Security access
          Access Code 31347
          Adaptation
          (9) – Zugangskontrolle 2 – SAD Richtung Komfortöffnen auswählen
          Change to Active
          When I go into Adaptation, I can't find (9) – Zugangskontrolle 2 – SAD Richtung Komfortöffnen auswählen
          It simply isn't there.
          Does anyone have any tips/assistance for me please? It's a 2017 Comfortline with DAP and Lux.
          Cheers,
          Dan
          • ^^^^ Dan: it really does depend on the car's build year and as a consequence - what model BCM (the hex09 module) is fitted. There was a major re-write of the "Parent" names in the adaptation channel database for the BCM around mid 2016 and lots of stuff changed.
            Also the name for the channel in your post looks like it came from a very old version of VCDS. Assuming that you are using VCDS - the modern SW no longer reports adaptation channel with leading number in parentheses. Now, these channels have a set of leading "Tag numbers" : one for each of the Parent and child names.
            Of course, if you are using OBD11 - there are no parentheses, or Tag numbers
            Instead of your channel (9) – Zugangskontrolle 2 – SAD Richtung Komfortöffnen auswählen- try looking for looking for ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen
            Don
            • Thanks for your reply Don.
              I'm actually using OBD11.
              I looked through every line, and couldn't find find anything relating to "SAD", "Sunroof" or "Komfortoeffnen". I'm also hesitant to start activating/de-activating things randomly.
              I'll have another go tonight.
              Cheers,
              Dan
              • Youu could try in long coding Byte 3 has Comfort closing sliding roof, Comfort opening sliding roof. and Comfort opening type sunroof
                Byte 4 also has alternatives
                  I got my MY20 Highline last week and my OBDeleven device on Tuesday. Used 100 credits to run the roadside display app, which OBDeleven said was successful, but the dash flashed up with an error message (didn't quite catch what it said - but something like 'not supported'), but it doesn't seem to work at all.
                  It did all a "roadsign data" (or similar) option into the the driving data screen in the AID, but it just says there is no data.
                  Anyone else got this working on a MY20?
                  • The only way anyone has got it working is using the instructions posted by Phone booth The APP doesnt work at all
                    • Originally posted by Hillbilly View Post
                      Ok thanks, will try that. That was a waste of 100 credits I guess!
                      • Hey guys, I have a few questions and I'm gonna write them here in one post no to clutter the thread.
                        1. so I tried coding my tiggi to recognise speed signs and I believe I have missed something or perhaps my R-line doesnt' have the capability to do it but now I'm stuck with error. Does anyone know how to fix it, I sort of followed the steps and tried to reverse the changes ... I must be missing some step.
                        Imgur: The magic of the Internet
Name:	Dynamic road sign error.jpg
                        2. When you are driving in the area you are not familiar with sometimes it's nice to have the info displayed on the map what road you are on. I found that when driving in left top corner of the main display it shows what drive mode is on, however when you switch off the engine it displays the road name. I was thinking there should be an option to code and have street name displayed while driving too. I mean who really wants to know if you are in normal or sports mode.
Name:	Maps driving.jpg
Name:	Maps parked.jpg
                        3. I bought my tiggi brand new and it had this weird glitch on both screens when you get in the car and start the engine. I have a feeling it's got something to do with firmware? Anyone has the same issue? I'm thinking to take it to dealership and get it checked.
Name:	Dash squares.jpg
Name:	Display funny vw logo.jpg
                        4. There's also a blue line on the screen when the maps are on, not all the time but it seems to come and go. You would think it's water border however it appears even in the city.
                        I have attached photos but not sure if they will be big enough to see so there links bellow with original size bellow.
                        Thanks in advance
                          Thanks in advance
                          • Originally posted by tsameti View Post
                            [ATTACH=CONFIG]47785[/ATTACH]
                            [ATTACH=CONFIG]47786[/ATTACH]
                            [ATTACH=CONFIG]47787[/ATTACH]
                            [ATTACH=CONFIG]47788[/ATTACH]
                            [ATTACH=CONFIG]47789[/ATTACH]
                            Thanks in advance
                            https://imgur.com/m1OKevW
                            I can only address item number 4, but unfortunately it seems to be a fairly common issue - you’ll need to take it back to the dealership and they’ll swap out the Discover Pro unit for a new one. Happened to me too.
                            I imagine this may also fix item 3, which definitely isn’t normal.
                            • Got the Road Signs working on my MY20. After running the OBDeleven app, I then I went into Module A5 / Adaptations / changed 'Road Sign Detection' from 'Fusion' to 'Road Side Detection' and it works!
                              • Originally posted by ajobbins View Post
                                [ATTACH=CONFIG]47791[/ATTACH]
                                Yes that has to be done but if you use coding you dont need credits
