Originally posted by Hole46
View Post
Mk2 Tiguan VCDS Tweaks
This is a sticky topic.
Looks like MK2 version is back to the drawing board...
Why Nextgen has been delayed?
Manufacturer did not meet our high standards – after internal and external testing, hardware hasn’t passed our quality control. We want our device to be as perfect as it can be, before releasing it to the public, so we will need some time to fix all the issues.
When Nextgen will be back in stock?
We are sorry to inform you that we have delayed the release of Next generation device for unlimited time, because the manufacturer did not meet our high standards – hardware hasn’t passed our quality control. We keep working on fixing the issue and iOS software development, though we’re not confident enough to set any dates
2018 Allspace 162TSI R Line
I have an inkling it’s not so much quality as it’s hard to keep ahead of (and satisfy) Apple.
Apple don’t make it easy for 3rd-parties and are very security conscious.
Often devices need to exploit/bypass measures to perform the way the app designers and end-users expect.
This can open the door to dodgy behaviour(by clever end-users, copycat companies- think vcds clones), so Apple blacklist the app and/or hardware- even if nothing bad had yet happened. Again, it’s because they want a controlled and secure environment, rather than ‘herp derp Apple are scum’
They said manufacturing standards fell below expectations so they chose to fix problems before release and probably get more brown stuff heaped on them
Unless you have a fruity thing the original one works well. The new one apparently is going to include BMW as well2021 Kamiq LE 110 , Moon White, BV cameras F & B
Is there a tweak to have a more proactive Haldex? Like Audi’s Quattro Ultra where it’s engaged every time starting off from standstill etc?MY14 MK VII GTI | Pure White | Manual | Bi-Xenons (his)
MY19 B8 Passat 206TSI wagon | Manganese Grey (hers)
Haldex All-Wheel-Drive Adjust TractionOriginally posted by Jimi View PostIs there a tweak to have a more proactive Haldex? Like Audi’s Quattro Ultra where it’s engaged every time starting off from standstill etc?
Reports indicate that changing this setting to ‘Increased Traction’ improves the handling and makes the car feel like a permanent AWD system.
Select AWD Control Unit
Adaptation
Acoustic Measure, Wiring Logic
Choose from ‘Standard, Increased Traction, Less Noise’
Audi's quattro system is not haldex (unless it's on the MGB)
Having the haldex engage more often may increase wear on the clutches.Tig 162 R-Line; Audi TT
hello guys, I have read various posts regarding DLA, I believe my Tiguan is equipped with DLA per factory if anybody needs anything drop me a PM.
Here is the link to the Autoscan I read from all modules if you can determine anything.
2018 VW Tiguan 2.0T 4 Motion (Saudi Arabia Market) - CZPA
I used OBD11 to activate High Beam Assist on my MY19.5 162 R Line. The Headlight symbol with the A displayed on the AID, and turned from white to blue, but high beams were not being activated. Using OBD11, I deactivated, so now not getting the headlight/A symbol when I push the stalk forward, but still not getting high beam. Wondering if anyone else has had this problem?
Sounds to me like you may have done something wrong in the long coding if it’s only partially working.Originally posted by danintas View PostI used OBD11 to activate High Beam Assist on my MY19.5 162 R Line. The Headlight symbol with the A displayed on the AID, and turned from white to blue, but high beams were not being activated. Using OBD11, I deactivated, so now not getting the headlight/A symbol when I push the stalk forward, but still not getting high beam. Wondering if anyone else has had this problem?
I can’t recall, but is HBA possible with one of the apps? Maybe give that a shot instead.
I used the obdeleven app so you would think it should work, or at least turn off at light settings.MY18 Tiguan R Line Black-162 Highline TSI
Drivers Assistance Package - Sunroof - Tow Bar
Ordered July 17 Arrived December 17 Delivery Jan 18
