Mk2 Tiguan VCDS Tweaks
This is a sticky topic.
  • Originally posted by danintas View Post
    Hi all... HBA can be activated with the app, which I used. I had the lights set to AUTO, and the stalk forward, but high beams would not activate.
    I have the same problem and can't turn off at light settings.
    MY18 Tiguan R Line Black-162 Highline TSI
    Drivers Assistance Package - Sunroof - Tow Bar
    Ordered July 17 Arrived December 17 Delivery Jan 18
      Was it dark enough for them to come on. If you want to turn it off dont push the stalk so far forward
      HBA app works but you have to code VERY CAREFULLY to get DLA to work and the method posted by Phonebooth definitely works and can be verified by the dance the lights do in a darkened garage when you turn them on
      • It has to be really dark with no cars etc. anywhere in front for them to work..
        Unlike other cars with this feature, individual led lights in each headlight cant operate to enable the high beam to work without blinding oncoming traffic, full highbeam on both lights seems to only work when active.
        Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
        • The lights do it by adjusting the beam or by shutters, unlike the Audis which have matrix lights which can turn off individual spots of the Led,s to achieve a similar outcome
          • My advice is NOT to buy OBD11, and if you already have, chuck it in the bin. It has cost me a heap of credits to activate High Beam Assist, then deactivate, and then revert to original. Support is woeful.
            • How much do you want for yours?
              I'm thinking of getting one.
              2018 Allspace 162TSI R Line
              • Danintas, everything can be done and undone by long coding. The credits/apps(or whatever they’re called) are shortcuts for POTENTIAL features of VW vehicles. Nothing is guaranteed to automatically work on Australia market tiguans/golfs/etc.
                Coding (still easy) is the best way to play.
                Feel free to sell yours/bin it, but learn from the experience- don’t blame the tool.
                  Hardly their fault you didnt follow what has been posted about it and the app DOES work because I did it on mine no trouble. Also you can just revert it back and not need 3 lots of credits or could even have coded it back for free
                  Does you vehicle meet the criteria HIGHLINE ??????? Lots more tweaks available and not a credit used In fact I have 621 saved up and not needed
                  If you used coding it wouldnt have cost you anything and the coding for that is on the Autoinstruct site as per here and it DOES WORK
                  Enable Auto High Beam (Light Assist)
                  Enables the Auto High Beam for Highline Models Only.
                  Workman, Tools blame???????
                  Select Control unit 09 (Central Electrics)
                  Security access
                  Access Code 31347
                  Adaptation
                  1. Fernlicht_assistent – Menuesteuerung Fernlichtassistent – Change to ‘Present’
                  2. Fernlicht_assistent – Erweiterte_Frenlichtsteuerung – Change to ‘AFS, FLA, Fernlicht ueber AFS’
                  Enter Coding
                  Byte 2 – Tick Bit 0 and Bit 1
                  Select Control Unit Front Sensor Driver Assist System (A5)
                  Enter Coding
                  Byte 21 – Tick Bit 5
                  Reboot Headunit. Option will now appear under ‘Light Settings’ and pushing the high beam stalk forward will reveal the symbol with an ‘A’ within it.
                  • Originally posted by Simonr23 View Post
                    Hes blaming the wrong tool ROFL
                    • Closing windows & sun roof with 1 click on key remote
                      Hi... someone have this coding for MK2 Tiguan..!?
                      Thanks.
                      YouTube
                      • Originally posted by Hillbilly View Post
                        Security access
                        Access Code 31347
                        Adaptation
                        Enter Coding
                        Enter Coding
                        Followed directions and was going well until the last step.
                        Selected A5 entered the long coding but no Byte options came up, help please I'm only new at this so be patient.
                        How do I attach photos to a thread?
                        • Originally posted by Wazza 162 View Post
                          USe the 'Go advanced button and follow prompts
                          When u entered A5 did you scroll along to byte 21
                            There was no Byte options like the control unit 09
                              To the right of long Coding at the top is a little box with O and 1 on it press the right side of it and magically what you want will appear
                                Learning a bit more with each step but still not showing in the light settings.
                                Byte 5 isn't shown but I presume it's the light assist box, there are 2 more unlisted boxes under that one do I leave them alone?
                                Close to giving up but I must be close to activating HBA.
                                THANKS for your patience.
