Originally posted by NZ_GolfR
View Post
Mk2 Tiguan VCDS Tweaks
This is a sticky topic.
Ok, so now in my opinion we can be clear on this. The MY18 does not have TJA enabled by default.Originally posted by veew View PostUnfortunately my MY18 cat doesn't have TJA and more annoying for me, ALG.
ALG can be enabled with VCDS, look up this topic for it, it has been done many times abd works. Except TJA, some are still investigating the long coding on this but no luck on that yet.
That is what an Australian road sign looks like. New Zealand signs do not have the white rectangular backgroundOriginally posted by zzc2010 View PostAnother try
[ATTACH=CONFIG]30241[/ATTACH]
Sent from my iPad using Tapatalk2017 VW Tiguan 140TDI Highline
2012 VW Touareg V6 TDI
1985 Mercedes-Benz 380SE
Frick me, my new Lenovo tab 3 7" doesn't see my home wifi! Tried over the last couple days different things with no luck. Connects to my phone hotspot fine however the Play store can't get internet that way. Gonna have to return the tablet and see what I'm going to do
Sent from my iPhone using TapatalkCurrent:
2017 Mk2 Tiguan 162TSI, R-line, White
2020 Mk7.5 Golf R Wagon, White
Maybe your home Wi-Fi uses the 5Ghz bandwith? Check your router/modem device if that's the case and try to enable older techniques?Originally posted by veew View PostFrick me, my new Lenovo tab 3 7" doesn't see my home wifi! Tried over the last couple days different things with no luck. Connects to my phone hotspot fine however the Play store can't get internet that way. Gonna have to return the tablet and see what I'm going to do
It does connect to your phone as a hotspot so the chip should be fine.
I got a VCDS output from a Audi A3 with from the A5 module:
Code:Address A5: Frt Sens. Drv. Assist (R242) Labels: 3Q0-980-65X-A5.clb Part No SW: 3Q0 980 654 G HW: 3Q0 980 654 Component: MQB_B_MFK H06 0231 Coding: 0403070300000401012223448048A90098000E200080 Shop #: WSC 06314 790 00021 ASAM Dataset: EV_MFKBoschMQBB 001001 ROD: EV_MFKBoschMQBB.rod VCID: 3B203F9DE3EC5E1F38B-806E
Thanks, can definitely see some differences in the long coding. Any chance you can get a copy of the adaption channels as well?Originally posted by GeeMoney View PostI got a VCDS output from a Audi A3 with from the A5 module:
Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
Had the tablet replaced for a new one. Same issue, doesn't recognise both my home normal and 5GHz wifi. Bit reluctant to buy a more expensive tablet considering it is only going to be used for the OBD2 dongle.
Anyone else have the D-link 2900AL modem/router?Current:
