Mk2 Tiguan VCDS Tweaks
This is a sticky topic.
Originally posted by Hillbilly View PostHave changed that but I guess I will have to try to recode the whole thing as after I got the 'Not supported" notice it looked like the settings I changed had reverted back to original. Will be using it ant night on Sunday so we will see
UPDATE
SUCCESS
Had to change a couple of things Like extra headlight LED and do what you said and it shows the correct symbol in the dash anyway, when I have headlights on and push the stalk away from me
couldnt figure out how to get the A5 to show in hex but worked out little sign in top of phone screen changes it into hex from English.
I changed it as you did but also did the hex settings and iit seems to have done it Now to see if it works on Sunday
To be perfectly honest in the video that supposedly shows it working I couldnt tell the difference between it on or off
Hopefully it works for you on Sunday when you test it out. Make sure you’re over 65km/h (whatever the speed at which ACC engages is)
Originally posted by PDMJO View PostGlad you finally got it sorted. Unfortunately sometimes you need to do some fiddling around.
Hopefully it works for you on Sunday when you test it out. Make sure you’re over 65km/h (whatever the speed at which ACC engages is)2021 Kamiq LE 110 , Moon White, BV cameras F & B
Hillbilly did you manage to get your traffic sign recognition working? I activated mine tonight via long coding and appears to work ok. Although I've got a fault in the information control unit stating "Function limitation due to missing message" do you have the same? Appeared after activating.MY19.5 Tiguan Highline with R-Line & Sound/Vision
You’re probably getting ste standard message that happens in aus(many countries) due to the lack of syncing the signs it visualises vs an ‘authorised’ database of gps coordinated speed data to use in conjunction.
In Europe, this speed sign system is more advanced. It allows for speed limiting (cruise control changes speed automatically- cool feature) based on the signs it sees AND in the database from gps data. I think it is also capable of auto braking for corners on major roads.
Because we don’t have that data in our gps info, the system tells us at each startup, that it’s working in a limited mode(visual recognition only)
Originally posted by phonebooth View PostHillbilly did you manage to get your traffic sign recognition working? I activated mine tonight via long coding and appears to work ok. Although I've got a fault in the information control unit stating "Function limitation due to missing message" do you have the same? Appeared after activating.2021 Kamiq LE 110 , Moon White, BV cameras F & B
Originally posted by Tob35 View PostDo you have the time to write a walkthrough?
As you havent said what vehicle and what device you are using is a bit hard to advise you
I just followed the instructions and made the small changes pictured and after 5 attempts it finally seems to be workingLast edited by Guest001; 06-07-2019, 09:26 AM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
So far I've been able to get the following working on my '19 Highline SWB.
1. Undertaking prevention disabled.
2. Traffic info display.
3. High beam assist.
4. Traffic sign recognition.
Will attempt Dynamic Light Assist once I've built up the courage and read through some of the issues people have had coding it.MY19.5 Tiguan Highline with R-Line & Sound/Vision
Originally posted by phonebooth View PostSo far I've been able to get the following working on my '19 Highline SWB.
Turned off Stop start
Enabled Speed sign recognition
Enabled Litres on filling
Turned off nag on Nav
Changed ambient light colours on dash to 10
Changed rear lights to be on with DRL's
Changed rear turns to be on 50% brightness when boot open
Enabled Needle sweep
Enabled pass on left
Enabled traffic information
Changed several warning levels
Raised microphone sensitivity
Enabled HBA
Changed display to GTI
Cant enable battery level.
Dont have headlight washers
Seem to have enabled Dynamic Light Assist (Thanks to Phonebooth)Last edited by Guest001; 17-07-2019, 12:33 PM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
Originally posted by Hole46 View PostToo me quite a while to get the courage to code DLA, but it was mainly persistence after several failures and stuff ups.
Sent from my iPad using TapatalkMY19.5 Tiguan Highline with R-Line & Sound/Vision
