having a play with my new obd11 and there looks to be an option to disable the warning message for traffic sign recognition. im pretty sure it was in the same area as where you choose fusion/read only(i forget the terminology sorry) i didnt change it from active to inactive, as i just wanted to follow existing instructions, but interesting...
Mk2 Tiguan VCDS Tweaks
This is a sticky topic.
Is it possible to have the speed limit option work in Australia? I enabled two functions within the speed sign detection area, that would be good to have, but when I try to select them from the touchscreen, they say not available.
Otherwise I enabled pretty much all the turned off features and a couple of others.Last edited by Simonr23; 30-12-2018, 01:13 PM.
The Tiguan Wolfsburg has listed in its specs “dynamic cornering lights” but dynamic light assist is not listed. Does the Wolfsburg have the hardware required? I ask because Ive read through the electrical service manual and it describes the two different LED light assembly’s. Basic LED and MID LED. The description for MID lists both ‘dynamic cornering lights’ and ‘dynamic light assist’ whereas the description for the Basic LED doesn’t.
i took a Wolfsburg for a test drive yesterday and dynamic light assist wasn’t an option in the settings so wonder if this can be coded?
If the hardware is there but not turned on I find that strange and a poor descision
these lights are the type that allow dynamic cornering (its the little light on the inside of each housing that points outwards, that allows this) and 'beam shaping' (whatever the correct term is) on high beam. although i fear ive managed to disable the beam-forming side of things in my obd11 playing around, as last night it was purely auto hi/lo selection- but this was in heavy traffic.
+Originally posted by Simonr23 View Post[ATTACH=CONFIG]41753[/ATTACH][ATTACH=CONFIG]41754[/ATTACH]
Originally posted by jdstephens View Post+
Is that a Wolfsburg? And have you seen the beam shaping work after coding or was last night the first time you tried?
1) basic halogen
2) reflector LED
3) projector LED
It’s the projector LED that have beam shaping available.
FYI the reflector LED look like this:
Wolfsburg headlights...
Just got back from my dealer and took photos of the Wolfsburg headlights, I compared them to the electrical service manual and they indeed do look like the MID version. It’s seems the hardware is in fact installed on the Wolfsburg but for some reason they have locked it out via software, one of the first things I do when I take delivery is coding this to onLast edited by jdstephens; 01-01-2019, 02:19 PM.
Originally posted by tigger73 View PostSimonr23 has a Highline Allspace. As far as I am aware there’s 3 different headlight options for the Tiguan/Allspace.
1) basic halogen
2) reflector LED
3) projector LED
They look like they are the same lights that are on my MY17 R Line. What coding is required to enable the Beam Shaping and I will give it a try.
Sent from my iPhone using TapatalkCurrent Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
Originally posted by NZ_GolfR View PostThey look like they are the same lights that are on my MY17 R Line. What coding is required to enable the Beam Shaping and I will give it a try.
Has anyone been to the autoinstruct website where all the tiguan vcds coding are?
Volkswagen MK2 Tiguan OBDeleven / VCDS Tweaks List – AutoInstruct
Looks like all the coding have disappeared.
Originally posted by MartoWolfie View PostHas anyone been to the autoinstruct website where all the tiguan vcds coding are?
Activate Dynamic Light Assist (DLA) - from MY 2017 - AS.Coding
Originally posted by jdstephens View Postsomething I found which may or may not work:
Don’t really want to take it to the dealership
