Yes I have done it on mine. It works well (except for the warning you get when you start the car) and yes you can do it with obd11 as that is what I used. Instructions for doing it should be at the start of this post, if you can’t find it let me know and I’ll re-post it.
If you could repost it with HUD display it would be much appreciated. I couldn't find the instructions here.
Does the warning goes away. Do u have to acknowledge the warning?
Thought I'd start a thread on any VCDS tweaks people have had success with. I assume most of the ones that work for the Mk7 Golf would also work but will be great to know which ones actually do work! Any screenshots, pictures, videos associated with the tweaks would be great! I'll let you guys know which ones work when I get my car and get around to borrowing/buying a cable!
These are the ones I'm keen to do on my Tiguan when it arrives: 1) Deactivation of auto stop/start 2) Memory retention of seat heater setting 3) Deactivation of seat belt reminder 4) Activation of Volkswagen Traffic Message Channel 5) Driving school mode 6) Air-conditioning recirculation memory setting
CONFIRMED working VCDS tweaks: Activation of Volkswagen Traffic Message Channel: Mk7 Golf TSI & TDI - Observations and Questions - Page 56 Deactivation of auto stop/start (courtesy DV52 and VYWY - post #94, exactly the same way as Mk Golf 7)
More tweaks: LED lights in door mirrors, DRL adjustments, refuel quanity, fan speed indicator when in auto, changing comfort blink amount, guage sweep, beep when locking/unlocking car (cheers bestyjny): http://www.vwwatercooled.com/forums/...ml#post1222463
TMC, DRL option in Head Unit, Auto window closing, Dynamic Road Sign display(Cheers hoola): A guide to enable EU specific features for AU Spec Tiguans
Easy Entry/Easy Exit seat function (NZ_GolfR): http://www.vwwatercooled.com/forums/f238/mk2-tiguan-vcds-tweaks-116815-18.html#post1239603
Key Fob works when outside the car even whilst engine running (allows you to get the car running to precondition the interior and walk away with a locked vehicle): http://www.vwwatercooled.com/forums/...ml#post1256693
- This tweak is helpful on the freeway when you are not in the right lane and approach a slower car driving in the right lane.
Usually the car slows to the other cars speed (annoying if the car in the right lane travelling at 100km/hr in a 110km/hr zone) and does not proceed past them.
Deactivating this setting allows you to continue at your predetermined cruise control speed and pass the car in the right hand lane.
Hi, could you help me? Do you have the process to enable Lane Assist Tiguan Rline 2018? I tried many process but didnt work. I use VCDS genuine. Best regards.
Hello,
I got the obd11 pro and used the apps (credit points) to turn on the traffic recognition sign and reeboted infotainment but its not working. I lost the speed limit on the navigation which i expected but nothing is showing on the info display. I went through it the long coding and check every step to make sure the app made changes and everything was ok except one step in A5 module adapt road sign detection fusionmode wasnt changed to road sign detection, so I changed it manually and reeboted again but still nothing.
Can anyone help me out or have any ideas?
Hello,
I had the same problem. Until now i dont have solution!! Somebody have a solution?
Now i put everything back but lost the fusion road sign speed limit on the gps. It wont show speed limit on the infotainment gps anymore like it did before the coding.
Hello,
Have you gone into the Vehicle Settings, then Instrument Cluster and turned on ‘Dynamic Road Sign Display’?
Mine works great. I do get a quick message in the AID that says ‘Dynamic Road Sign Display is currently restricted’. Not sure this is normal or not.
Yeah I did. It was ticked and then I rebooted infotainment. Did you code it manually or used the app? Which vehicle do you have? I ll give it another go this evening
I have an Allspace. I coded it manually using OBD11 as per the guide on the auto instruct website.
I have tiguan my19 so my only assumption they changed something between my17/18 to my19 models. Anyways going to try it now again and go for a drive. Fingers crossed
