Mk2 Tiguan VCDS Tweaks
This is a sticky topic.
  • Anyone figure out how to enable the navigation maps to be displayed on the digital cockpit and the radio display at the same time?
    Thank You
    Paul
    • I think it is only possible using the media pro media unit.
      • What are the basic specs of your car and what infotainment unit do you have?
        MY18.5 Tiguan 162TSI RLine
        • Originally posted by Moveingfaster View Post
          Thank You
          Paul
          Home button, can setup what displays you want
          Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
          • Originally posted by INASNT View Post
            I have a US Tiguan that doesn’t allow me to display the navigation map on both displays at the same time.
            • Hey guys, got my Tiggy (Comfortline, with Driver Assist and Lux packages), and looking to make a few tweaks to it. My wishlist includes:
              1. Traffic Alerts
              2. Speed Limit on dashboard instrument (active info display) - is this actually possible?
              3. TJA
              4. Changing which lights work for DRL
              I'm not sure if I should be looking at getting an OBDeleven or whether I can pay someone to do this for me given it looks to be a once off (and I don't have an android). Any thoughts on where I could do this? I'm based in the inner-north of Melbourne.
              D
              • Hello ,
                For anyone he is interested to activating Trailer Assist, you have coding here (OBDeleven).
Name:	Trailer assist.png
                • Hello,
                  Does anyone know the coding(OBDeleven) for steering wheel heating? Thank you
                  • Originally posted by adysh View Post
                    Hello,
                    What do you want to do? I made changes to mine with their apps
                    • I want to know what coding must to do , for activated the heating in steering wheel .I maked something, but it's not right.How did you do the coding?
                      • Doesn't seem like this question has been asked, but apologies if it has:
                        With activating Traffic Sign Recognition, does this information feed into the ACC? ie if i'm cruising along with ACC set to 80 km/h and it picks up a sign saying the limit is 100km/h, would it automatically register that speed, and increase the car's speed to 100?
                        Or is it merely a tool for monitoring the posted speed limits?
                        • Originally posted by PDMJO View Post
                          It’s just monitoring and displaying the detected speed limit on the dashboard.
                          Sent from my iPhone using Tapatalk Pro
                          • Originally posted by NZ_GolfR View Post
                            Also if anyone is interested I found that if you have electronic seats you can turn on the Easy Entry/Easy Exit function:
                            Seat Adjustment Driver Side (36) - Coding - Easy_Entry_front - Change to Active
                            This will slide the seat all the way back when you turn the car off to allow you to get it out and then when you get back in and turn the car on it slides forward to the saved position.
                            I've activated the Easy Entry/Exit function, however, it only slides the seat back for about a second, then stops. Any of you have a clue as to what might be going wrong?
                            • Long coding
                              Control unit: 6C Camera System Rear View
                              I can't find 3D_Presentation after entering long code
                              I use VCDS
                              • Long coding
                                I use VCDS
