Mk2 Tiguan VCDS Tweaks
This is a sticky topic.
  • Originally posted by Steve2010 View Post
    Hi greygoose_x. My DLA works a Treat. I have video but can't upload to this thread. Can someone assist? I'm happy to email the vid. Looks great and you can see it clearly in action.
    Yep, upload to Youtube, and post the video link here!
    • I tried using the app in obdeleven to activate traffic sign recognition but it doesn't seem to be working on my MY19 wolfsburg. Has anyone else got this working via the app?
      If I want to do the long coding method should I undo the app version first? 100 credits to undo something that doesn't work is a bit unfair
      • Originally posted by Psych101 View Post
        I had the same problem but got it working, the app did most of the job so don't undo it.
        There was one more setting that required changing:
        Control unit A5
        Adaptation
        Road Sign Detection Fusion Mode
        Change to ‘Road Sign Detection’
        Reboot the Infotainment unit
        And then in the infotainment Vehicle settings, Driver assistance settings there is an option to show in instrument cluster which displays it on the Virtual cockpit, but this setting keeps disabling for me for some reason and I need to re-enable it.
        • Originally posted by impsta View Post
          Control unit A5
          Adaptation
          Cheers. Will give it a go later today.
          Annoying you to have to re-enable and hope there is a fix for that too
            Control unit A5
            Adaptation
            Followed your advice but had to do the changes in control units A5 and 17 below as well. Works properly now and stays on unless I switch it off (don't have to re-enable).
            Recommend checking every step below has been done in yours to see if this solve the issue of having to re-enable on start-up.
            • Hi guys, I am new to this forum and saw a lot of outstanding information.
              I have a Tiguan only with a rear view camera. Could it be possible to code the camera so that it can be activated when i click on the parkpilot button, rather than having to activate it by putting the reverse gear.
              Thanks a lot!!
              • Hey Gents,
                Lately I’ve done a lot of research and decided to buy my first VW TIguan and collect it on the 22nd of this month. I’ve ordered a Wolfsburg edition and have been reading up on this forum about all the various mods you have all done and there are some pretty cool
                things.
                The main wuestion I have is should I buy the obdeleven or go with the ross tech to get started on this? It seems most obdeleven posts when using the app don’t always work so just wondering which is best to go with? Also with the obdeleven token system, if you run out of tokens is it costly to get more or how do you get them? Open to either option as you guys are the pros.
                background - I have good IT background Incase that sways decision.
                cheers
                • Originally posted by CjsTiguan View Post
                  Hey Gents,
                  things.
                  cheers
                  It seems to me the OBDEleven is the way to go (due cost), but I don’t have experience with either. My OBDEleven arrived a couple of weeks ago but I’m still waiting on my car to use it with.
                  • Really wanting to see a video with DLA coded on the Australian models of the Tiguan (preferably Wolfsburg). I’m hoping to get this to work when mine arrives.
                    • Originally posted by jdstephens View Post
                      Super keen to see this too, it’s been done - just need to see it in action!
                      • Hi All, can someone please repost the OBDII code to enable showing dual lane in the AID? I can’t seem to find it but remember seeing it somewhere. Thanks.
                        • What do you mean by dual lane?
                          Registering interest. Is it the option to deactivate ‘pass on left restriction’ (or whatever it’s called)
                          • Sorry I should been clearer with my request.
                            I have an my17 model Tiguan and the dual lane is disabled by default in AID on drive assist. So I wanted to enable that and also deactivate the left lane overtaking restriction.
                            • Originally posted by axe0210kimo View Post
                              I tried the coding you posted, but it only changed the skins not "Two line(rows)"
                              Originally posted by artful View Post
                              5F Information Control Unit
                              Long Coding
                              byte_17
                              Bit 05
                              In a UK 2016 MK2 tiguan, it's bit 3.
                              • Does aus have the heated steering wheel fitted- so I can code that feature on?
                                Cheers.
