Mk2 Tiguan VCDS Tweaks
This is a sticky topic.
  • The swb wolfy has the same lights as the Comfortline and highline versions. It’s brochure is just messed up. You have to go down to bottom of page4 of the brochure to get the full headlight specs.
    All swb models have dynamic cornering lights, And the passive ones. This to me says that with the driver assist pack, you should be able to code in DLA. As having the passive cornering lamps is the one piece missing from the normal leds vs ‘mid’ leds.
    I admit that I’m not 100% sure on this though. I’d need to see a DAP optioned allspace Comfortline next to one that isn’t now optioned.
    Confirmed as correct. See petec’s post on page 60.
    • Originally posted by Simonr23 View Post
      Makes sense, will have to look into it. Thanks for the info 👍
      • Originally posted by GreyGoose_X View Post
        My Wolfsburg will arrive at similar times too. Very interested to see how you go with this
        My boat is still anchored off the coast of South Africa, so I don’t reckon I’ll see it until March. Hoping that’s not the case!
        • Is it possible to re-activate the sunroof ambient lights via vcds/obdeleven?
          My dealer is struggling. They’ve done the recall work(fuses) and when they did what they thought would reenable them(shouldn’t have ever been disabled according to their system...) nothing.
          Cheers for any help.
          • I've tried this and keep getting error messages as well. I'm going to have another play around shortly. I'm taking about the DRL.
            • Hi bushpig667, can you supply me with your long coding on 4b please. I've tried to clear my error message for the song of the DLA but I keep getting an error message saying, cornering light (afs), with the orange exclamation mark on the dash. Have tried everything as stated above but no luck. Followed the instructions correctly except at front sensor a5 coding. It is a bit different but I've set byte 19 to 30. The rest is identical. Tried resetting many times but no go. Any help would be appreciated.
              • Originally posted by Steve2010 View Post
                A5
                000307060000010100022346C156A90098000E300040
                4B
                000000050100085207104F010A000000000000000000000000 0000000000
                For my car, after I had completed the coding, changing byte 9 to 10 in module 4B cleared my AFS fault.
                Hope that helps.
                • Thanks mate I'll give that a try. Just out at the moment but heading home shortly. I'll try and let you know.
                  • Thanks bushpig667. Problem solved and fixed. The important part was changing byte 9 and 19 to 10 after all the coding is done. Took the fault away instantly. Now to try the lights at dark. Still daylight here in Western Australia!
                    • Hi all does anyone know how to keep adaptive Lane guidance on permanently? Mine keeps unticking itself every time I turn the car off and on. Very annoying?
                        Make sure to set Bit 3 in Byte 14 of A5 front assist camera.
                        • Hi bushpig667 just to let you know the DLA works a treat! Tried them tonight and boy do they work well! Thanks again bushpig667 for your help on this. Greatly appreciated. Owe you one!
                          • Thanks kamold. I'll try this in the morning and let you know how I go.
                              Nice work! Any chance of posting a video with the DLA in action?
                                I tried to do a couple videos but unfortunately my cameraman skills are weak and it’s just a blurry mess. Maybe steve2010 can do better!
