Cool, thanks for that. Seen those on ebay, I will grab one to give it a go.
MK3 Random Thread
I have always found I got better fuel economy using the Caltex Vortex 98 in the 1.8l CL. Even if I don't get the 4c/L off with the Shell V-Power at Coles Express, it worked out more cost effective to pay more per litre but the extra mileage meant that I saved myself a couple of dollars a tank.
I have heard that the BP 98 is the best fuel of the lot but without a BP close by I do usually fill up with it.1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
1996 Vento GL (white) - RIP
i was never one to fill up at United..... A good friend of mine swore by it, one day out of desperation i filled up my Stag 2+ mk6 gti with their 98 octane and 2 things happenedOriginally posted by stefcio007 View PostI'm not sure what you mean? I've been putting Shell Vortex 98 for a really long time (previously used BP's 98 ), just wondering if United 98 petrol is similar in terms of quality to Shell's.
1 i had a more responsive car within a few hundred meters of exiting the station
2 i went from getting 550 from a tank to just shy of 600
Now if i ever pass a United i check to see if i need fuel as there arent many in Sydney
also on the way back from QLD in a VR6 that had a miss fire on the leg that was done on a tank of United from Coffs, the miss fire disappeared lol
go figurePolo GTI
T-Roc R
Tiguan R
Tiguan 162 Allspace Wolfsburg
Going to try and fit a new ignition switch to the vento to see if that fixes my power window problems! Back window wont go up at all and drivers window now wont work! Apparentky the ignition switch causes a whole lot of problems with electrics!
^ ball joints, wheel bearings
Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
Originally Posted by JoeVR
I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
how hard is it to replace a door for a 5dr mk3 specifically the driver's door?
i saw this: How to replace a door on a MKIII
but what about stuff like the vacuum lines for the lock and speaker cables etc?
are they all part of that twist harness?
thanks2010 Jetta 125TDi DSG
1994 Golf VR6 Manual
The vacuum line is visible in the photo. I assume speaker cables would go through that twist cap too, if not just disconnect them from the speakers before you take the door off and pull them through.Originally posted by doridori View Posthow hard is it to replace a door for a 5dr mk3 specifically the driver's door?
thanksPast - '95 VW Golf MK3 VR6
would ignition switch be causing it if its only some windows?Originally posted by dubster99 View PostGoing to try and fit a new ignition switch to the vento to see if that fixes my power window problems! Back window wont go up at all and drivers window now wont work! Apparentky the ignition switch causes a whole lot of problems with electrics!
back windows are common as for the wiring splitting which can upset the front windows
rear control arm bushesOriginally posted by stefcio007 View PostI have a feeling my lower control arms (both) are worn out. How much is something like that to replace? Anything else that could be done at the same time?
front control arm bushes if you think they are worn but usually arent
strut top bearings and bushes
tie rod ends or the whole assembly
ball joints
sway bar end links and bushes
bearings if you are super keen.
pretty simple.Originally posted by doridori View Posthow hard is it to replace a door for a 5dr mk3 specifically the driver's door?
thanks
make sure your vacuum lines and electric connector are the same. I had to swap wiring/vacuum lines in the door as there was some differences between carsLast edited by dylan8; 15-03-2016, 05:36 PM.
We bought a mk3 cabrio on the weekend. Speedo and tachometer work but sometimes when we start the car, they don't work. What should I be checking to ensure they work all the time?
Thankyou.Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
