MK3 Random Thread
Thanks feenix74, tis the dance of death im seeing. So new cluster required. Appreciate your helpMk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
Originally Posted by JoeVR
I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
Originally posted by dylan8 View Postwould ignition switch be causing it if its only some windows?
back windows are common as for the wiring splitting which can upset the front windows
@dubster99, my VR used to run rough sometimes and shudder to the point I would stop and restart it for fear of something bad happening. Usually if revved too high. New ignition leads fixed the issue completely. Not sure if you would have the same issue in a 2.0 but leads are leads. How old are your leads? If fairly new at least you can eliminate that.Past - '95 VW Golf MK3 VR6
Originally posted by Speed View PostThanks feenix74, tis the dance of death im seeing. So new cluster required. Appreciate your help1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
1996 Vento GL (white) - RIP
Have no idea how old they would be they came with the car, drove back from work lastnight and it started and ran fine about 40 mins into the drive home it started to stutter when I put my foot down for a few seconds then when the revs were up over 2k it stopped which is weird. Ill try new leads and plugs first to eliminate them, also just going to clean the MAF and TB too.
Anyone ever installed mk4 leather seats into a mk3? I was thinking about it after seeing your ad MilkIsYum. Seen tutorials for the front seats but not the back.
Let me know if anyone has any up my way, I would buy MilkIsYums but don't want to pay more in postage then for the seats.
This definitely seems like something I need to do.Last edited by browntown42; 20-03-2016, 04:35 PM.Mk3 2.0. Mk3 VR6 CC. Future Mk2?
Originally posted by browntown42 View PostAnyone ever installed mk4 leather seats into a mk3? I was thinking about it after seeing your ad MilkIsYum. Seen tutorials for the front seats but not the back.
weld in mk4 rails, or swap/cut up base of seats and fit mk3 parts.
rears need the clamping point at the top changed.
cant recall what happens down the bottom, think they need to be swapped to mk4 ones too
Doesn't seem too bad, should be fun if I can find a good set of leather seats.
And just my luck, went out tonight and came home missing the parts car key which was the only one with no spare. ****
where do I go from here, bother to ring a auto locksmith? Only one 1 on the cheap because the car is being either sold for cheap or scrapped after I'm done with itMk3 2.0. Mk3 VR6 CC. Future Mk2?
Picked up a PCV boot including valve in pretty good nick for $25. Finally I can properly fix my day one problem and not make it look like a hack job.
Also, had a laugh reading my old RWC the other day, it stated my front rotors were undersized...Past - '95 VW Golf MK3 VR6
Nice. Must be the last one on earth that hasn't disintegrated.
My ebay coolant hose kit came with a hose that deletes the PCVMk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
Anyone want a set of mk4 r32 wheels for their vr6?
Would sell for 750.
PM me if interested.
Cheers!Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
Some questions for my new RS's.
1. What tool do you use to undo the bolts to take them apart?
2. Do I need to take the tyres off before I do this?
3. They are 16x8, Will 195/45/16 or 195/50/16 tyres will give me a bit of stretch right? But which will be closest to VR6 total wheel diameter?
Just googled how to pull apart BBS rs wheels. Has most of your answersMk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
