Discover Media retrofit
  • Originally posted by MIG View Post
    I have had one of these, it uses the steering angle sensor to approximate the high line lines, this is passive on the can network unlike the highline unit.
    so how come i can't get it to work then?? supposed to be an easy hook up, connect all the wires as per diagram and bam, supposed to work...well not in my case
    i mean everything else with the mib unit is spot on, all works except the camera.
    is it a matter of setting up some key adaptations in 5F module?? or just this particular camera just plainly won't work in my 6R.
    SO in that case i can just return it, and get the t-roc 2GD....part # that Kamold suggested....it's only $180 canadian on ailexpress
      Hmmm....... OK that makes sense - but I'm not sure what is meant by "approximate" high-line lines?
      No offense intended, but isn't this a bit like being "approximate" dead (meaning that either the high-line lines are displayed and usable, or they are NOT)?
      AND, if the high-line lines are displayed and usable on the low-line camera - why would anyone buy the seller's high-line camera option?
      Again, no offense intended in my request for clarification - I'm simply trying to understand these non-OEM cameras
      Don
      • Originally posted by DV52 View Post
        Don
        No offense taken. These aftermarket cameras are interesting units, some have better than OEM picture quality, but as there is no way to calibrate or load parameters like the OEM units, so they have been made with a one size fits all. the lines move but might not show the path of the car 100% or the distances with the lines correct to the car.
        Still they are pretty good, am I probably would of kept mine, but I ended up pinching the video cable and breaking it.
        • Originally posted by kamold View Post
          Confirm that the following adaptation channel is set to 'FBAS':
          IDE03471-ENG126143-Vehicle configuration-RVC_video_input
          Also confirm with a multimeter that the camera is getting 12v.
          i checked, i don't have such parameter to choose in adaptation; now what??
            VPS should be disabled. That's only for OEM highline control module. Was worth a try.
            You don't have a PDC module so you need to disable PDC adaptations:
            ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc
            ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high
            ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A
            and these 3 are already NOT ACTIVATED....or as you call them DISABLED
            • Is this available?
              • Originally posted by Specisl View Post
                Is this available?
                ????????????????? Is what available The thread is about fitting the unit, not if its for sale
                • ok so i got the T-roc 2GD 827 469 low res RVC, now what??? how do i hook it up
                  i know where the blue wire goes, it goes to the reverse light and there is well as the blk and clear (which go to the blue connector)
                  but there is another black connector that looks like the wires brown and purple would go into (don't know which wire goes to what pin yet), but WHERE does that connector plug into??
                  and there is also a green/black wire that has a pin attached to it and DON"T know exactly where that one goes either....POWER maybe?? and if so is it constant power or SWITCHED power??
                  i've attached some pictures of all this
                  THANKS again in advance.
                  • This is how the power is connected:
                    KL30=constant power
                    KL31=ground
Name:	RVC Low wiring.jpg
                      KL30=constant power
                      KL31=ground
                      [ATTACH=CONFIG]55893[/ATTACH]
                      so in my situation/application, which wire is the KL30 and which one is KL31
                      i have a BROWN wire as well as a PURPLE wire which i assume they to to that black 2 pin connector, but i don't know which wire goes to which pin
                      and then i have green with a black stripe wire that has a metal pin crimped to it and i DON"T know where that one goes either
                      thanks.
                      • Looks like purple is power and brown is ground.
                        • Green is your ign switched power for the camera AKA KL15
                          • ok today i tried to install this t-roc RVC but what i don;t understand is WHERE is this set up getting the 12V constant power to the rear emblem?? i measured the voltage or checked for voltage at the 2 pin connector ( see attached picture) and i DON"T get the 12V constant there.
                            i've hooked up the green 12V switched wire, the blue one to the reverse light, but i'm at a loss that there is NO 12V constant at the factory 2 pin at the back.
                            how did the original emblem work then using that 2 pin connector??? as before i was able to open up the trunk without any issues??
                            what am i missing here??
                            thanks again in advance.
                            • You put those terminals into that connector in your hand, and plug that into the one under your thumb.
                                i did that after i posted the reply, as i "gambled" that that is where it SHOULD go adn nothing happened.
                                i closed the trunk and then when i wanted to open it again i couldn't. WHERE is the RVC supposed to get 12 constant power??
                                funny thing, that after i unplugged that particular connector and plugged it into the stock OEM emblem, while inside the car in the trunk and pushed the emblem, the trunk opened.....but it will NOT open with the T-roc assembly/RVC/emblem
                                so my question is, WHERE is the stock OEM emblem getting it's 12V constant power?? so that the trunk opens when the stock OEM emblem is used?
                                so i'm at a loss....is there a SETTING now i have to do with vagcom now that i'm using the T-roc assembly???
                                to recap
                                -green wire is connected to a switched 12V
                                -the brown wire and purple wire are pushed into the black connector that came with the RVC and it is mated to the factory connector/plug
                                -the 2 wires black and clear go to the blue connector at pin 6 and 12
                                -blue wire is connected to the reverse light
