1 of 2
2 of 2
Discover Media retrofit
Saturday,18,May,2024,16:55:13:11842
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 24.5.0.0 (x64)
Data version: 20240429 DS355.0
Ross-Tech: Home
VIN: WVWPF7AJ2DW009721 License Plate:
Mileage: 70000km-43495mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 05 08 09 15 16 17 19 22 25 2B 2E 37 42 44 46 47 52 55
56 62 72 77
VIN: WVWPF7AJ2DW009721 Mileage: 70000km-43495miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: Cannot be reached 1100
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CRZ) Labels:. 06F-907-115-CDL.clb
Part No SW: 5K0 907 115 M HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0030
Revision: 5BH21--- Serial number:
Coding: 0403010A180F0160
Shop #: WSC 85573 554 600234
VCID: 346C150857152D3697-8060
VINID: 9E69E058745A0949C00091C2047B2F8BA6
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 144BE00C49228003281207E6921A0141310000
Shop #: WSC 01357 011 00200
VCID: 7DFAF02CE4DF2C7E28-8028
Address 05: Acc/Start Auth. (J51Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 085 0902
Revision: 00085000 Serial number: 0175854123 Dataset Number: 5K0116v____ 5K0C
Coding: 030C0C
ASAM Dataset: EV_KESSYPQ35G A02013
ROD: EV_KESSYPQ35G_A02_VW32.rod
VCID: 346C15089F152D3697-8060
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 35D 907 044 B HW: 35D 907 044 B
Component: Climatronic H03 0303
Revision: 00001K02
Coding: 0008002002
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_ACClimaBHBVW411 A01001
ROD: EV_ACClimaBHBVW411_VW36.rod
VCID: 2648FF4059C94FA619-8072
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 1K0 937 084 J HW: 1K0 937 084 J
Component: BCM PQ35 B 111 0709
Revision: AB111709
Coding: 61180ABF8CEB0EC4108800C170000B4448850486675D8DB0E4 8420248040
VCID: 356A280C9C6F343EA0-8060
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 18051 26 0512
Coding: 009F95
1 Fault Found:
00061 - Footwell Lights
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 5
Fault Frequency: 1
Reset counter: 59
Mileage: 70008 km
Time Indication: 0
Date: 2018.10.09
Time: 16:54:43
Freeze Frame:
Term 15 On
Voltage: 12.15 V
ON
ON
Term 50 Off
OFF
OFF
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA2BYNS Dataset Number: 5K0003v__B_ 0069
Coding: 00003132
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3F864A24A653FE6E7A-806A
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME2F05756BZZZ1
Front Passenger's Side Airbag Crash Sensor:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME61286066ZZZT
Rear Side Airbag Crash Sensor (on driver's side):
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME7E06153CZZZ$
Passenger side rear thorax airbag crash sensor:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME5C101565ZZZR
Crash sensor for front airbag: driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME3651782CZZZK
Crash sensor for front airbag: front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME704B782CZZZS
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 521 BR HW: 5K0 953 569 E
Component: LENKS.MODUL 014 0140
Revision: FF010041 Serial number: 20120525301907
Coding: 100A140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DFAF02CECDF2C7E28-8028
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0033
Coding: 820000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K6 920 873 C HW: 5K6 920 873 C
Component: KOMBI H05 0705
Serial number: 00000000000000
Coding: 370D00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 36682F0089693F26A9-8062
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 R HW: 7N0 907 530 H
Component: J533 Gateway H42 1632
Revision: H42 Serial number: 180512F2002532
Coding: 350002
VCID: 3F864A24AE53FE6E7A-806A
1 Fault Found:
03272 - Control Module for Audio Interface
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 70008 km
Time Indication: 0
Date: 2018.10.09
Time: 16:54:46
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BR 907 554 C HW: 0BR 907 554 C
Component: Haldex 4Motion 3018
Coding: 0000005
Shop #: WSC 00000 000 00000
VCID: 458A58CC0C8FA4BE30-8010
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0705
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
VCID: 6AD0CB708D51ABC6FD-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 B HW: 5K0 905 861 B
Component: ELV-PQ35 H20 0240
Revision: 00000000 Serial number: 12000114103003
Coding: 4100000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X_VW32.rod
VCID: 2F661A6476330EEEEA-807A
I HAD TO DO IT IN TWO PARTS BECAUSE I WAS EXCEEDING 10000 CHARACTERS
Address 2E: Media Player 3
Cannot be reached
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2119
Coding: 0001204
VCID: 31621C1CA807181EFC-8064
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 251 3305
Revision: 00H22000
VCID: 377622044663C62EB2-8062
Address 47: Sound System (R12) Labels: None
Part No HW: 5K0 035 456 B
Component: KonzernAmp 8K H07 0368
Revision: -------- Serial number: EAA085A0027287 Dataset Number: 1K8050v____ 5K04
ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
ROD: EV_AudioVerst8KanalBNO1_VW12.rod
VCID: 55AA888C342F143E40-8000
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001204
VCID: 32601310AD01230685-8066
Address 55: Headlight Range Labels: 5M0-907-357-V2.clb
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0148
Revision: 00H04000 Serial number:
Coding: 1479708
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0005
Coding: 00000022
Subsystem 2 - Part No: ID-R fehlt Labels: ID-55-02.CLB
Component: AFS-Lst.-Modul r ....
Coding: 00000255
5 Faults Found:
02234 - Right Headlight Power Output Stage (J66
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 70008 km
Time Indication: 0
Date: 2018.10.09
Time: 16:54:42
Freeze Frame:
Voltage: 11.93 V
Speed: 0.0 km/h
ABS 1
01042 - Control Module; Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
02657 - Power Output Stage for Right Headlight (J66; Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 59
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0001168
Shop #: WSC 01357 011 1012552
VCID: 356A280C5C6F343EA0-8060
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0001168
VCID: 36682F0041693F26A9-8062
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 03:00)--------------------------
^^^^ yes, the SCAN confirms that the Gateway module is unable to communicate with the modules on the infotainment CAN bus!
However- given your latest scan, I'm not sure if the "cannot be reached" errors are due to the fact that these modules refer to the original factory modules that were replaced by the new MIB unit.
I note that your SCAN does NOT report a module at the normal CAN address for a MIB (which is address hex5F) - but I assume that the MIB is operating correctly (other than the RVC operation). Lots of aftermarket MIB-lookalike non-OEM units avoid SCAN reports
Normally, a MIB not appearing on a SCAN would be problematic - but because the infotainment set-up on this car is now very non-OEM, anything is possible. So it's anyone's guess how the SCAN is meant to report a healthy Infotainment CAN arrangement for the retrofitted MIB on this car!
After viewing the full-SCAN, my gut-feel is now that this car might need to have its GIL (Gateway Installation List) adjusted - but again, the fact that there is NO 5F module in your SCAN and the MIB is working, makes me hesitant to suggest this option!!
The other concerning issue is the RVC, itself - meaning that the non-OEM camera that you retrofitted is NOT like a normal OEM low-line camera
You said in a previous post:
Originally posted by RBmk6R View Posti don't want the fancy high res camera that the lines turn with the steering wheel turns...i want something basic like this low rec RVC
Smoked black badge camera Dynamic parking line Golf6/7 GTI Polo EOS Beetle PassatCC RCD330 plus | RCD330 Plus | RCD340G
However, clearly the non-OEM camera that you installed DOES use CAN high/low wires, but I assume from your words above that it was sold as a low-line camera. So something is very different about the RVC that you installed - no surprise I guess because it's non-OEM equipment!!
So bottom-line = it's possible because of the non-OEM MIB that you first installed that the "cannot be reached" errors in your SCAN might be a "red-herring" for the camera problem - maybe?
I suggest that you try a couple of experiments:- Remove the CAN high/low wires from their connections to the CAN network.
- Cleae ALL errors and then make a fresh SCAN.
- Do the same "cannot be reached" errors re-appear? If so, the SCAN errors result from the retrofitted MIB (i.e. the errors are dispositive to the RVC problem)
- Refit the CAN high/low wires
- Change the current status of Byte 19, Bit 4 (Rear View Camera (RVC) Low installed) on the long-code for the 5F module (the MIB). Does the image appear on the MIB screen when reverse-gear is selected?
- If the problem persists- post-up a copy of the full MIB long-code string and the values for the 2 x adaptation channels below:
- Car Function List BAP Gen2 → VPS_0x0B
Car Function List BAP Gen2 → VPS_0x0B_msg_bus
DonLast edited by DV52; 20-05-2024, 11:28 AM.Please don't PM to ask questions about coding, or vehicle repairs. The better place to deal with these matters is in the forum proper. That way you get the benefit of the wider expertise of other forum members! Thank you.
Originally posted by DV52 View Post^^^^ yes, the SCAN confirms that the Gateway module is unable to communicate with the modules on the infotainment CAN bus!
An OEM low-line camera does NOT use CAN-high/low wires - it's a simple dumb device that hangs-off the MIB. The OEM high-line camera is the version that is connected to the CAN network!
Don
thx for the reply
so to answer your question, YES the MIB STD2 PQ +/NAV part #5C0 035 684 (that i installed in my mk6 R to replace the factory RMS-510) works just fine apart for the RVC not displaying on the screen when i put the car in reverse.
i had someone program the MIB unit programmed with the options that my mk6r came with, dynaudio amp. etc, etc...and he asked me if i want the RVC enabled as well, i said YES as i was gonna get one later ON.
and even before i had bought this RVC i was still getting the black screen when putting the car in reverse, and i think that is the case because the MIB is enabled taht way for teh RVC, even though there wasn't one installed.
i bought this type of RVC as i've seen some videos or posts of someone that had bought one and it worked with his MIB unit.
hey Don,
so i cleared all codes and did another scan as per your recommendation with NO CAN lines connected. here's the LOG and what do you make of this?
part 1 of 2....because i was exceeding the 10000 characters
Monday,20,May,2024,11:31:58:11842
Ross-Tech: Home
56 62 72 77
Revision: 00H31001
Coding: 030C0C
Revision: 00001K02
Coding: 0008002002
Revision: AB111709
Coding: 009F95
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 60
Mileage: 70008 km
Time Indication: 0
Date: 2018.10.11
Time: 11:32:38
Freeze Frame:
Term 15 On
Voltage: 12.45 V
ON
ON
Term 50 Off
OFF
OFF
Coding: 00003132
Coding: 100A140000
Coding: 820000
Coding: 370D00
Coding: 350002
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Mileage: 70008 km
Time Indication: 0
Date: 2018.10.11
Time: 11:32:44
Coding: 0000005
Coding: 000007
part 2 of 2
Cannot be reached
Cannot be reached
Coding: 0001204
Revision: 00H22000
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5K0 035 456 B HW: 5K0 035 456 B
VCID: 2952F47C48D760DE34-807C
Coding: 0001204
Coding: 1479708
Subsystem 1 - Part No: ID-L fehlt Labels: ID-55-01.CLB
Component: AFS-Lst.-Modul l ....
Coding: 00000255
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0005
Coding: 00000022
5 Faults Found:
02233 - Left Headlight Power Output Stage (J667)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 60
Mileage: 70008 km
Time Indication: 0
Date: 2018.10.11
Time: 11:32:39
Freeze Frame:
Voltage: 12.35 V
Speed: 0.0 km/h
ABS 1
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 60
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
Address 56: Radio
Cannot be reached
Coding: 0001168
Coding: 0001168
Cannot be reached
End-------------------------(Elapsed Time: 02:59)--------------------------
Originally posted by dv52 View Postif the problem persists- post-up a copy of the full mib long-code string and the values for the 2 x adaptation channels below:car function list bap gen2 → vps_0x0
car function list bap gen2 → vps_0x0b_msg_bus
I'm not sure how you access this module given that it doesn't appear in your SCAN - maybe you can access the 5F module directly from this screen:
and even if i can access it, which BYTE and BIT you want me to access of the particular LONG CODE?
Originally posted by RBmk6R View Postif i can access it, which BYTE and BIT you want me to access of the particular LONG CODE?
DonPlease don't PM to ask questions about coding, or vehicle repairs. The better place to deal with these matters is in the forum proper. That way you get the benefit of the wider expertise of other forum members! Thank you.
hmm........... OK, clearly the software switch for the low-line camera is set. Assuming that this non-OEM camera (which surprisingly uses CAN high/low wires) is indeed a low-line camera- this should be OK.
Check that the values for the 2 x adaptation channels below in the 5F module are set to not active:
- Car Function List BAP Gen2 → VPS_0x0B_msg_bus
Also, check that the video-signal terminations on the QUAD lock connector for the coaxial cable is correct - meaning that the screen-earth wire (Black wire in the picture below) is connected to pin #12 and NOT to pin #6.
Finally, if you still can't get the camera to work - maybe try telling the MIB that this is a high-line camera? I'm totally guessing of course and this is a "desperation" suggestion!! To do this, remove the tick from Byte 19 Bit 4 and set:
- Car Function List BAP Gen2 → VPS_0x0B > active
- Car Function List BAP Gen2 → VPS_0x0B_msg_bus > terminal 15, or comfort data bus, or infotainment data bus
If ALL my suggestions above fail - I'm all-out-of-ideas!!
Again, the problem with this equipment is that it's non-OEM, maybe the seller can help?
DonLast edited by DV52; 23-05-2024, 11:56 AM.Please don't PM to ask questions about coding, or vehicle repairs. The better place to deal with these matters is in the forum proper. That way you get the benefit of the wider expertise of other forum members! Thank you.
From the VCDS Open Controller screen for the 5F Module - select Adaptation - 10
In the Search box below, enter "ENG117712" and ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B should appear in the Channel (1B) box. If it doesn't, click on the down-arrow on the right-side of the Channel (1B) box and select the channel. Make the suggested change and press Do it! - follow the prompts to implement the change.
Repeat for the 2nd channel by entering "ENG117713" into Search box
DonLast edited by DV52; 23-05-2024, 12:18 PM.Please don't PM to ask questions about coding, or vehicle repairs. The better place to deal with these matters is in the forum proper. That way you get the benefit of the wider expertise of other forum members! Thank you.
