Originally posted by NickHoltOz
View Post
This is a sticky topic.
It may be recoverable. I am assuming you meant 4120 firmware. If you cant get someone in Sydney, PM me.08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
http://photobucket.com/gregsr32
I tried to update an RNS510 rev D manufactured late 2010. I was able to extract the PIN as VW wasn't able to give the owner the correct code. I also changed the DVD region to "0" (region free). Map update wasn't a problem. My issue is that it had sw 1580. It would not accept 4020 or 5238 as an update. It locked up and would reset with the three fingers. I was able to get it back using the motordiag program.
Does anyone have ideas on this?08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
I don't think 1580 is an eu/au firmware off the top of my head. Might be Chinese or US. Check the system detail numbers in diag.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
It came out of a MK6 car in a wreckers. I should have done a screenshot when it was connected to the computer. Unfortunately, the owner is in Central Sydney and I am in Orange. A VW dealer charged $80 for the pin and it didn't work which is where I stepped in to find the pin to unlock the unit. If a DIY day comes up, I will get more info. It stumped me as it was a newer revision with a strange firmware that would not let it update. Nav worked fine on his trip home and the radio is now useable so all was not lost for a drive to the country
I think its a Chinese unit.
Only references to 1580 I can find are on Chinese websites.
If the radio tuner works (ie has correct frequencies available on bands), then it MIGHT be possible to change the device IDs via Setconfig or RNS Manager and then flash an EU/AU firmware on it. But I would give that maybe a 30% chance given I've never tried it. Could end up with a dead mainboard. But not too much to loose I guess in this case.
I'm happy to have a crack at it if for nothing more than to see if it can be done...2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
I will let Paul know. They are much nicer with the extra bits in the newer firmware. It doesn't currently have RDS or the AC displaying. At this point though, I think he is happy as it is an upgrade from the standard radio without knowing much about the extra features.08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
Hi Pete. I have an original V6 map disc from a dealer. Your welcome to use it and post it back to me or I can organise a copy for you..Originally posted by pete_syd View PostHi all,
Does anyone have a working link to the V6 or V7 maps for AU?
I've been search the forums all morning and the old V6 link seems to be broken.
Thanks in advance,
Pete
Cheers, George
Best not mention copies on here any more. Several posts have been removed and one poster banned over this.Originally posted by hishothouse View PostHi Pete. I have an original V6 map disc from a dealer. Your welcome to use it and post it back to me or I can organise a copy for you..
Cheers, George
Just a friendly warning Buy one and be legal.2021 Kamiq LE 110 , Moon White, BV cameras F & B
A DNS or a RNS 510 If a RNS you do it with a DVD yourself Don't need a cable.Originally posted by shane_in_oz View PostHi All
I am looking for someone with a vagcom cable that knows how to upgrade the sw on a DNS510 1T0035680D from 3970 to xxxx so that I can get FM text on screen
cheers shane
Read original post in this threadLast edited by Guest001; 12-08-2014, 06:41 AM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
Burn the disk put it in, wait It will either do it or leave it as it is. Takes an hour roughly Read through the thread all instructions and pictures are there2021 Kamiq LE 110 , Moon White, BV cameras F & B
